Old 11-27-2014, 02:46 PM #1
bdubbin bdubbin is offline
bdubbin is on a distinguished road
Inconsistent Heat
So it's winter... some times I get heat in my 4Runner (2006 V6) and sometimes I don't.
I spent 45 minutes with no heat this morning. I park in a garage that was probably 10C. It was about -10C outside. Engine temperature gauge indicated that the engine was warm after maybe 10 minutes of driving but I couldn't get any heat into the cabin. At a red light I turned the truck on and off to see if that would solve anything. No change.
I turned the 4Runner off and left it for 5 minutes outside. When I fired the truck back up again I had hot air; not just warm but hot.
I've noticed over the past couple months that I've inconsistently being getting cold air from my air vents even after the engine is warm and the heat is turned to max. I change the settings (floor/defrost/auto/fan speed/temperature/everything I can think of) and I can't consistently get hot air.
Any ideas what's going on?
2006 4Runner Limited V6 4WD | Daystar 2.5/1.5 | Duratracs 265/70/17 | All-Pro 1.25/1.5 | Morimoto Mini D2S HIDs
bdubbin is offline   Reply With QuoteReply With Quote
Old 11-27-2014, 04:08 PM #2
Rocketdog Rocketdog is offline
Rocketdog is on a distinguished road
Checktthe heater hoses coming to and leaving the firewall. If they are warm/ hot, then you have most likely have a problem with either the blend doors or the blend door motors that operate them.
Rocketdog is offline   Reply With QuoteReply With Quote
Old 11-28-2014, 12:06 AM #3
fourwd1's Avatar
fourwd1 fourwd1 is online now
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
have you done any work on the cooling system lately?
You may have an air bubble in there, which can be gotten out by bleeding the system.
'89 4Runner SR5 - stock
fourwd1 is online now   Reply With QuoteReply With Quote
Old 11-28-2014, 07:28 PM #4
Thanks I'll look into those.
I haven't done any work to the cooling system lately.
However, this morning was -30C and again I didn't have any heat... similar to yesterday traffic was moving at a snail's pace. Today I held the RPM's at 2 - 3k and did get heat to flow. After that the heat was okay. Does this point to something other than what's suggested above?
Old 11-28-2014, 10:17 PM #5
ARunner's Avatar
ARunner ARunner is offline
Real Name: Kyle
ARunner is on a distinguished road
ARunner's Avatar
Real Name: Kyle
If your temp gauge is looking normal, that indicates your thermostat is acting fine. The other possibility is you are low on coolant, but what you describe doesn't sound like that either. I agree it sounds like the electric device that allows heat to flow through the heater core and thereby provide you warm air in the cabin is a likely candidate.
Best way to isolate this IMO is turn the heat all the way to hot before you turn off the truck and park for the night. Confirm its hot. In the morning see if the heat indeed works. In this case the mechanism that allows for coolant to flow through the heater core should be out of play since it was opened already before you shut the truck off. Good luck. Sounds miserable. Hopefully you have some heated seats at least.
03 Limited V8 4WD
ARunner is offline   Reply With QuoteReply With Quote
Old 11-28-2014, 11:29 PM #6
RPS13 RPS13 is offline
RPS13 is on a distinguished road
No heat at idle means your coolant is low. Check the level and bleed the cooling system.
'92 Nissan 240SX - 400 HP/2500 lbs
'07 4Runner Sport Edition V6 RWD
RPS13 is offline   Reply With QuoteReply With Quote
Old 11-29-2014, 10:54 AM #7
scw1991 scw1991 is offline
scw1991 is on a distinguished road
first thing would be to verify the stainless steel heater core lines entering the cab from the engine bay above the gas pedal are hot. If so, then I'd suspect the blend door actuator is the culprit which is also located on the drivers side directly above the lower vent.
No heater core valve on the 4th gen that I'm aware of.
scw1991 is offline   Reply With QuoteReply With Quote
Old 12-03-2014, 03:44 PM #8
Thanks everyone... embarrassingly my coolant level was low. I fail. But I have heat now!
Old 12-03-2014, 08:51 PM #9
What sort of prize do I win?!?!?
BTW - keep an eye on your head gasket and your water pump (from under neath). Losing coolant is a bad sign, and hopefully it's just your WP weeping.
Cold heat coming out but auxiliary heat? Gremcat Classic T4Rs 4 11-19-2014 09:57 AM
1999 T4R SR 5 inconsistent starting. Terry C 3rd gen T4Rs 15 11-11-2014 05:28 PM
What would cause an inconsistent shake in the steering wheel??? Jeff T 4th Gen T4Rs 15 09-09-2013 10:45 PM
Long, inconsistent, crank T4RBoarder 4th Gen T4Rs 0 09-01-2010 10:55 PM
Inconsistent and sometimes abrupt transmission shifts eskimochaos 4th Gen T4Rs 26 07-23-2009 06:45 PM
