Originally Posted by zopperman
Yeah - I used 2000 grit sandpaper to get the paint off. The needles are very fragile. They also make special needle paint that like glows or something, I can post a link later. Also to get the needle part out of the housing you have to Dremel out some plastic rivets and glue the needle back together.
I think the needles in the Limited cluster are the only ones that need to be taken apart to change the color. Also, after you sand the orange paint off, you'll need to use some white paint on the back of the needle to get good visibility again. If you leave them clear with no paint, they will not be very visible.
