Originally Posted by 03_4x4Runner
I think the problem is 206k miles. You should be happy that is all it is doing.
It is a 4runner, my 3rd gen is close to that and drives/runs as good as new, I'd be disappointed if it doesn't go well past 300k, along with my 4th gen.
In any case, you can try starting at the PCV valve, it's cheap and easy enough to change (google where it is for more details, but it's threaded on the driver's side near the firewall). Compression test can indicate whether you have worn rings, but when my old car had worn rings it was smoking all the time.
