Old 08-25-2014, 04:35 PM #1
Flyingbread1 Flyingbread1 is offline
Flyingbread1 is on a distinguished road
Question 4th Gen XREAS Springs Question
Thank you guys for being here. I have read so many threads here that my head is spinning. I cannot believe how useless the Toyota dealerships have been in my area regarding XREAS :redbrick:. They will only replace with original factory XREAS, what a bunch of garbage. Most of the shops around here as well have to do some research, very few will even touch it, even the main 4x4 shop doesn't want to touch it. If I hear Strutmasters replacement suspension one more time I am going to scream:gun5:. Ok, rant over thanks for reading.
I have an amazing 2006 SE with XREAS and need new shocks after 140000 miles, probably needed since 120000 :target:. I am ditching the XREAS and have no plans to lift since I am an older guy now. The only question I can't seem to find the answer for is if I can keep my original coils/springs and what that would mean for my ride. Did they use different springs in the XREAS setup or are they the same as in the Limited? I have narrowed my replacement shocks down to either Bilstein HD's or OEM shocks for the 2006 limited for budget reasons. I will also look to upgrade my front sway bar bushings to poly as was recommended here. Any help regarding the springs would be greatly appreciated.
Flyingbread1 is offline   Reply With QuoteReply With Quote
Old 08-25-2014, 05:28 PM #2
pc1p's Avatar
pc1p pc1p is offline
Real Name: Patrick
pc1p is on a distinguished road
pc1p's Avatar
Real Name: Patrick
Hey Flyingbread - I'm in the same boat as your for the most part. My 04 V8 Sport w/XREAS has worn and lightly (for now) leaking rear shocks.
To my knowledge, the springs between the XREAS and non-XREAS suspension are NOT different, the only difference in P/N's I see are for wheel-drive and engine configurations.
I will be replacing mine with Bilstein 5100's when it cools down here in Phoenix. I'll also be grabbing a set of MOOG FJ Springs to help give a bit more lift without being a true lift kit (mine is only 2WD and I mainly do desert rides and dirt roads)... just enough to fit some 265/70's underneath.
BTW, Toytec has a set of 5100's for $399 or less - which is about as cheap as AutoZone replacement shocks.
2004 2WD 4PreRunner Build Page | OME Nitros | OME 885/895E | K&N AirCharger | Gibson Stainless Exhaust | ES Sway Bar Bushings | Goodyear Wrangler DuraTrac 255/75 R17 115S SL | CBI Ditch Light Brackets | Hella 500 Fog's
2003 Infiniti G35 w/Stillen goodies (we've put over 180k miles and still running strong, my wife's DD)
2012 Harley Road King w/goodies (put on almost 10k since getting new)
pc1p is offline   Reply With QuoteReply With Quote
Old 08-25-2014, 08:36 PM #3
OzarkRunner's Avatar
OzarkRunner OzarkRunner is offline
OzarkRunner is on a distinguished road
You should check out this thread, if you already haven't.
You certainly can keep the original springs and just change the shocks, but you might be slightly disappointed in the ride without updating your coils. In March, I swapped out my XREAS with 5100s (front set a 0.0" lift) and also put new Moog 4Runner coils in the front. I like the look (removes some of the rake, but not all), but am now wanting to also get new coils in the rear. It's not a bad ride, but I want just a little lift in the rear so that I can move the front shocks up to 0.85" of lift.
2008 Sport / V8 / Bright Silver FN FX Pro / 255/75 Duractracs / Fox 2.5" Factory Front Coilovers / JBA / Superpro / Fox 2.0" Rear / Wheeler's T12 / Limited Grill / Rigid Duallys / Flowmaster 70 Series / ScanGaugeII on Blendmount / 5k LEDs / Homelink Upgrade
OzarkRunner is offline   Reply With QuoteReply With Quote
Old 08-25-2014, 09:02 PM #4
Sporin's Avatar
Sporin Sporin is offline
Sporin is on a distinguished road
Sporin's Avatar
I was just looking at RockAuto and you can get complete Moog FJC front strut/coil/mount assemblies ready to drop in for about $100 each. New coils and shocks for the rear are around the same.
http://www.rockauto.com/catalog/x,ca...parttype,15174
So let's say $400ish for all new FJ suspension to replace an old 4Runner Xreas. Am I understanding all if that correctly?
My 150k mile Xreas is definitely feign tired and I'd love to replace it with just a bit if lift over stock/new height. Mild off-roading, mostly road.
Sporin is offline   Reply With QuoteReply With Quote
Old 08-26-2014, 09:53 AM #5
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
My X-Reas failed on my 03 Limited at 138,000 km (or 85,750 miles). There was a leak in the system - in the line behind the Driver’s Side Centre Control Absorber. Leak was likely caused by corrosion of the line due to road salt used up here during our Canadian winters.
In discussing options with my Toyota mechanic, he strongly advised not replacing the failed system with a new X-Reas system (cost prohibitive for one thing!).
I really didn't have the option (i.e., time!) of shopping around for shocks, so we installed the standard Toyota SR5 shocks. The coils were not changed.
Note: I have the Rear Air Suspension (RAS) with height control.
When my mechanic removed the X-Reas system, he left the lines on my 4Runner. He must have drained and sealed or capped off the lines somehow, because I have had no leaks from the failed system.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 08-26-2014, 10:07 AM #6
ben550's Avatar
ben550 ben550 is offline
ben550 is on a distinguished road
ben550's Avatar
I'd love to try that. I used to steer clear of SE's because of the xreas suspension but now id be willing to swap it out if/when it started leaking. The standard SR5 shocks would definitely be sufficient for me but the 5100s would be cool too.
ben550 is offline   Reply With QuoteReply With Quote
Old 08-26-2014, 10:32 AM #7
How was the ride with that setup? The MOOG strut assemblies look appealing too but there aren't any reviews of those that I can find.
Old 08-26-2014, 10:33 AM #8
2007 TOYOTA FJ CRUISER Strut / Coil Spring / Mount Assembly
This looks appealing and keep install cost down a bit. Have you found anyone using this setup?
Old 08-26-2014, 10:43 AM #9
Bossman's Avatar
Bossman's Avatar
The X-Reas being a cross-linked, closed system was definitely innovative as a suspension system for this heavy SUV. From my recollection, the system handled just fine. But the inability to properly repair/service components of the system is a huge drawback. If one shock leaks, you pretty much have to replace the entire system :O
As for the ride with the standard SR5 shocks, I can't say I noticed much of a difference. That is, the X-Reas did not completely outperform what the standard SR5 shocks are doing for me now.
Mainly city/highway driving, with a few dirt roads now and then. Ride comfort seems just fine to me.
Old 08-26-2014, 11:16 AM #10
How many miles were on your original springs? I am trying to figure out if it's worth getting new springs now since most of my cost is going to be in labor. Although the easier the better for my install since everyone is a bit concerned with the XREAS. I am actually considering a guy who posted his services on craigslist for the install but he will only install the assembled front struts which makes the Moogs a nice option.
Old 08-26-2014, 12:48 PM #11
Sporin's Avatar
Sporin's Avatar
I have to dig through the stickied thread still.
Old 08-26-2014, 02:01 PM #12
As luck would have it someone posted set of front struts and rear shocks from a 2014 Tacoma TRD 4x4 in my local craigslist for $50.00 so I picked them up. I just read a thread that talks about the Tacoma suspension swap and at that price I am going to go for it. I'll need to change out the lower bushing on the rear shocks since they'll be going from a leaf spring Tacoma to my 2006 4R. I'll also need to pick up some rear springs from an FJ to match the lift that the Tacoma struts will give me. I've been reading a few positive reviews for the Moog rears. Sorry to abandon the original purpose for my post.
Rear: 81081 (sold as a pair; $42.97)
http://www.summitracing.com/parts/mog-81081
Old 08-27-2014, 07:13 AM #13
Sporin's Avatar
Sporin's Avatar
From the Tacoma suspension swap thread, relevant to this discussion...
Originally Posted by chompster4runner View Post
Moogs rear FJ coils won't fit into the groove on the axle. I should know because I took em off after I bought it and after I googled a little more and there was other members with the same problem. So I ended up with oem FJ coils. If I had to do it again I would skip the rear FJ because there was negligible difference in height and ride. Better to get rear spacers and set the Tacoma/ FJ front coils @1.75 for level look or stay with stock rears with Tacoma/FJ front set @.85 for a level look. I am currently @FJ rears with spacers and Taco coils on front [email protected]. Gives me a stock rake look which is better for loading cargos and headlight issues as the front lift a bit with cargo in the rear. Good luck!!
Sounds like new shocks, stock springs and a spacer is what's needed for the rear. Even cheaper!
Starting to think this is the budget way to go for me when the time comes to pull the Xreas.
Old 08-27-2014, 11:18 AM #14
Cygan1008's Avatar
Cygan1008 Cygan1008 is offline
Cygan1008 is on a distinguished road
Cygan1008's Avatar
I have don't the Xreas to TRD Tacoma swap. The MOOG Fj Springs will need about 1/2" cut off of the end of the bottom to seat correctly or you could go with the moog 4runner coils which from what I have seen seem to fit better. The TRD Bilstien Tacoma suspension is a nice ride and handles very well. Front is direct swap and like stated above the rear just needs a bushing change, which is cake.
'03 with '12 TRD Taco swap with 1/2" Toytec front/1.5" DaystarRear, 265/70/17 Cooper Discoverer ATP's on Sequoia Split Spokes
Scarcely for a righteous man will one die; yet perhaps for a good man some would even dare to die.
Romans 5:7
Cygan1008 is offline   Reply With QuoteReply With Quote
Old 08-27-2014, 11:24 AM #15
How much lift did you get in the front with the Tacoma TRD setup. I just picked up a set from a 2014 that will be installed next week. I am going with some OEM FJ rear springs paired with the rear Tacoma shocks. Can't wait to get rid of the shot XREAS.
coils , springs , xreas
XREAS out, FJ springs + Bilstein 5100s in AKmoney 4th Gen T4Rs 26 05-14-2017 11:40 PM
Xreas/daystar/fj springs hrjaw 4th Gen T4Rs 9 01-30-2014 12:57 AM
What to do with XREAS and springs? 762x51 4th Gen T4Rs 2 11-23-2011 03:59 PM
Springs-XREAS Shocks FREE !! natevans65 4th Gen T4Rs 4 08-05-2011 12:21 PM
Xreas replacement, Same springs? dittodog Engines / Suspension / Wheels / Tires / Audio / Accessories 1 11-29-2010 03:46 PM
