Originally Posted by Brutalguyracing
unsure what your doing but a normal circuit would be like this
power wire from battery with a fuse as close to battery as possible - run this wire to a relay
from relay to light or whatever your hooking up
ground from relay to ground
acc wire from a switched source to switch- then from switch to relay
then ground wire from light or whatever your hooking up to ground
so in your case find a fuse that only powered when key is on
then buy an add a circuit pull fuse plug in add a circuit then install fuse
i will send over a diagram when i get home
i am on my phone now
dont think i forgot anything
good luck
See the part I highlighted in bold? That's the part I'm missing. I can sit there with a multimeter and hunt for one, or I could call on the collective knowledge of this board to see if someone has already done it and can just tell me which one to use.
I am not new to wiring up a relay for Aux lights - I already built the harness and it's ready to be installed. I was just trying to make the process more efficient.
