10-12-2014, 11:34 AM
Instrument Cluster Help
Hi,
I have an 04, and starting Friday afternoon my speedometer just stopped working. I've also noticed that my fuel gauge and temp, will sometimes just twitch back and forth when I start the truck. They'll eventually start working, but the speedometer doesn't.
I've been reading the forums, and it sounds like this has happened to others and the only fix is replacing the whole cluster? Is that correct?
So I have an 04 V8 with Air Suspension. Been having a hard time finding a cluster, since the air suspension was so rare it appears. I can only use an 04-05 cluster right? The 03's didn't light up all the time did they? The 06+ were slightly different I thought (they moved things around I thought I remembered). Is that right, or if I happen to find an 06+ with Air, it will still work?
Any other ideas on ways to fix my cluster?
Check out my 2004 4Runner Audio upgrade.
10-18-2014, 02:55 PM
So over the past week, the speedometer will sometimes work other times not.
Today I decided to take the cluster out to see if I can find the cause.
One thing I noticed about the speedometer compared to the other gauges. When the need moves, you can hear something inside the actual mechanism. The other gauges are silent.
So it's leading me to think that the speedometer drive is bad in my cluster.
I've removed it from the circuit board, to see if there were any numbers or anything on it. I can't find anything.
I really don't want to have to buy a whole new cluster off Ebay just for this 1 piece. Does anyone know where I could get this?
10-18-2014, 03:40 PM
Real Name: Ed
Real Name: Ed
I don't think you will have a choice. That's one very specialized piece of equipment, ALTHOUGH there are companies out there that will fix your cluster, but it doesn't sound like you are the type to send it out and get it fixed. I think they are called "stepper motors". Cheapest solution would be fleabay and do a swap of the stepper motor. Worth a shot
Either way: Speedometer Repair, Repair Speedometers &* Instrument Cluster Repair - Advanced Auto Electronics, Inc.
10-18-2014, 04:23 PM
There's some grey areas when it comes to instrument clusters due to the fact that odometer tampering is an issue and it is regulated. I suspect that only speedometer shops will have access to these parts (if they do at all) based on how strict the laws are on odometer tampering.
You're only bet is to get a used instrument cluster, send it to a repair shop, and/or buy a brand new instrument cluster. All the above steps with the exception of gutting an old instrument cluster for the motor unit require you to send it to a speedometer shop regardless to reprogram the mileage in the new/used unit.
10-18-2014, 07:03 PM
Ya I've emailed a couple places to see if they sell those motors, but I'm guessing they'll say no.
so ya most likely I'll buy a cluster of Ebay and swap it out myself.
sucks, that something like that had to go out. Really the first thing that's ever really broke on the rig in 157k miles. Guess I was due.
10-27-2014, 10:49 AM
Real Name: Ed
Real Name: Ed
Great find!!!! I've seen this happen a few other times so this is definitely useful. For whatever reason, when I recently unplugged my battery, upon hooking it back up, the needles started "break dancing" (moving maybe a 1/4 of an inch back and forth very rapidly). Lasted only 1-2 sec. Scared me.
10-27-2014, 11:10 AM
Thats exactly what mine was doing, it was actually causing all my gages to act up. At first I thought my whole cluster went out. So glad that was only that one little motor.
10-27-2014, 06:27 PM
Real Name: Ed
Real Name: Ed
Well, it's only done that to me (twitch) that one time. Today I disconnected the battery and they did not twitch (breakdance, LOL). Hopefully it stays that way. How often would they act up on you? (just to know in case this is the only the beginning of a failure).
Thanks
10-27-2014, 07:34 PM
i think you guys forget to do a zero point calibration for the cluster? i think everytime you guys remove and reinstall the cluster, theres a step by step procedure to do to zero point it out. i did this before and it solved my fuel gauge being inaccurate.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
10-27-2014, 07:38 PM
in the electronic service manual
look for the meter folder
then combination meter
look for the 0520012.pdf
i have the 06 service manual, it might be the same thing. also the buzzer will sound only if no seatbelt is plug, so dont plug in the seatbelt.
10-27-2014, 11:08 PM
Real Name: Ed
Real Name: Ed
Oh Jeeze, really? I've taken my cluster out about 10 times now, never did a zero point calibration. So far, so good. I guess I've been lucky. Good to know about it, thanks!
11-25-2014, 11:31 PM
Hello,
That's us. Glad you found us and the part worked out for you. This is a common issue among many vehicles, especially with parts and assembly becoming cheaper and made with more plastic.
If you aren't comfortable with the repair yourself you can certainly send in your cluster and we can repair it for you for cheaper than anywhere else in the country.
We do everything and anything related to gauge clusters, climate control units, and LED lighting.
You can send us a PM here or email us on the website to order more of these motors.
As far as odometer correction goes, we can correct the odometer on almost every vehicle. This comes in handy when we sell a refurbished replacement gauge cluster to someone so we can match their vehicle mileage.
I have a few 80-Series Land Cruisers and other Toyota/Lexus vehicles so don't think I'm just coming in here to make a quick buck
Take care!
11-14-2015, 05:05 PM
I have the exact same problem that you did. How hard was the stepper motor to replace? Thanks for posting the link too!
05-16-2016, 10:04 PM
Instrument Cluster Not Working Following Radio Install
Purchased an '03 Limited two days ago. Have been tuning it up before a cross-country trip back to school in two days.
Took apart the dash and installed my own radio. Radio works perfectly. Also painted dash with black truck bed liner. Looks awesome.
I put the dash all back together and turned on the car to find that the instrument cluster was not working. No lights, no odometer, no movement of the gauge hands.
Was there a wire cluster I did not connect again?
When I took the dash apart, I did not go past the instrument cluster.
All the lights work, the turn signals work, the radio works, etc. I checked fuses and spun the dash light. The problem is that the entire instrument cluster doesn't function.
I've attached an image. Let me know what y'all think!
