Old 08-20-2019, 11:40 PM #1
dalandshark's Avatar
dalandshark dalandshark is offline
dalandshark is on a distinguished road
Do you have an old caliper you can take apart?
Hi,
I am looking for a picture of a caliper that is taken apart... like the two halves of a sandwich. Why, you ask? Because... I am curious how much meat there is and where the fluid passages are. Obviously, there are some pictures on the internet of calipers in this state of affairs. But, I couldn't find one from a 4runner, much less the larger size caliper from a 2003 V8.
So, if you find your curiosity aroused, please take one apart and post a picture.
Thanks!
P.S. Yes, this has to do with wheels. But, not the common issue already posted about in these forums... that will be a whole another issue worthy of its own post.
2003 4runner sport (V8, RWD, Mostly Stock)
dalandshark is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 09:11 AM #2
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
How much meat is there?
-Enough
Where are the fluid passages?
-The path is only on the one side with the pistons for the rears. You wouldn't see anything with it split apart.
The fluid enters through the brake line and enters a void behind the pistons. They most likely have a narrow single channel with an o-ring that jumps to the other side for the fronts. I would assume they are separate since we commonly get just one side seizing.
There is also a small pass for the air valve to enable the bleed procedure.
Everything else is solid. It is a cast part so the fact that it is two pieces would typically just be to simplify the mfg process.
Edit* I was able to find this image of a similar setup. looks like just one crossover passage*
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 12:16 PM #3
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
I'm guessing he's trying to figure out how much material he can take off to reshape the calipers to fit his wheels.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 01:35 PM #4
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
I would guess the same. meaning he probably wants to see one with the pistons removed.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 08-21-2019, 10:26 PM #5
Yes, I want to see how much I can take off. I don't need much. I started with cleaning up the excess casting. It is enough for the wheel to spin but barely a sheet of paper. I drove to work two days (64 miles) so far no problem. But, I'd like another millimeter or two. I added an arrow to the picture from UrbanRunner651 to show what part is in question. Unlike people putting 17" wheels onto the smaller brakes (seems they need to help the outboard side of the caliper) my problem area is the ends. In my case, they are 17" wheels from a 2019 Tacoma.
Old 08-22-2019, 07:31 AM #6
Captsolo Captsolo is offline
Captsolo will become famous soon enough
You are wasting your time IMO. I had a top mechanic work on an old caliper up on the lift off a 2005 SR5 and it took hours, and he failed, and said get him a new one.
Here's what I got at Amazon for $68. Fit perfectly.
With calipers, new or remanufactured is the way to go.
https://www.amazon.com/MAYASAF-Calip...Toyota+4Runner
it's been working a year now. He did a total brake job. Old caliper was 15 years old.
Captsolo is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 09:31 AM #7
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
^pretty sweet. i got a rebuilt oem installed by mechanic and he listed it to me for i think $98
hinmo24t is offline   Reply With QuoteReply With Quote
Old 08-22-2019, 10:57 PM #8
I appreciate the input, but this thread is not about replacing my caliper. My caliper works fine, and is a reman oem installed by the dealer last year.
caliper , find , issue , picture , post
brake rotor/caliper/pad replacement - caliper piston, too? amheck 4th Gen T4Rs 16 11-08-2017 09:29 AM
4th Gen Caliper and pad jmauld For Sale: T4R Items 0 02-09-2017 08:17 AM
Brake caliper question - which caliper mfg doesn't lock up? bergs 4th Gen T4Rs 6 03-14-2015 09:18 PM
Caliper rebuild...torque settings for caliper halves squabeggz 3rd gen T4Rs 0 07-24-2014 11:08 PM
Caliper Timbo 4th Gen T4Rs 3 06-01-2013 03:30 PM
