Old 01-26-2021, 03:22 AM #16
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Thanks for that review.
The Fox 2.0 vs2.5 is presumably why you had issues with the shaft. My Icon 2.0IFP lasted 13,000 miles. I had them to 250F. The shaft was well protected by the boot though so no shaft issues. That is okay, they were meant as a first step anyway. I will probably rebuild them and keep them for the heck of it.
Old 01-28-2021, 01:17 PM #17
Alpinst Alpinst is offline
Alpinst is on a distinguished road
I'm running 2.5 Radflo and I did need to get them rebuilt for pitting, even with the Icon shin & shaft guards. They hadn't lost oil yet because of pitting damage, one of them lost oil when the Icon guard was deformed back towards the shaft and punctured the shock body. But during rebuild it was obvious I was going to need the shafts replaced. Radflo now offers pre-installed rubber boots (for a small $) and I haven't had a pitting problem since.
I'm now running the Rago shock skid to protect the bottom shock mount. I'm just trying to warn people about the few skid designs that us bent sheet metal to provide "shaft protection". They won't protect the whole shaft, you'll still get pitting, you still need a boot. And the sheet metal "protection" can actually deform pretty easily leading to shock body damage. The only skid design I've seen that has thick, gusseted and welded shaft protection is the Rago. They still don't protect the whole shaft and so I'm also running rubber boots.
2018 TRD Off Road Premium w/KDSS. Pro conversion: TRD CAI, skidplate, and fascia. Radflo 2.5" lift, 2.5" coil-overs with remote adjustable reservoirs, Total Chaos UCAs, FN FX Pro wheels, 33" KO2s. RCI rock sliders and full undercarriage armor. Baja Designs Squadron fog lights.
Alpinst is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 01:24 PM #18
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Its kinda sad that these high end shocks dont come with any sort of boot or protection but the cheaper bilstein or eibach shocks come with a boot. Is there a reason for this?
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 01:37 PM #19
Boots protect from pitting but trap moisture and fine debris that can lead to their own problems and failures. In a perfect world you'd velco your shock boots on before heading off road and then take them off when you come out. Too much effort for me. I wheel in the southwest so moisture is less of an issue and pitting has already proven to be a problem, so I run boots.
Old 01-28-2021, 01:55 PM #20
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Don't attach the boots to the shock body. Shaft is protected and moisture drains.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 07:11 PM #21
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Shock Skids (non-King Shock) |
Anyone try those? Seems to remedy the shock bolt problem but no "shin" to protect the shaft - less of an issue for me with my booted IMS shocks.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 07:20 PM #22
montijo505's Avatar
montijo505's Avatar
Don’t seem like they protect the shock itself much other than the mount.
Old 05-11-2021, 08:23 PM #23
The boot covers the shaft on my shocks - no issues with that so far - I almost think the "shin" part is kinda a liability - bending it into the shock would be no bueno haha.
Old 05-18-2021, 01:33 PM #24
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Interesting read. I have Kings on back order and I already bough the sheet metal shin guards. Maybe I'll TIG weld some supports to beef up the shin guard a bit so the top piece doesn't bend in and mess up the shock body.
What boots are people running for rear king shocks? I ordered resis and adjusters.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Rear End Crash Protection alaskaman 4th Gen T4Rs 18 04-09-2015 06:01 PM
Rear bumper protection alaskaman 4th Gen T4Rs 12 10-08-2013 11:01 PM
Rear Shock Protection phillyd2 5th gen T4Rs 17 06-25-2012 06:37 PM
Rear Differential Protection 4Fun Off-Roading 5 11-28-2007 04:08 AM
I need some rear bumper protection BenSD Engines / Suspension / Wheels / Tires / Audio / Accessories 12 08-04-2005 02:51 PM
