Old 10-03-2014, 03:46 AM #1
tjhaf2007's Avatar
tjhaf2007 tjhaf2007 is offline
Real Name: Tyler
tjhaf2007 is on a distinguished road
tjhaf2007's Avatar
Real Name: Tyler
Got an alignment and it still pulls both ways??
I put a lift on my new 2007 Limited 4WD V6, it went in for an alignment today and after getting it back, it still pulls to either side inconsistently, its a little squirrelly, i have to fight it to keep it going stay straight sometimes. it was that way before the lift. i just assumed it need an alignment. the tires on it are 265/60r18 cooper discoverer h/t. they have about 40% tread left. even wear on them, so im not sure if its the tire or not. they checked my front end and everything looked good. My 2003 SR5 V6 was never that squirrelly, what am i missing?
2003 2WD V6 SR5
2007 4WD V6 LTD
tjhaf2007 is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 04:25 AM #2
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
They should have given you a printout showing your alignment specs before and after. Post it.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 06:36 AM #3
ebg18t ebg18t is offline
ebg18t is on a distinguished road
If you installed a lift and kept the stock UCA's your caster is probably low which results in wandering. As Kid requested, post your alignment specs so we can confirm that your caster is low.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
ebg18t is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 12:14 PM #4
tjhaf2007's Avatar
Real Name: Tyler
tjhaf2007's Avatar
Real Name: Tyler
I have total chaos UCA installed.
2003 2WD V6 SR5
2007 4WD V6 LTD
Old 10-03-2014, 12:22 PM #5
Sungod Sungod is offline
Sungod is on a distinguished road
Your alignment looks good. They could dial in a little more caster, but I doubt that would make much difference. It could be the tires or it could be that you are a little more sensitive in driving from the change in ride height.
Sungod is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 12:24 PM #6
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
does it do this on all roads? or just some.
the fact, that its both directions is odd. maybe its just following the grooves in the road?
the alignment sheet looks pretty good. caster might be a touch low, but plenty high for it to track correctly.
rack mount bushings tight?
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 12:31 PM #7
olsen_karl olsen_karl is offline
olsen_karl is on a distinguished road
That alignment report shows 3* of caster -- that should be fine.
For the guys saying it could be higher -- isn't the top of the factory range only 4*?
FWIW, my 4R after last alignment was at about 2* of caster, stock control arms. Drives fine, no wandering.
olsen_karl is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 12:47 PM #8
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
It could possibly be your tires. Aged and worn tires can become out of round and sidewall stiffness inconsistencies can cause this. I'd locate a shop that has a Hunter balancer with load roller (like a GSP9700) or similar machine to diagnose this.
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 12:48 PM #9
tjhaf2007's Avatar
Real Name: Tyler
tjhaf2007's Avatar
Real Name: Tyler
im use to driving at this height though, it sits just about identical to my 03 sr5 i drove all summer. its the same setup that was on my 03 thats now on the 07.
i dont think it has to do with the roads, because it happens anywhere, its just wanders whenever it wants too. its frustrating.
i was thinking about rotating my tires and seeing if that would make a difference.
im use to driving on at tires, and right now it has ht tires on it, not sure if that would make a big difference in the wandering, but i thought id throw that out there.
my 2003 had 265/75r16 on it and the 2007 has 265/60r18, so it has a wider tread and shorter sidewall, while the 2003 had a much taller sidewall and a little narrower tread. sunday im hoping to pick up a set of used 275/65r18 toyo at with about 60% tread left. i just want to make sure to solve the issue before i pick them up.
2003 2WD V6 SR5
2007 4WD V6 LTD
Old 10-03-2014, 01:14 PM #10
sonerick's Avatar
sonerick sonerick is offline
Real Name: Nick
sonerick is on a distinguished road
sonerick's Avatar
Real Name: Nick
Just curious, is there any change in handling on your '07 between 2WD and 4HI settings?
You said the tire wear is even and they checked out the front end and everything looks good. Worn ball joints, bushings, etc. could cause wandering, but usually that would be manifested in some uneven tire wear.
Wider tread might change the feel a little bit, but not to the amount you describe.
FWIW, I run over 4* of caster with 3" lift and SPC UCAs on my '05. Handles the same as my sister's stock '06 (maybe even a little bit better). Maybe ask them to dial in the caster more and see if it helps.
2017 Chevrolet Silverado 1500 LT Z71
2011 Audi A4 2.0T Quattro
2005 4Runner SE V6 4WD (Sold)
2004 Volvo S60R (Sold)
1999 Jeep Cherokee Sport (Sold)
sonerick is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 01:51 PM #11
tjhaf2007's Avatar
Real Name: Tyler
tjhaf2007's Avatar
Real Name: Tyler
i just took it out and compared 2wd to 4hi. i couldn't get it to really wander like it did yesterday in either 2wd or 4hi. but i did notice that the steering has seamed a little stiffer in the 2007 compared to the 2003. i just assumed the 2003 was more worn and thats why the steering wasnt as stiff in 2003. i really suck at describing stuff haha.
im wondering if it could be my intermediate shaft? this car does has more visible rust than the 2003.
2003 2WD V6 SR5
2007 4WD V6 LTD
Old 10-03-2014, 06:51 PM #12
That caster is much better than I expected.
Old 10-04-2014, 03:51 AM #13
preacher35's Avatar
preacher35 preacher35 is offline
preacher35 is on a distinguished road
preacher35's Avatar
I'm not sure if you or anyone else has mentioned this, but have you thought that maybe your tie rods are shot? I mean, they're at a steeper angle now and any play is going to be that much more noticeable. Just my 2 cents.
2005 Sport Edition V6 / Toytec Ultimate 3" lift / Light Racing UCA's / 17x9 KMC Hoss wheels / 285/70 17 Goodyear Duratracs / Gibson cat-back / black headlights / HID's / Shrockworks bumper / Rola Vortex roof basket / LED interior swap / Emelianenkov's gauge cluster LED swap /
preacher35 is offline   Reply With QuoteReply With Quote
Old 10-04-2014, 11:28 AM #14
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
How much air do you have in the tires? May want to drop the pressure a bit. I would do a close check on all the bushings and tie rods to make sure there isn't an issue there.
I would also see if they can dial in a little more caster as well.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 10-06-2014, 08:43 PM #15
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
I found that on my '03, with the original Bridgestone H/T's, I could run at 37 psi and it rode and tracked well. But when I installed a set of Bridgestone Dueler Revo's I had wandering problems at 37, and had to run them at 34 to get a satisfactory ride.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Alignment Revolution- post your alignment print off sheets. 3rd Gen TacticalSR5 3rd gen T4Rs 66 02-17-2024 04:35 PM
pulls to the right when in 4WD DRVNGENTHUSIAST 3rd gen T4Rs 24 02-13-2014 09:07 PM
4WD pulls Runge17 Classic T4Rs 4 09-14-2011 02:59 AM
Next set of changes...for those familiar with Toyota's ways volrus7 5th gen T4Rs 29 12-29-2010 01:48 AM
how do u act when a cop pulls up next to you t4r4life Off Topic 42 02-14-2010 01:44 AM
