10-12-2015, 10:34 AM
#31
Originally Posted by BobbyC4Runner
I purchased my first 4Runner a couple weeks ago. 2001 Limited Toyota 4Runner. How do I know what a normal amount of rust is and how much I should be worried about?
Worry about it now, and you won't later.
Show a pic, so we can see the rust and let you know if it is critical, or just in need of early control.
There's a reason you separate the military and police. One fights enemies of the state, the other protects the people. When the military becomes both, then the enemies of the state tend to become the people...
10-12-2015, 01:50 PM
#32
Originally Posted by willbgood
I like rust mort for my commercial/industrial applications. Under a toy, you have to be careful as it is caustic. I would use it first, paint, and then Fluid film. Fluid film is new to me, but my research has shown its used in industry, and has been for years. I was talking about it this weekend, and a friend told me, that NASA uses it, so I figure it must be pretty well thought of, by the rocket scientists.
For some of the rust I see on eastern toys, I would consider grinding out the old rust, rust mort around the area, and welding on plates.
It not cheap, but it works great. http://www.amazon.com/SEM-69501-Rust...ords=rust+mort
Of course the best plan would be move west, buy a new rust free toy, and Fluid film it...
PS: your project is looking good...most people do not pay any attention to the rust underneath until they have a frame failure.
so do you recommend using this, then applying POR15 on top?
living in the northeast, I expect to have my underside completely salted this winter.
somehow the previous owner did a decent job with keeping rust at bed. he must have went to the carwash twice a week.
10-12-2015, 02:16 PM
#33
Yes, and FF on top of it all. It will a dirty job, but saving the underside is worth it.
Waxing and cleaning your car, and ignoring the underside, is like a women who gets a tit job, but doesn't Kegal...what's the point?
The same goes for handling the underside, but ignoring the inner spaces of the frame, doors, and any other space expose to moisture on a regular basis...your frame with just rust inside out, hence my recommendation FF.
10-12-2015, 03:42 PM
#34
awesome! This is something I have to do within the next month.
Ill start ordering supplies.
how much do you think it will take to do the frame and other pieces underneath? a gallon of each?
10-12-2015, 08:14 PM
#35
Post a pic, and I can tell you, but you are probably pretty close with a gallon. Rust more only has to applied to the actually rusty areas, not any where there is paint. You should wire wheel and sand before application. Rust mort lasts forever as it is basically a mild acid, so even if you have extra, it won't go bad.
The POR 15, a gallon will do it for sure, and likelt with left over, that will not last more than year or less, once expose to air. If I remember right. a gallon does 250 square feet, but remember you are going to be on you back painting, so you will have waste.
Amazon has a Fluid Film gallon kit, with applicator, or you can go direct to site, (I think they are about the same price, but amazon prime ships in two days, free, )that will definitely do your whole car, including inside the doors and kicks. Amazon also has rust mort, and I would guess Por 15, so again with amazon prime, free shipping.
10-14-2015, 03:17 PM
#36
Originally Posted by Vols77
What about areas like steering components, can it be applied there also?
Sorry for the delay. Yes, dump it on everything but your brake rotors. The beauty is you can just hook it up to an air-powered spray gun and blast away. Quick & easy.
And to clarify some above posts, Por-15 should go on first, then FF on top. And I recommend getting the smaller 6-packs of POR-15, unless you're doing your entire frame at one time (which is a PITA and not worth it, IMO.) Just treat the bad areas with POR and dump FF all over everything. I recommend the 6-packs of POR over the gallons, because once you re-seal a POR can, you're not getting it open again. Stick with the smaller ones and use a whole can at a time.
10-14-2015, 07:36 PM
#37
Would typically a body shop do this ? Lots of surface rust on my 4runner. would be nice to have this be done on a lift, doing this on jackstands is just not possible for me.
10-14-2015, 08:07 PM
#38
10-16-2015, 10:55 AM
#39
So I have the Mort stuff and 6 pack of por15 coming Monday.
I figure I'll order the FF after, as I think it will take a couple weekends to do the underside.
12-12-2015, 01:31 AM
#40
Originally Posted by Skinfaxi
I use FF on my 3rd gen. I have the hose with both the straight-shot nozzle and the 360 degree sprayer for inside the frame rails. Never had to use anything else.
I'm going to apply FF to my truck this weekend. Do you take care in certain areas or basically just spray away?
It mentions to perhaps not spray rubber, anybody encounter problems spraying electrical wires or anything like that?
I did the Eastwood internal frame coating, but I'll probably FF the interior of the frame as well for extra protection.
12-12-2015, 09:35 AM
#41
FF is safe on electrical connections and most rubber as well - see the FAQ: Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor
But on this page they mention it may soften some existing undercoatings - Fluid Film® | Corrosion Preventative, Lubricant and Rust Inhibitor - not too clear what undercoatings a T4R has to worry about here.
Got a gallon of FF and spray gun - jack and jack stands are next. Since I did not have a T4R to spray
it on I also just bought a 2008 T4R (from Tennessee) and want to spray it before this winter in sunny
Massachusetts.
I plan to spray everything except the brakes and exhaust components.
Guess I'm in the not worry about rubber or wires camp with this stuff.
12-13-2015, 01:28 AM
#42
Watch the brakes and exhaust. Other than that, blast away.
12-13-2015, 02:16 AM
#43
To all the POR15 lovers...are you guys actually following the application procedures with the de-greaser, metal-prep, then POR? Sure it's easy to slap a coat of paint on something and it look great short term, but I've seen so many long-term failures doing this. Just make sure you use products how the mfgr recommends.
For attacking rust, the best method is to eliminate it whenever possible, either through mechanical (e.g. wire wheel) or chemical (e.g. acids, chelation). Only if it's not possible to remove it should you consider the rust "converters".
Bare steel + a quality epoxy primer like SPI is my go-to for rust prevention.
For parts that can be removed, check out electrolysis, it's a very simple, cheap, and non-toxic way of removing rust. I've done in containers as large as 55 gallons with amazing results.
'04 V8 Sport 4wd, Daystar Lift, 265/70R17
12-13-2015, 12:28 PM
#44
Sounds like a plan. Thank for the info!
12-14-2015, 11:41 PM
#45
If you live in New England, you could do what I do. Take it to Heaths in Loudon NH for a hot chain saw oil application! Thats all he does all summer long!
