12-11-2014, 04:17 AM
#16
i would love to swap them all on white or blue.
12-11-2014, 09:26 AM
#17
Yosh2000, which bulbs would be brightest for the info display? And would they be brighter than the OEM?
04-27-2015, 04:09 PM
#18
if someone could overlay this chart with the supervleds bulb chart so that forum memebers would know which oem bulbs corresponds to which superbrightvled bulbs...
for example my ac temp bulb is out..am not sure if its 4mm, or 5mm or 3mm superbrightvled bulb i should buy, can anybpody help?
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
04-27-2015, 04:11 PM
#19
I have already posted this...
http://www.toyota-4runner.org/4th-ge...ml#post1811914
i plan on updating this and posting it in a separate post for ease of all the noob questions. might even make sticky status!
05 4runner SR5 4x4 v8 : Build thread - Hailed totaled
17 Tundra SR5 crewmax 4x4 v8
04-27-2015, 04:20 PM
#20
Thanks for this Yosh!
04-23-2018, 10:40 PM
#21
Originally Posted by MasterAtArms
Any update regarding this?
12-22-2018, 03:17 PM
#22
Originally Posted by Rawkkrawler
I had one of the two bulbs out on the info display so I pulled it apart and looked for any obvious issues, unseated etc.. After a visual inspection, I put them both back in. Now both are out. I checked the voltage on the circuit board itself (where the bulb socket actually seats) and I read about 6.5 volts. Is this correct?
I don't mind trying the radio shack route and purchasing two bulbs and threading the sockets myself but after watching the YouTube video in this thread, it looks like I should be seeing 12 volts on the circuit board.
Can anyone confirm?
Thanks!
I hate to resurrect and old thread but I'm having a similar experience. Had a light out, purchased new ones from the superbrightleds and replaced them. Neither light worked, put the old one that had worked before back in and now it doesn't work. The Reset, Mode and Airbag lights all still work but the display does not. Curious if anyone had any ideas?
07-25-2019, 08:39 PM
#23
Superbrightleds say their bulbs only work when they get between something like 9- 12 volts. I only measure 6.x volts where the lamp is supposed to plug in at my climate control display circuit board for my 2004 4Runner. People claim they work but I assume my mileage is going to vary. I found Dorman incandescents with the plastic bases at RockAuto for less than $2 but you have to buy 5 at a time. If you want to buy at RockAuto look under "miscellaneous light bulb" in the "Electrical -Bulb and Socket" section for your vehicle, and make sure to check the Toyota part number with the Dorman alternate part number. I also found some "grain of wheat" 7219 incandescent bulbs with pigtail terminals on Amazon. They are rated 12v but they worked. You have to install these in the old bases. $7 for 10 pcs. I had to use my jeweler's magnifying headpiece to see what I was doing. My wife can read the 4Runner display again with these.
01-25-2022, 09:58 AM
#24
Has anyone replaced just the LED window part 81942A? Mine is badly scratched up from the previous owner. I wondered how ez it is to separate from the module.
01-25-2022, 04:14 PM
#25
Per the dealer 81942A is just a sticker. I was able to pick up all the bulbs for $40. Since I will have it out I will change them all at once.
01-25-2022, 05:05 PM
#26
Real Name: Mark
Real Name: Mark
I may have an extra laying around, let me check tonight. for those of you that don't know I do led swapping services.
LED Cluster, HVAC and accessory customization work
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
01-26-2022, 11:52 AM
#27
Per the schematic in the initial post; which diagram applies to the Sport Edition? The Limited or the SR5?
01-26-2022, 04:57 PM
#28
Real Name: Mark
Real Name: Mark
Just do this.
'04 Sport V8
01-26-2022, 05:00 PM
#29
Real Name: Mark
Real Name: Mark
I have one as I mentioned. Please see pic. Some paint came off around the edges on the back. I would think that’s an easy fix. The screen has a small dent in it, heat gun May fox that. PM me.
'04 Sport V8
01-29-2022, 02:44 PM
#30
Thanks for posting that photo Sparky. I ordered a new one for $13. Toyota dealer said he was only showing 3 in the entire country. When (if) it arrives I will have everything I need to be able to read the info center and HVAC controls.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
