Cliff notes: buy centric stainless steel front lines part # 950.44007 for $36 from amazon. same part as stoptech. install it, then you done.
Full story below
This problem has plagued my 4R since i bought it 19 months ago.
Its a 03 V8 SR5 that has right now 189,500 miles. so it has the 318mm brake rotors/smaller calipers.
I replaced the following way back when i got it, so everything has about 22,000 miles on it.
-All new rotors
-All new OEM pads AND parking brake shoes
-All new brake fluid
-front Calipers and rear calipers were not seized up and functioning properly
This past weekend i got a change to drive
kirkg
's 03 v8 limited 150k with the 331 rotors and the bigger calipers and stainless steel goodrich brake lines. he's a muffler and brake pro.
With his advice and then some more "research" on t4r.org.
He suggested i only do the fronts, there are 4 in the rear. they didnt do much and the two center rubbers lines didnt do anything at all for him.
Well this is what i did.
Found out that Centric is the parent for stop tech.
If you google search a set of stainless steel DOT approved brake lines for your truck using this part number 950.44007 you will get stop tech part AND centric part. Amazon sells the centric brand for $34.78 free shipping with prime plus tax. everywhere i look its going for $52 plus shipping
When you get the package from amazon its in a stoptech bag.
For me, i didnt even think my lines were bad, when i got the truck inspected it and it was fine. I got used to the problem.
Now with only the front lines done. the pedal has a much firmer feel. it doesnt creep at traffic lights anymore. i find the brakes are more touchy, instead of a mushy feel to it. I think it can be better, so i promptly ordered the rear two outer lines from "centric", so i cant comment if they are going to be the stop tech ones or not. at least not till next tuesday when they come in. btw the rears cost $52 bucks from amazon, still cheaper than everyone else out there!
here are the fine looking 189,500 mile old lines next to the new ones
Questions?
