Old 07-23-2014, 07:12 AM #16
gshadow325 gshadow325 is offline
gshadow325 will become famous soon enough
Originally Posted by turbo sol View Post
these pictures are from inside the cabin. under the glove box. both the ABS module (smaller looking ECM) and the main ECM.
I appears to be an oil/ATF type of liquid as mentioned by the dealership
is removing the ECM simple? it looks tucked up there pretty tight.
question is how did that get there? was the grommit on the engine bay passenger side loose?
gshadow325 is offline   Reply With QuoteReply With Quote
Old 07-24-2014, 04:44 PM #17
turbo sol turbo sol is offline
turbo sol is on a distinguished road
I cleaned up the connectors as best I could. and will keep an eye on them.
I had Adv. Auto reset the CEL and read the codes
P0136
P2238
(both 02 sensors on bank1)
I've been dealing with the rear parking brake show assembly at the moment, so I haven't had a chance to look that deep into the engine bay harness / grommets.
But the dealer thinks the fluid is coming up from the transmission wiring harness…
turbo sol is offline   Reply With QuoteReply With Quote
Old 07-24-2014, 07:53 PM #18
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Capillary action, its really interesting actually. Like I mentioned earlier in the thread its common on some of the European makes like BMW where their coolant sensors rot through and then coolant is transferred THROUGH the wiring harness in the engine bay all the way into the ECM in the cabin.
P0136
P2238
The thing is that they should be able to tell you which sensor/switch/connector is suspect. So far it just seems they stopped trying after finding fluid, which is kind of crappy if they were already under the car looking at stuff?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 07-24-2014, 09:04 PM #19
BlackWorksInc
how do the european models fix the issue? if its capillary action, shouldn't a splice in the offending wire stop it?
here are a few more pics of the passenger side O2 sensors
lower
this plug was next to the lower passenger O2 and appeared to be completely dry.
Upper O2
Old 07-24-2014, 11:33 PM #20
BlackWorksInc
how do the european models fix the issue? if its capillary action, shouldn't a ...
The BMWs, Hondas, GMs, ect. that have these types of issues have updated sensors/switches that are not as prone to rotting out as the previous design.
As for a splice, that may or may not work. From my understanding, the fluid actually travels inside of the physical wires. There's microscopic space between the wire strands when their made into electrical wires (since most electrical wiring is stranded and not solid copper), so the rubber/plastic outer layer actually encourages capillary action. I would suspect that a splice would slow it down some, but would probably not eliminate the issue as it still has small holes/spaces inside of the splice connector and between the wire strands.
Old 10-09-2015, 04:47 PM #21
tahot1 tahot1 is offline
tahot1 is on a distinguished road
Conclusion
So what was the conclusion to this story?
I have confirmed all of what you mentioned.
-ATF in the o2 sensor connector
-ATF connector as the source wicking fluids
-ECM connector (2nd form top) oily.
Is it worth changing all the harness, ECM and o2 sensors?
tahot1 is offline   Reply With QuoteReply With Quote
Old 10-29-2017, 11:28 AM #22
dta1984 dta1984 is offline
dta1984 is on a distinguished road
Alright, so I have been chasing down 02 codes and lean codes (p0174, p0171, p0136) for over a year. Replaced both downstream 02 sensors, a/f relay, and all general tune up stuff (plugs, cleaned maf, pcv, tb clean). The codes would always come back....sometimes not all 3 at once.
A deep Google search last night and I came across this oil in wire harness phenomenon. A light bulb clicked and I remembered last year while replacing one of the 02 sensors, there was moisture in the plug. So sure enough today, I pulled the top 3 plugs from the ecm and there was red-brown oil on the second and third plug.
@BlackWorksInc , any idea which sensor may be wicking moisture?
Can someone give me a diagram of this harness?
@OP if you're still around, what was your solution?
Here is my original thread; 02 Sensor Check Engine Lights
oil wicking up my o2 sensor wire harness?-20171029_111514-jpg  oil wicking up my o2 sensor wire harness?-20171029_111449-jpg
dta1984 is offline   Reply With QuoteReply With Quote
Old 10-30-2017, 12:35 AM #23
Looks like it could be transmission fluid? I am not sure... haven't seen this on a 4Runner before.
Old 10-30-2017, 07:53 AM #24
Ya, that is what I was thinking.
This link shows the sensor in the transmisison pan may be the culprit https://www.justanswer.com/toyota/6x...r-chronic.html
I think I am just going to dry everything out with compressed air and see how long it takes to re-saturate, and the check engine light to come back on.
Old 10-30-2017, 11:12 AM #25
Just thinking out loud here, but what if I cut the connection from the transmission sensor as the OP was going to do. Is there a type of connection to re-join the wires that would be less susceptible to capillary action (spade, butt, solder etc.)? What about splicing in solid core wire? I know solid core wire and vehicle vibrations don't mix too well though....
Old 10-30-2017, 12:22 PM #26
Supersonic Supersonic is offline
Supersonic is on a distinguished road
Going to add the end of the link so everyone knows what's going on. Thanks for posting all this it's very mysterious and I wish you the best getting through it so you can drive your 4Runner again with confidence.
Originally Posted by dta1984 View Post
This link shows the sensor in the transmisison pan may be the culprit https://www.justanswer.com/toyota/6x...r-chronic.html.
I think I have a solution to the A/F sensors failing. I am now pretty confident that the problem was transmission fluid wicking through the wiring harness from the transmission sensor to A/F sensors (including between connectors in the ECM behind the glove box). I replaced the failed A/F sensors with new sensors, but before I installed them I spliced in a piece of solid wire in each of the four conductors. The theory was that this would block the transmission fluid that was wicking through the braided wire. I did this about 1.5 years ago and have not had a problem since. Prior to this fix, the A/F sensors were failing in just a few weeks after installing. I also preformed this fix to one of the downstream O2 sensors that failed. I used high quality sealed but splices to splice in the solid wire segments (http://www.mcmaster.com/#9895k11/=tbr293).
you can also check the transmission ventilation if not plugged, as this will cause high pressure in the tranny case.
Supersonic is offline   Reply With QuoteReply With Quote
Old 10-30-2017, 01:24 PM #27
BoostinZX's Avatar
BoostinZX BoostinZX is offline
BoostinZX is on a distinguished road
BoostinZX's Avatar
I am very interested in how this turns out. I have had similar intermittent issues driving me crazy. I have replaced the A/F sensors and O2 sensors, just to have them go bad in a few months. The car intermittently will run like crap, and then will run fine for a few days/weeks/months, etc... and then run bad again... I'm thinking this may be a very possible culprit to the root of all my problems... Thanks for bringing it to my attention dta1984! Please keep us posted on the progress and ideas!
2005 Limited V8 4x4
BoostinZX is offline   Reply With QuoteReply With Quote
Old 10-30-2017, 01:31 PM #28
Thanks for posting that! It does clear up what I was referring to.
Old 10-30-2017, 01:34 PM #29
Hey no problem! Glad to see it may be the root of your issues as well. Our symptoms are very similar.
Most likely it will be this coming weekend i'll get back around to working on it. My intention is to first blow out all of the connectors and ECM, and see how long that lasts me. Next step will probably be to splice the wire somewhere to see if I can stop the capillary action.
Old 10-30-2017, 01:57 PM #30
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
I'm still find it hard to believe that the transmission fluid is getting pushed through the wiring harness, especially the O2 harness, and into the ECM. I don't recall ever seeing that on any of the vehicles I've worked on. I would think you would see one of the connectors between the transmission and ECM start to leak first. Plus, if the connectors are dry inside, there's no way that's the issue.
It's funny that this thread popped up because a friend of mine was dealing with some lean codes on his super clean, pampered FJ after the dealer forgot to put the air filter housing together. He put the air filter housing back together himself but ended up taking the FJ back after the codes re-appeared. The dealer's findings were that the transmission over-pressured due to a plugged transmission vent and pumped ATF through the harness to the ECM. They recommended replacing the ECM, entire engine/trans harness to the staggering cost of $5k, and that was just to start. It didn't sound right to my buddy because they never mentioned anything about clearing or replacing the trans vent or to find out why the transmission was over-pressurizing so he had them put it back together and he drove it home. Not to mention that the FJ is driving and running perfectly fine other than the CEL was on. The dealer supposedly showed him oil on the ECM connectors but the oil, or whatever it was, had no color, it was clear. When my buddy inquired about that the dealer stated that the ATF in the FJ was clear, not red (more red flags).
I went and checked the FJ out and pulled apart several connectors (O2 and some others) and found them to be dry. I next went the MAF, since the whole problem started with the dealer leaving the air filter lid off. I cleaned the MAF and so far the CEL is off and the FJ is running great. I feel that the dealer was completely trying to take advantage of my buddy. I never dug into the ECM to see if oil was on those connectors but I really doubt oil is getting to them anyway. Like I said, it just seems highly unlikely that such a thing could even happen, much less to a low mile, very pampered FJ.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
cel , o2 sensor , oil , vcs , wicking
Wire Harness?? Whalergang66! Maintenance/Detailing 1 05-15-2012 10:16 PM
WTB: Wire harness cheesencrackers Want to Buy/Trade 0 09-18-2010 01:55 AM
non-JBL wire harness pin out hkccool98 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-21-2009 09:49 PM
VSS wire in radio harness? mattrpav Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-20-2008 12:53 PM
I have the scion RCA wire harness... Larry77 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 02-16-2006 03:58 PM
