Originally Posted by Radial GT
Hello!
I am wondering if anyone else has seen this code on an '04 Limited with the V8?
I got this code after parking my truck for a week while I was on a business trip. 15 minutes after driving away from the airport it came on. Of course it turned on the VSC and TSC lights. So when I got home I pulled the code I got this code on my scan tool. I clear the code and the light, but the VSC and TSC come back on as soon as I put the truck into gear.
So I search, and search for anything in regards to this "Transmission Fluid Temp Sensor Bank A" and I cannot find anything on it for my model year truck. I go to my local Toyota dealership and with my VIN are not able to find a sensor on the transmission at all for temp sensing. The parts guy calls his contact at Toyota and they say that it is the temp sensor on the engine up by the thermostat. I have the part on order but am not completely convinced that this is going to be the fix.
Basically I am hoping someone out there has had the same issue to provide some input.
Thanks!
Mitch
Did a quick search because I haven't seen that code before - I found this on a tundra forum:
According to the FSM, the P0710 code IS NOT an ATF OVERTEMP condition, it's a circuitry problem where the ECM is seeing the following:
Either (a) or (b) is detected momentary within 0.5 sec. when neither P0712 or P0713 is not detected
(a) ATF temperature sensor resistance is less than 79 Ohms.
(b) ATF temperature sensor resistance is more than 156K Ohms.
The P0712 code means the ATF temperature sensor resistance is less than 79 Ohms for 0.5 sec. or more
The P0713 code means the ATF temperature sensor resistance is more than 156K Ohms for 0.5 sec. or more
The causes for the P0710 code are listed as:
(1) Open or short in ATF temperature sensor circuit, or
(2) Defective ATF temperature sensor, or
(3) Defective ECM
No idea if it's the same as the 4Runner but I'm sure it's similar. I imagine
BlackWorksInc
would be able to clarify and help out much more than I can!
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver
Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
