Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 01-08-2024, 09:42 PM #541
slyfox75 slyfox75 is offline
slyfox75 will become famous soon enough
Originally Posted by robotfood540 View Post
I've had the Slyfox bypass installed since 2022 with no issues, yet as I was casually driving down the highway my car went into limp mode and the CEL and VSC lights came on. I got home to my scanner and pulled the P2445 code (secondary air injection system pump stuck off bank 1). I thought maybe this would be related to the "cold weather glitch" as described on the Hewitt-Tech website, but I'm in Massachusetts and have certainly driven in cold temps (-20) without issue until now. Any idea what the issue is?
Couple things to be aware of or think about.
1) The AIP system doesn't engage under 41F anyway, so if bypass failed, the system wouldn't run anyway if you are cold starting sub 41F.(yet to have a known failure in the field BTW).
2) The cold weather glitch isnt a repeatable "normal" thing. Its very rare. So I wouldn't assume because of living in MA and it hasn't happened yet, doesn't mean it won't.....and then may never happen again(or at least be very rare). Do you have a OBD2 scanner? Not to clog up this thread but with a quick check you can look at IAT(Intak air temp) and determine of bypass is working. Email me for details if you want to track it down.
3) Rodents (it happens)
4) Bad MAF sensor. (OBD2 can check this as well)
-jeff
2005 SR5 V8 4x4. Shrockworks Sliders, 4th gen Limited Wheels, Falken Wildpeak ATW3, Slyfox75 Bypass of course, Bilstein 5100s w Dobinson's Coils(314 & 505)
Slyfox75 AIP/SAIS bypass kit. Bypass = $49 Stainless Blockoff Plates $28(pair) email to jeffcolemaps at gmail for more info or questions. -jeff
slyfox75 is offline   Reply With QuoteReply With Quote
Old 01-19-2024, 04:43 AM #542
joec500 joec500 is offline
joec500 is on a distinguished road
Originally Posted by jbock View Post
lol at "bypass installation Olympics". That would be a quite a thing to see a bunch of 4Runners lined up and you knocking these out like a pit crew.
Well thanks again, I retuned all the parts I bought and I will be doing the bypass. I ended up buying the Hewitt one so I didn't have to cut any wires. I'm planning on having this 4Runner till it dies, but just in case I ever need to sell it or whatever, it makes me feel a little better that I don't have to cut the wire. I know its probably an irrational concern, but it may help me sleep a little better. I did some research on your kit and its really clever. Kudos to you for figuring it out and providing a really great affordable option for people as well as good support. Those types of things make for a really great community and I as well as many others appreciate it.
I did the hewitt bypass and Live in CA, easily passed smog. Nothing about the kit looks aftermarket so unless the tech REALLY knows that they are looking for it's no problem. Most SMOG techs just look for blatant aftermarket parts.
joec500 is offline   Reply With QuoteReply With Quote
Old 01-22-2024, 10:29 AM #543
mnorm757 mnorm757 is offline
mnorm757 is on a distinguished road
I've had the Slyfox bypass kit for about 18 months and the exact same thing happened to me on the freeway this morning. Temp went down to 17 last night so I'm hoping this may be the culprit. I cleared the codes (P2445 & C1201) once I got to work and the truck seems to be driving normally. One exception...the TPMS light will blink for a minute and then remain steady on despite all five tires being inflated correctly.
Follow up...
I just realized my battery is over five years old (October 2018). I probably should've put a new one in when I replaced the alternator in 2022 (multiple jump-starts). Could this be the culprit?
mnorm757 is offline   Reply With QuoteReply With Quote
Old 02-02-2024, 06:22 PM #544
kenwoodguy kenwoodguy is offline
kenwoodguy is on a distinguished road
Do you still sell these kits?
kenwoodguy is offline   Reply With QuoteReply With Quote
Old 02-02-2024, 06:56 PM #545
yes, see signature.
Old 02-05-2024, 08:24 AM #546
parsky1 parsky1 is offline
parsky1 is on a distinguished road
I have the slyfox kit installed. It took care of my P1442. I never installed the plates. I notice though that when it gets down to -10 to -20F the blower still runs on a cold start. It sounds like crap!!! Seems like that shouldn’t happen? My concern is most temperature sensors are non-linear and the 4.99k resistance added by the kit isn’t enough to trick the ECU when it’s that stinking cold out.
This is exactly how it sounds at really cold temps: https://m.youtube.com/watch?v=It9KqnsVorU
parsky1 is offline   Reply With QuoteReply With Quote
Old 04-25-2024, 03:29 PM #547
matrix111 matrix111 is offline
matrix111 is on a distinguished road
So i got the vacuum sound on cold start 3 days ago (went away after 30 sec). No codes, truck runs fine, no limp. If i ordered a AIP bypass, do i need to install the plates? How would i know if the valves are close/open?
matrix111 is offline   Reply With QuoteReply With Quote
PS Pump Failure joneseyyy 5th gen T4Rs 17 01-04-2022 01:08 AM
secondary air injection help Txjcb5002 4th Gen T4Rs 10 08-27-2020 12:21 PM
Air Injection Pump.... Whiplash Willy 5th gen T4Rs 35 02-12-2020 07:38 AM
Possible Water Pump Failure? onekyoung 4th Gen T4Rs 4 06-22-2013 12:57 AM
85 2.4D oil pump failure garey Classic T4Rs 0 05-08-2007 06:58 PM
