08-03-2014, 08:16 PM
Real Name: 03 v8 Limited
Icon overland coil spring info needed
so i picked up some icon overland coils for the rear of my 03 limited
i see no way these things will fit ?
anyone installed these
coil spring rear suspension is all new to me
i know
remove shocks and sway bar end links and brake lines
stand on axle .
i just don't see how these monsters will fit.....
also are ext rear brake lines required when installing these springs?
08-03-2014, 08:48 PM
i know
stand on axle .
They are long springs. You will need ext brake lines. Find a way to get a spring compressor on them and work them in. You may also need to put the oem jack between the bump stop and the axle to push them apart farther.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
08-03-2014, 08:50 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
spring compressor x2, worked on my superflex plus a 2" spacer. or worst case just disconnect the lower links and drop the axle. oh and disco the trac bar
08-03-2014, 08:51 PM
i cant just remove the brake line hangars like i did on my taco?
i mean i have the lines already...just dont have the time
08-03-2014, 08:52 PM
Real Name: Steven
Real Name: Steven
I'm not sure how much longer those exact type springs are but I just installed the Icon 2" springs a few weeks ago. As ebg18t stated, I used my factory jack to spread it open.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
do what?
i have zero knowledge of this rear link system
im a leaf guy
08-03-2014, 08:53 PM
Maybe short term, but with springs that long you really need longer brake lines. You may want an adjustable track bar too.
08-03-2014, 08:54 PM
Moderator
Real Name: Zak
Moderator
Real Name: Zak
do what?
im a leaf guy
oh yeah, the trac bar - you'll see it runs from the frame (on the pass side) to the axle on the driver side. disconnect it on the driver side. use a floor jack under the brake rotor on one side to flex the axle and open up the other side. then if you have to use spring compressors, use compressors.
08-03-2014, 09:39 PM
I'm with Zak, if you have both springs out support the pumpkin with a jack stand in the center and use your jack to raise up the opposite side from where you are working
Build Thread
OME 886/896 w/OME shocks, "customish" sway bar end links, 265/75r16 KM2s, ext. diff breather, plastidip, CBI DLB's w/BeanLED duallys, custom electrical distro, Cobra 75wx st, 4ft Firestik Firefly on Comet RS730, Demello 3 hoop bumper w/Warn VR 8000, Camburg Balljoint UCA's, CBI rear plate bumper w/swing out tire carrier, CBI bolt-on sliders, Matte Bronze Konig Countersteer Type X 16s, more to come....
08-03-2014, 10:42 PM
Time to see what my local mechanic would charge
Sounds like fun
I can barely even see my existing coil spring
Its ****ing crazy
08-03-2014, 11:13 PM
Sounds like fun
Its ****ing crazy
Please don't! Haha if you have the trucks frame supported by jack stands it is an extremely easy install.
Link to instructions: 2007 Toyota 4Runner Sport Edition Lift
Build Thread
