Originally posted by rook
Mr. Lambdebois,
From your other thread regarding the tire rub, I believe this issue is related to the recent oil change. The last person who changed the oil bent the skidplate when removing the filter or possibly let it hang by a few bolts to gain access thus causing the plate to distort and not mount flush. You may need to experiment a little to get the noise to stop, but I'd bring it in to the dealer first.
Yes the last person did not unbolt the oil pan at all apparently. When I asked them how they got to the oil filter they showed me and it was clear their arm slightly bent down the side of the skid plate and made it rub. After checking the bolts I just gave it a slight bend back. No more rub....
I still don't think that bending the far side of the skid on the outside of the bolts where it was hitting the tire on right turns, would cause a distortion in the very middle of the skid if it was bolted down tight when the oil was changed. The other thing is I had noticed this noise before the oil change.
Either way.... I am going to run it up to the dealer today and see what they say first.
Thanks again for all your advice guys. I really do appreaciate it.
