Originally Posted by xtremewlr
Check and clean all the grounds that you can find. Dirty ground could also be causing you issues.
Yes, thank you. I have checked and cleaned the grounds I can find, but is there a diagram or list of grounds that may not be obvious? I've done all the ones I can see around the battery box, top of engine / manifold and alternator. I can't seem to find where the big block ground is, there is a protected wire that looks pretty decent gauge that goes down and under the engine from the battery (one of the big 3?), but I'm having a difficult time locating where it bolts to the frame/engine.
Anyone else run into this or have pictures of the grounds? Assuming the big cable from alternator runs directly to positive side of battery, or is there a splice somewhere in between?
Since she starts up fine I wasn't going to pull the manifold off to get at the starter.
Where does the cluster read the voltage from? I'm guessing at the ECU near fuse box? Are there other wires in that area that aren't obvious?
