Old 09-11-2014, 03:32 PM #1
blackmax's Avatar
blackmax blackmax is offline
blackmax is on a distinguished road
blackmax's Avatar
Rear Turn-Signal not working....it's NOT the bulb??
driver's side rear ts stopped working (fast blink)....but when I checked it, the bulb is fine. I even swapped that pod to the other side and it worked. The one from the working side, when swapped to the non-working side, still won't work. I've wiggled everything I can see; and the inside contact points seem normal. I've tried the pod in every possible position. I'm pretty darn sure there is no voltage getting to that one. ??? how could this be? Anyone else ever have this??
blackmax is offline   Reply With QuoteReply With Quote
Old 10-05-2014, 08:31 AM #2
blackmax's Avatar
blackmax's Avatar
Bump.....still haven't figured this one out. Reverse light (just one, driver side) and the rear turn signal on the same side don't work. Both bulbs are good. I checked every fuse under the hood and also below the steering wheel.
any ideas?
Old 10-05-2014, 09:00 AM #3
wnelax04sr5's Avatar
wnelax04sr5 wnelax04sr5 is offline
Real Name: Ethan
wnelax04sr5 is on a distinguished road
Real Name: Ethan
any ideas?
did you replace the sockets?
A lot of stuff I didn't need...
My Build
Originally Posted by kfitz77555 View Post
oh my god the erection I have from this thread is unreal.
wnelax04sr5 is offline   Reply With QuoteReply With Quote
Old 10-05-2014, 09:43 AM #4
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
Would start by testing voltage at the socket and work backwards from there.
zopperman is offline   Reply With QuoteReply With Quote
Old 10-29-2014, 07:40 PM #5
blackmax's Avatar
blackmax's Avatar
Solved! (for anyone else out there who ever has this problem)
- so, for the entire rear assembly (that being the turn light and the reverse light) is powered by tail/brake light plug-in. If that isn't inserted properly, and isn't making proper contact, the assembly itself won't be energized; and the blinker and reverse lights won't work either. Kinda tough to describe....but essentially, you've got to fiddle with the tail/brake portion and it will fix the non-working blinker and reverse lights.
Old 10-30-2014, 12:40 AM #6
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
I'm guessing the main socket was not installed properly?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 10-30-2014, 12:50 AM #7
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Sounds about right.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 10-30-2014, 01:40 PM #8
sr3tlaw sr3tlaw is offline
sr3tlaw is on a distinguished road
See PDF
My issue was simply this fuse needed to be replaced. See attached
2007 LIMITED 4WD V8
Salsa Red Pearl
Husky Liners|Full Time 115v|Full Time 12v|Full Interior VLED|Independed Fog Light Mod|Dual Battery Optima Yellow/Yellow|Partial VLED Exterior|ICON Stage I|Moog Upper & Lower Ball Joints|DRL Mod|ProClip/Wilson Booster Custom Phone Mount|Bluesea Fuse Block|Speedohealer|Weathertech Bumpstop|Skids
sr3tlaw is offline   Reply With QuoteReply With Quote
Old 05-06-2017, 01:57 PM #9
Ryanmb21 Ryanmb21 is offline
Ryanmb21 is an unknown quantity at this point
Great thread. Right rear blinker went out, I assumed it was the bulb. I bought a new bulb from the dealer. The old bulb looked brand new when I removed it. Replaced and still didn't work. Then I replaced the "trn-haz" fuse. No dice. Then I unplugged the power going to rear brake light assembly, and plugged it back in. It worked.
So, no new bulb or fuse necessary. Weird.
Ryanmb21 is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 01:18 PM #10
I_bRAD I_bRAD is offline
I_bRAD is on a distinguished road
Well that saved me some effort, although I already blew money on replacement bulbs. Apparently this applies to other Toyotas as well since the problem was on my Echo
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
I_bRAD is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 03:20 PM #11
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Did you try the non working bulb on the side that is working? That would verify for sure that the bulb is good... or bad.
importman is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 03:35 PM #12
Syr4RinNC's Avatar
Syr4RinNC's Avatar
+1 for this. Very odd. I think my driver side rear turn signal burned out or failed. put in a new bulb and couldnt get it to work. I had to reseat the plug in harness for the brake light/ housing to get it work
Old 11-30-2020, 01:40 PM #13
Syr4RinNC's Avatar
Syr4RinNC's Avatar
So unplugging the harness worked briefly. Unfortunately l, I had to take out the entire taillight housing to clean all the contacts with contact cleaner and an eraser to remove oxidation. That finally did the trick. What a pita
Old 04-07-2021, 08:54 PM #14
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Update:
So I think I fixed my problem - for now. The housing had a bad connection between the metal contacts and wire. I wasnt getting continuity with the wire. So I gently pried this up stripped the wire a little and seated it better in the metal tab contact and was able to get continuity. Taillight is again working,
So I'm having issues, went to the forum and low and behold Im the last one to post.
So anyhow - Im having issues again. Im having some sort of fuse issue or some sort of extra resistance or a short causing the fuse to intermittently blow
Heres my recommendation if the turn signal isnt working after reading and going through all this.
1. Check the bulb on the other side to see if the bulb is blown/ needs to be replaced
2. Check the bulb socket on the other side to see if the socket needs to be replaced
3. lift up all the metal contacts on the sockets and power in socket to make sure you have good contact and use contact cleaner or dielectric grease etc
4. Unseat the power harness into the tail light and reseat it
5. Check the wires into the harness/ tail light for any damage
6. Near the steering wheel on the interior fuse box is a "turn signal fuse" - check this or try replacing
7. in the engine bay fuse box check the Trn/hzd (turn / hazard fuse) or try replacing
8. Take the tail light housing out and check the wire connections. Can use multimeter to check continuity.
Hope that helps someone.
Mines temporarily working tonight, but worried again tomorrow I wont be able to signal a turn and someone behind me will crash
Old 04-10-2021, 10:30 PM #15
mit_peid's Avatar
mit_peid mit_peid is offline
mit_peid is an unknown quantity at this point
mit_peid's Avatar
I have a similar problem on my 4th Gen (2005) 4Runner. I was troubleshooting an aftermarket backup camera that died on me and seemed to have screwed up something.
Here are my observations:
-Now all my blinkers are not working - however hazard blinkers work fine and using my keyfob to unlock/lock flashes the blinkers
-Reverse lights are not working (therefore cannot turn on backup camera)
-Center HVAC panel isn’t lighting up (or working) with the exception of just the clock
-received a CEL with code P0705 Tranny Range Sensor Circuit Malfunction; replaced part P/N: 8454004-010 “Automatic Transmission Gear Position Sensor” and it appears there’s no more CEL
- taillights and brake lights are working fine
-oddly my driver window Auto Down function doesn’t work (however I can still roll up/down all the windows).
My 4Runner was working fine before I started to “fix”the backup camera. Now all these things which kinda seem unrelated are messed up. Any clues or suggestions would be much appreciated.
2005 Black Sport Edition V6 4WD
18" Limited Rims
Eclipse AVN5500 w/ Ipod Adapter
Infinity 6.5" Reference x 4
Kenwood 4-Ch amp
Infinity Basslink
mit_peid is offline   Reply With QuoteReply With Quote
Turn signal not working? Std trouble shooting isn't working swapmeet 4th Gen T4Rs 9 09-14-2014 11:21 PM
Rear left turn signal not working. bootsmcrivers 4th Gen T4Rs 2 11-11-2012 10:11 PM
Front Pass. Side Turn Signal Not Working - Replaced Bulb 63custom 3rd gen T4Rs 1 05-29-2011 10:53 PM
Rear turn signal bulb part number? Jed 4th Gen T4Rs 4 02-22-2010 01:49 AM
Turn Signal Bulb....HELP 4runnerndachi General Discussions 5 06-12-2008 01:25 PM
