Installation directions continued:
Did i disconnect my battery? No, should you? You should. I'm a pro it will not blow LOL...Dont try this at home kids hahahaha.
Ok with the airbag out you will see two connectors for the airbag. orange goes to orange. black to black. you need to pry the yellow clip up to release the two airbag connectors.
What it looks like inside with the airbag out
Disconnect this connector that for the steering wheel controls and cruise that go into the clock spring
what it looks like when the connector is out
Now the wheel is tilted to the left a little because i took the steering wheel bolt off and LOCKED the steering column. i took this picture as reference for me to see where the wheel was before i put everything back together.
Steering bolt is a 19mm.
The fun part. You should use a steering wheel puller. I dont have one, i used good old fashion muscle, yes i work out LOL hahaha. easiest way i found to get it off was, pull on the top towards you, then pull on the bottom towards you. rinse and repeat. basically wiggling it off. wiggle it, just a little bit remember that 80's song LOL
here is the back of the factory wheel. why you need to see it? i dont know but here it is.
Just in case, I tested to see if the splines lined up with the new wheel and my truck. It does indeed, i was getting happy now.
