Old 09-05-2014, 12:10 PM #1
South-O 4RnR's Avatar
South-O 4RnR South-O 4RnR is offline
Real Name: Matt
South-O 4RnR is on a distinguished road
Real Name: Matt
Baja Designs as Foglight replacement
I rarely use my fogs on the road, and I like the look of a stock-ish truck. I want to replace my fogs with a light that will give me extra coverage while exploring and expedition camping.
I'm not a fan of HID's in the stock housing, and a easy bulb replacement isn't going to cut it either. I've seen a few who installed Rigid duallys in place of the fogs, but I'd like something a little bit better.
Baja Designs puts out some of the best LEDs in the industry. Their squadron XL-R is similar in size and shape to the factory fogs and 4300k lumens each is some serious light. Since these would eventually be complimented by one of their OnX light bars, I'm thinking of going with the 'wide cornering' output pattern.
My question is this; Assuming our fogs only draw 35w, would I need to stick with a product drawing under 35w to allow the use of stock fog wiring? These draw 42w each.
At what point does a replacement fog light become more than a fog? If aimed properly, would these still be considered street legal, or would you put them in the same category as HID in reflector housing (not safe for oncoming traffic)?
Spec sheet- http://http://www.bajadesigns.com/sc...ron-data-sheet
2006 Nautical Blue V8 AWD - King resi CO's & 2.5" rears, Icon 2" Spring
Builtright UCA, Magflow 50 series (resonator delete), Morimoto D2S 4.0's...etc
Sold- 2002 Thundercloud Grey, Sport Edition- King Coilover's, Builtright UCA
South-O 4RnR is offline   Reply With QuoteReply With Quote
Old 09-05-2014, 12:49 PM #2
HokieRunner's Avatar
HokieRunner HokieRunner is offline
Real Name: Matt
HokieRunner will become famous soon enough
Real Name: Matt
Those look nice. Just to clarify, those are definitely driving lights and not fog lights (just a pet peeve of mine that most low mounted supplemental lights are referred to as 'fog lights' these days...when they're not).
Also you had 4300k lumens. The 4300 lumens is correct but they're listed as 5000k for color. Again - sure you noticed but just clarifying.
Finally, onto your question - while you probably can use the factory wiring (I have no clue what gauge it is etc) I'd run a relay and fresh wiring. Use the stockwiring to trigger your relay.
Also - any aftermarket lighting is illegal. So you can be ticketed for it, fail inspection for it, etc at least here in VA. Now, if you aim it properly it shouldn't attract unwanted attention and you'll probably be fine for street use. But just be aware it probably is illegal. Of course, that hasn't stopped most of us from adding lights!
If you plan on using this for offroad/inclement weather, may want to consider a true fog light. I only use mine in the low/zero visibility conditions (snow storm outtings and heavy fog/rain), but the yellow fogs are life savers and really help with eye strain/fatigue.
Post up if/when you get them mounted.
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
HokieRunner is offline   Reply With QuoteReply With Quote
Old 09-06-2014, 11:52 AM #3
Real Name: Matt
Real Name: Matt
Hokie- I appreciate the feedback and clarifications. I tried to tread lightly on this subject as I've seen many members get flamed for going against the grain in the lighting department. After recently completing a retro on my projectors and installing the 4300k TRS retro-quik kit, the stock fogs need some help.
One of the things I liked about this light is the ability to modify the light after it's been installed. They sell replacement lens covers, so I figured I'd put install a yellow lens to help in the event of foul weather.
I'd agree that it's smarter/safer to run new wires and a relay and then just use the factory switch. I'm an electrical noob, so this sounds easier said than done.
Now I need to pull the bumper and see about getting the light to mount in the fog location.
BTW- always enjoy going through your build thread.
Old 10-23-2015, 07:05 PM #4
wmiranda wmiranda is offline
wmiranda is on a distinguished road
Actually there are several aftermarket lights you can use in Virginia. And if not listed the fact that the law states that if not listed, any SAE certified light with the appropriate markings are allowed. I have aftermarket lights on all my vehicles.
Virginia State Police - Safety Division
2004 Limited V8: Demello single hoop Bumper, Icon stage 3, stuff. 143k miles.
1997 80 series locked all around, OME 3" lift. Partial exo-skeleton. 12k Winch. 35s. Sliders. 336k miles.
2k Porsche 911, 97 BMW M3, both modded. Bikes, other stuff.
My Latest 4wd: 2014 E63 AMG Wagon - 600hp woohoo.
wmiranda is offline   Reply With QuoteReply With Quote
Old 10-23-2015, 09:44 PM #5
Dpassmore Dpassmore is offline
Dpassmore is on a distinguished road
I run one on my dirt bike and it's a bad ass light.
05' V8 4x4 230K LEVEL 8 MK6 wheels Grabber AT2
3.5"/2.5" lift 1/2" body lift Flowmaster 50 series
K&N filter with air box mods
Custom built roof rack
Satoshi grille
Dpassmore is offline   Reply With QuoteReply With Quote
Old 10-23-2015, 11:28 PM #6
Davy180's Avatar
Davy180 Davy180 is offline
Real Name: David
Davy180 is on a distinguished road
Davy180's Avatar
Real Name: David
This has me wondering too, the Amber wide cornering XL-R sport lights look nice.
Baja Designs as Foglight replacement-screen-shot-2015-10-23-8-29-02-pm-jpg
2006 T4R Sport 4WD V6 - Bilsein 5100 Shocks, Toytec 2.5" lift front coils, SuperFlex rear coils, Toytec front diff drop, Icon sway bar relocation block - BFGoodrich AT KO2 275/70/17 - Spidertrax 1.5in wheel spacers - DDM 6k low beam headlights & 6K dually ditch lights - Scion FRS radio - Custom rear sway bar end links
Build Threadhttp://www.toyota-4runner.org/4th-ge...ld-thread.html
IG: Davy180
Davy180 is offline   Reply With QuoteReply With Quote
Old 01-26-2016, 04:39 PM #7
Real Name: Matt
Real Name: Matt
I just picked up a set of XL pro's to play with. I'll report back with my findings. These puppies are huge!
Baja Designs LEDS? or Rigid? or Vision X? nosamk 5th gen T4Rs 5 02-25-2014 06:53 PM
4 baja designs 8" la paz lights blue dog For Sale: Non-T4R Items 8 10-02-2013 10:31 PM
Baja Designs 30" Stealth LED Bar RG79 5th gen T4Rs 11 11-12-2012 02:48 PM
Foglight Replacement Andrew_I 3rd gen T4Rs 8 10-29-2008 04:16 PM
