Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 02-04-2019, 10:55 AM #376
hewitt-tech hewitt-tech is offline
Real Name: Paul
hewitt-tech is on a distinguished road
Real Name: Paul
Originally Posted by loarmistead View Post
Chatted with Rutech on their bypass. Asked them if the blocking plates were necessary if I was only installing the bypass and the system hadn't failed yet. Rutech said the plates are still necessary as gasses will circulate back into the engine without them... if the valves haven't frozen open, how is that possible? Are they saying this just to cover their butts?
Seems that if system is still operational, simply disabling the pump via the bypass module should be all that is necesary.
Any credence to Rutech's claim?
Please don't take anything Rutech says as factual. He did not design what he is selling and his units are made in China regardless of what he claims. He simply sells them and does not understand how the system actually operates.
www.hewitt-tech.com - Home of the original Secondary Air Injection System Bypass Kits.
Contact us [email protected] or Call Toll Free 844-307-7671
Current development vehicle - 2015 4R Limited
hewitt-tech is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 10:09 PM #377
MattDamnit MattDamnit is offline
MattDamnit is on a distinguished road
So I had this issue with my 05 gx 470 with the pump being stuck and the relay a? po418 or whatever. I ordered the rutech off ebay for 200 and saw I also needed the pump proxy kit, I called Hewitt and they said rutech copied them and it should work together just fine? Can anyone concur?
MattDamnit is offline   Reply With QuoteReply With Quote
Old 04-08-2019, 01:31 PM #378
shoehorny shoehorny is offline
shoehorny is on a distinguished road
I ordered a AIP bypass kit from Jeff Coleman (slyfox75) for $48 from this site. He sent me email confirmations. I installed it in my wife's GX470. It took less than 15 minutes to do and it was silly easy to do! No need for "plug-and-play" kits. Anyway, my CEL went away and no more AIP problems! Thanks Jeff!
shoehorny is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 06:13 PM #379
michael99b michael99b is offline
michael99b is on a distinguished road
Is it true that the bypass causes more problems then its worth on the 2008 V8?
michael99b is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 06:50 PM #380
SAC-CA-Runner SAC-CA-Runner is offline
SAC-CA-Runner is on a distinguished road
I don't know, but I believe I'm having issues with my Rutech as I've been hearing my pump kick on when I start the 4R lately. And here I thought the Rutech was supposed to completely keep it off when the 4R starts. I'm also wondering if it is linked to the starter in any way as I've been having issues with my 4R not turning over right away. It's VERY hit or miss. I installed the Rutech before pump failure so I may take it out along with the plates and see if my starting issue keeps up. If it does then I'll swap the starter. Weird because I get more issues after going thru water. Nailed it down to starter, Rutech failure (since my pump is also turning on, which it shouldn't), or possibly the parking switch. Things that make you go hmmmmm
SAC-CA-Runner is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 11:36 PM #381
bookooc bookooc is offline
bookooc is on a distinguished road
Originally Posted by slyfox75 View Post
Deputy.....yeah, just send me your pics to jeffcolemaps at gmail and I'll hook you up. These should not no affect on your starter if installed properly but yes I will help you determine what you have and where we need to go from here to get you fixed up.
-Jeff
Hi Jeff,
I want to order your kit. tried a PM, isn't working. Sent you an email
Rick
bookooc is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 12:02 AM #382
zeekevin zeekevin is offline
zeekevin is on a distinguished road
i do not have any air pump issues yet with 202k. but as a preventative maintenance i ordered slyfox75 aip bypass kit and installed in with zero issues.
zeekevin is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 11:17 AM #383
stopthefury stopthefury is offline
stopthefury is on a distinguished road
I have a BRAND NEW Rutech plug and play kit for sale (no block off plates) for $150 shipped!!
stopthefury is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 04:37 PM #384
RBLACAUSA's Avatar
RBLACAUSA RBLACAUSA is offline
RBLACAUSA is on a distinguished road
RBLACAUSA's Avatar
Crap. This happened to our 2006 LX470 three yrs ago, 102k miles. Guess a call to Toyota N.A. is next.
'04 4Runner 4X4 SE V8
'06 4Runner 4X2 SE V8
'03 4Runner 4X2 Lmtd V8
'06 LX470
RBLACAUSA is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 06:04 PM #385
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
I really can't understand why most are so resistant to change the airpump. Its not that bad of a job.
I got the labor, starter, airpump, rad hoses, gaskets, fluid and any misc items that came up for under 700.00.
Now i never have to worry again or have to deal with extra wiring.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 06-26-2019, 06:55 PM #386
slyfox75 slyfox75 is offline
slyfox75 will become famous soon enough
Well let’s see
~$50 bypass, 1 wire and 10 mins to be done.
Or
$700 an entire day for most people AND have same system that failed you once already.
THATS why we all bypass.
Sounds like you replaced the pump. That is typically one of 2-3 failure points within the system. Hopefully you cleaned the ASVs and other components as they clog with crap and eventually fail.
It was smart to replace the starter while you were in there for sure.
slyfox75 is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 04:45 PM #387
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
Nothing like this has happened to me yet but im both happy there is a long thread about this topic but also unhappy that it seems common enough to cause worry.
royal T4R is offline   Reply With QuoteReply With Quote
Old 07-02-2019, 11:05 AM #388
Real Name: Paul
Real Name: Paul
The Rutech and other bypasses will cause a P011B Temperature Correlation code on the 08 and newer vehicles. There was a change in how the computer does this test starting on the 08 model year vehicles. We have a specifically designed bypass kit for the 08 and newer vehicles for this reason.
We are alse getting ready to release our Next Gen units that will cover all the 4.0L engines up to the current model years. They operate completely different than the current units and are completely plug and play with no need for a connection to the MAF, IAT or the starter relay. They essentially replace the Air Injection Control Driver and connect to the ECM inputs there and of the air switching valves. If you add one of our pressure sensors to the kit for a 4.0L or two for a 5.7L you can completely remove every component of the system.
Secondary Air Injection Pump Failure on V8's! Important!-4thofjuly2019-jpg
Old 07-29-2019, 12:57 PM #389
Bedstraps's Avatar
Bedstraps Bedstraps is offline
Bedstraps is on a distinguished road
Bedstraps's Avatar
Happy Customer
I installed my SlyFox bypass last night. 15 minutes. Stopped the screaming shop vac sound. I'm so happy.
For anyone else considering this or wondering if they have the same problem, My car engine "made the awful noise" whenever it was cold. Cold is relative in my case. It would do it in the summer and winter whenever it had been sitting a while.
Geaux Saints
Bedstraps is offline   Reply With QuoteReply With Quote
Old 08-02-2019, 11:54 PM #390
Plates now available.
Forum.......wanted folks with V8s to know I now sell the blockoff plates(4.7 and 4.6/5.7 if you have another platform in your arsenal). Another source used to sell the plates individually so I sent many of you that direction to help you get the parts you needed. That source has since decided to stop selling the plates individually. For those that want to save a little money and still fix your system, the plates are $40 for the pair. The bypass is still $48. $88 complete kit. Most don't need plates but some want them anyway for complete solution. If you have Tundra, Seq, LX, GX and obviously 4R, just let me know yr /model and I can get you setup. 2005-2012 V8s.
-Slyfox
PS Pump Failure joneseyyy 5th gen T4Rs 17 01-04-2022 01:08 AM
secondary air injection help Txjcb5002 4th Gen T4Rs 10 08-27-2020 12:21 PM
Air Injection Pump.... Whiplash Willy 5th gen T4Rs 35 02-12-2020 07:38 AM
Possible Water Pump Failure? onekyoung 4th Gen T4Rs 4 06-22-2013 12:57 AM
85 2.4D oil pump failure garey Classic T4Rs 0 05-08-2007 06:58 PM
