Old 12-11-2014, 04:17 AM #16
isthunidal isthunidal is offline
isthunidal is on a distinguished road
i would love to swap them all on white or blue.
isthunidal is offline   Reply With QuoteReply With Quote
Old 12-11-2014, 09:26 AM #17
tweak tweak is offline
tweak is on a distinguished road
Yosh2000, which bulbs would be brightest for the info display? And would they be brighter than the OEM?
tweak is offline   Reply With QuoteReply With Quote
Old 04-27-2015, 04:09 PM #18
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
if someone could overlay this chart with the supervleds bulb chart so that forum memebers would know which oem bulbs corresponds to which superbrightvled bulbs...
for example my ac temp bulb is out..am not sure if its 4mm, or 5mm or 3mm superbrightvled bulb i should buy, can anybpody help?
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 04-27-2015, 04:11 PM #19
yosh2000 yosh2000 is offline
yosh2000 is on a distinguished road
I have already posted this...
http://www.toyota-4runner.org/4th-ge...ml#post1811914
i plan on updating this and posting it in a separate post for ease of all the noob questions. might even make sticky status!
05 4runner SR5 4x4 v8 : Build thread - Hailed totaled
17 Tundra SR5 crewmax 4x4 v8
yosh2000 is offline   Reply With QuoteReply With Quote
Old 04-27-2015, 04:20 PM #20
paperchasin paperchasin is offline
paperchasin is on a distinguished road
Thanks for this Yosh!
paperchasin is offline   Reply With QuoteReply With Quote
Old 04-23-2018, 10:40 PM #21
Togman Togman is offline
Togman is on a distinguished road
Originally Posted by MasterAtArms View Post
So, in order to do a the HVAC controls and LCD info panel in white, what would need to be purchased from here?
https://www.superbrightleds.com/more.../Photos&Videos
Any update regarding this?
Togman is offline   Reply With QuoteReply With Quote
Old 12-22-2018, 03:17 PM #22
hjones7276's Avatar
hjones7276 hjones7276 is offline
hjones7276 is on a distinguished road
hjones7276's Avatar
Originally Posted by Rawkkrawler View Post
I had one of the two bulbs out on the info display so I pulled it apart and looked for any obvious issues, unseated etc.. After a visual inspection, I put them both back in. Now both are out. I checked the voltage on the circuit board itself (where the bulb socket actually seats) and I read about 6.5 volts. Is this correct?
I don't mind trying the radio shack route and purchasing two bulbs and threading the sockets myself but after watching the YouTube video in this thread, it looks like I should be seeing 12 volts on the circuit board.
Can anyone confirm?
Thanks!
I hate to resurrect and old thread but I'm having a similar experience. Had a light out, purchased new ones from the superbrightleds and replaced them. Neither light worked, put the old one that had worked before back in and now it doesn't work. The Reset, Mode and Airbag lights all still work but the display does not. Curious if anyone had any ideas?
hjones7276 is offline   Reply With QuoteReply With Quote
Old 07-25-2019, 08:39 PM #23
Ferndaleguy Ferndaleguy is offline
Ferndaleguy is on a distinguished road
Superbrightleds say their bulbs only work when they get between something like 9- 12 volts. I only measure 6.x volts where the lamp is supposed to plug in at my climate control display circuit board for my 2004 4Runner. People claim they work but I assume my mileage is going to vary. I found Dorman incandescents with the plastic bases at RockAuto for less than $2 but you have to buy 5 at a time. If you want to buy at RockAuto look under "miscellaneous light bulb" in the "Electrical -Bulb and Socket" section for your vehicle, and make sure to check the Toyota part number with the Dorman alternate part number. I also found some "grain of wheat" 7219 incandescent bulbs with pigtail terminals on Amazon. They are rated 12v but they worked. You have to install these in the old bases. $7 for 10 pcs. I had to use my jeweler's magnifying headpiece to see what I was doing. My wife can read the 4Runner display again with these.
Ferndaleguy is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 09:58 AM #24
Dergibog Dergibog is offline
Dergibog is on a distinguished road
Has anyone replaced just the LED window part 81942A? Mine is badly scratched up from the previous owner. I wondered how ez it is to separate from the module.
HVAC and info center bulb information-led-cover-jpg
Dergibog is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 04:14 PM #25
Per the dealer 81942A is just a sticker. I was able to pick up all the bulbs for $40. Since I will have it out I will change them all at once.
Old 01-25-2022, 05:05 PM #26
S p a r k y's Avatar
S p a r k y S p a r k y is offline
Real Name: Mark
S p a r k y will become famous soon enough
Real Name: Mark
I may have an extra laying around, let me check tonight. for those of you that don't know I do led swapping services.
LED Cluster, HVAC and accessory customization work
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
S p a r k y is offline   Reply With QuoteReply With Quote
Old 01-26-2022, 11:52 AM #27
Per the schematic in the initial post; which diagram applies to the Sport Edition? The Limited or the SR5?
Old 01-26-2022, 04:57 PM #28
Real Name: Mark
Real Name: Mark
NEOx LED Bulb - High Power Instrument Panel LED | Super Bright LEDs
Just do this.
HVAC and info center bulb information-0d2f4731-a354-451b-ae09-639e318beff3-jpg
'04 Sport V8
Old 01-26-2022, 05:00 PM #29
Real Name: Mark
Real Name: Mark
I have one as I mentioned. Please see pic. Some paint came off around the edges on the back. I would think that’s an easy fix. The screen has a small dent in it, heat gun May fox that. PM me.
HVAC and info center bulb information-df9e0b83-c650-41dd-9245-b0a0aba324b2-jpg
'04 Sport V8
Old 01-29-2022, 02:44 PM #30
Thanks for posting that photo Sparky. I ordered a new one for $13. Toyota dealer said he was only showing 3 in the entire country. When (if) it arrives I will have everything I need to be able to read the info center and HVAC controls.
How To: HVAC Bulb Replacement - 4th Gen weifert 4th Gen T4Rs 15 03-09-2018 02:31 PM
HVAC Bulb Replacement Writeup ToyTec Lifts 3rd gen T4Rs 3 12-03-2017 04:04 PM
How do you replace the bulb in the digital display information panel? Hapeacres 4th Gen T4Rs 9 07-30-2014 06:45 PM
Plasti Dip information center JPWendtinc 4th Gen T4Rs 11 08-22-2011 11:19 PM
HVAC and Headunit bulb replacement. Jonathansgreene Classic T4Rs 0 06-20-2010 08:01 PM
