Originally Posted by wkeryder4
Can you elaborate a little more on how they are tunable? I understand that the remote reservoir version can be upgraded to a CDC valve to fine tune the dampening but I'm not familiar with how the standard shock setup can be tuned. Would that be something I would need to discuss with the factory prior to purchase?
These higher end shocks provide the dealer/end user a few options for tweaking. As
Troymclure
mentioned the shims are the primary way the valving is changed. The psi for the nitrogen added can be increased/decreased as well as the viscosity of the oil used. Once you add the remote resi and Adjustment knob the end user can turn a knob that restricts the oil flow which primarily changes the rebound, compression is changed very slightly.
At the end of the day for you the Icon shock is a smoother better performing shock.
