11-07-2014, 01:43 PM
Metaltech Rear Extended Travel Flex Photos
I thought Id post some pics of my recently installed Metaltech Stage 4 Rear extended travel suspension. I'm running the rear suspension with Metaltechs 3" HD springs. It definitely gives me more crawling ability as it keeps the rear wheels on the ground where they should be. I also installed an Icon adjustable rear track bar. The adjustability doesn't seem necessary but the hiem joint allows more flex yet in the rear. And no sway bars front or rear.
With regards to the Metaltech rear HD springs, they are not very rough around town unless I have my 10 ply tires at 45+ pounds pressure. When offroad and the tires are aired down the system doesn't feel any more firm than my previous Toytec bilstien height adjustable coilovers and rear 2" superflexes. I went with the heavy because its rare I offroad with no weight. I'm usually carrying 300-400lbs of beer, food, recovery gear and other camping supplies. The faster I go the better it gets, it soaks up the bumps amazingly well. The only thing id change is having the front being able to flex like the rear but I like the ride of IFS over solid front axle.
11-07-2014, 01:59 PM
Looks good! You look like a happy camper, understandably.
2004 SR5 V8 4WD White - Full LED Swap - Pioneer BT Stereo - Lite Racing UCAs - Toytec Bilstein 5100 Front 3"
Superflex Rear 2"- Spidertrax 1.5" - 255/75r17 Destination AT - SS Brake Lines - Prothane Bushings - SE Brake Upgrade - Full Synthetic
1994 SR5 V6 4WD Black - Bilstein HDs - OME 900 - 31" Destination AT
11-07-2014, 02:13 PM
Real Name: Ryan
Real Name: Ryan
This is insanely tempting to buy, how much lift over stock?
2003 SR5 4WD V6
wyanrard build/picture thread
-Bilstein 5100s w/OME 884 Coils Replica Camburg UCAs
-Procomp ES9000 extended rear shocks with Toytec SuperFlex Coils.
-2012 FJ Wheels (17s) wrapped in 275/70-17 Cooper Discoverer AT3 Load Range C. SpiderTrax 1.25 up front
11-07-2014, 08:23 PM
I got to check my numbers but its more than 3" in the rear unloaded. I have a 1.5" spacer under the drivers rear coil to level it. I needed it in my previous superflex rear setup and with this setup.
11-08-2014, 12:02 PM
Nice crocs!
Srsly, looks nice.
'92 Nissan 240SX - 400 HP/2500 lbs
'07 4Runner Sport Edition V6 RWD
11-08-2014, 04:31 PM
Real Name: Matt
Real Name: Matt
2006 Nautical Blue V8 AWD - King resi CO's & 2.5" rears, Icon 2" Spring
Builtright UCA, Magflow 50 series (resonator delete), Morimoto D2S 4.0's...etc
Sold- 2002 Thundercloud Grey, Sport Edition- King Coilover's, Builtright UCA
11-09-2014, 01:24 AM
Nice man looks good I have the same set up just not fully completed yet,we ran out of time doing the instal i still have to do the extended brake lines and bumpstops. I also have double disconnect rear sway bar end links but since its not finished yet i haven't got a chance to disconnect them yet but even with them still connected the amount of flex i have is still ridiculous it's still impossible to get the rear tire off the ground! Love this set up
[/SIZE]08 Urban Runner Dipped-Satoshi Grill,Icons,M LT,BAMF,RCI,Addicted Off Road Front bumper,4x4 Labs rear bumper,Warn M8000 w Spydura synth,FN Five Stars with 34" Goodyear kevlar Mtr's,4:56 Re gear with Rear FJ Elocker,Flow Master,Afe,and much much more..........
My Build > http://www.toyota-4runner.org/4th-ge...ld-thread.html
11-09-2014, 08:00 PM
Thanks guys
Originally Posted by RPS13
Nice crocs!
Srsly, looks nice.
Crocs are my offroad slippers!!
11-09-2014, 08:31 PM
Real Name: Tony
Real Name: Tony
I want this soooo bad!!!!
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
