Originally Posted by MarkinWMich
Belt tensioner?
The pulleys do tend to wear out around 100K, or so, but personally, I've had pulley issues and the noise is a bit different...hard to describe. At any rate, with that rattling noise coming and going every few seconds, and given the fact that your pump has been recently replaced, and you are not experiencing any coolant issues, I'd be less likely to conclude it was the water pump, but rather a rattling spring in the belt tensioner.
I could be full of stool, as well.
Haha MarkinWMich
I just saw the service records when I registered the 4runner after purchasing. It just said PUMP ASSY, WATER 1610009471 1 at 93000 miles so I am assuming it was the main water pump. I went to another mechanic today and he confirmed that the noise is more concentrated at the water pump assembly. Probably it is the bearing itself. Thanks alot for your input though.
