Old 07-13-2020, 07:12 AM #16
subersubs subersubs is offline
subersubs is on a distinguished road
I have a problem with my 08 SR5. Rear switch had the melted button cover so I removed to clean. Reinstalled it and now no function at all. Took it back off and noticed a little bit of the cleaning solution around the wires so im guessing it's fried now. Question is does the rear door require the button to be functional for a complete circuit on everything else?
Thanks in advance!
Sent from my SM-N950U using Tapatalk
subersubs is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 06:40 PM #17
Real Name: Skip
Real Name: Skip
Thanks in advance!
You can get a new replacement switch and cover for not too much, or get one at a salvage yard.
I not for if a defective switch will cause issues with other functions, but at the very least you will not be able to open the hatch
2004 Limited V8
Old 08-14-2020, 12:22 PM #18
Mr_Dobalina Mr_Dobalina is offline
Mr_Dobalina will become famous soon enough
Thanks in advance!
Did you get this figured out? I just replaced my switch and when I go to open it, it sounds like it locks it.
Don tknow what to do.
Mr_Dobalina is offline   Reply With QuoteReply With Quote
Old 03-27-2021, 01:43 PM #19
noslofivoh noslofivoh is offline
noslofivoh is on a distinguished road
I am having issues with my hatch and have no clue. It won't work from the switch on the outside which is new. And the window intermittently works with the key but works fine from dash button. I can use my Autel Scanner and activate the latch to open it so I think my ECU is fine but not sure. Any ideas?
Sent from my SM-N986U using Tapatalk
noslofivoh is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 02:43 PM #20
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
1 bad tailgate switch
2 broken wire in loom between body and tail gate
3 bad release solenoid (latch release) [should be a annual grease item]
4 bad control ecu
The order in which I'd check things.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 03:38 PM #21
Runnin on E Runnin on E is offline
Runnin on E is on a distinguished road
I just had this happen to me also. I had removed the hatch interior panel to look for the infamous "rusted hardware" that holds the window track to the door. I had disconnected to ECU harness to get a good look on that side. When I reassembled everything and closed the hatch it would not open no matter what. On the interior panel there is a small pop out panel maybe 3x4 inches. If you remove it there is a manual latch release lever inside, BUT that lever is covered by a second plastic guard that must also be removed. Once you get that far you can release the latch with the lever. I know this doesn't help with a bad ECU but at least you can open the hatch to get the interior panel off to investigate a possible cause. Hers the thing and this is the important bit. When I disconnected the ECU harness I wasn't aware that the ECUhad to be reset by disconnecting the battery (and starting the 4R). Once I figured that out everything worked normally again, and the best part was that I didn't have the dreaded rusted hardware (when it fails it can break your window, ouch!) Also I figured out how to get the hatch open manually and that the ECU needs to be reset if disconnected. Come on, how great is that....
Runnin on E is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 06:27 PM #22
LEX4runner LEX4runner is offline
LEX4runner is on a distinguished road
MY 06 4 runner the back wiper will start running when the engine is off and key out intermittently. I have reset the back ecu and battery several times , rear latch works now but just not sure why the wiper runs when power is off?? bad back ECU ???
LEX4runner is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 08:41 PM #23
Real Name: Skip
Real Name: Skip
This is a symptom of your battery being bad.
Have your battery load tested.
2004 Limited V8
Old 09-29-2022, 05:17 PM #24
TNRockyraccoon TNRockyraccoon is offline
TNRockyraccoon is on a distinguished road
Same thing happened to me a year or so back. I was able to get it to open by pulling out on the hatch while pressing the button. After a few days this issue just disappeared on it's on. Been good ever since and I never figred out what the issue was. I did shoot the latch full of wd-40 once I got it opened.
TNRockyraccoon is offline   Reply With QuoteReply With Quote
Old 10-03-2022, 01:39 PM #25
KanRunner KanRunner is offline
KanRunner is on a distinguished road
I had issues on my 09 hatch not opening. The release was completely seized due to rust. I hope you fix your problem, its incredibly annoying to not have a working hatch.
KanRunner is offline   Reply With QuoteReply With Quote
Old 10-09-2022, 12:38 PM #26
Cezar Cezar is offline
Cezar is on a distinguished road
The $60 amazon unit works.
HOWTO:
To open hatch: disconnect battery and hit a dome light to kill charge. Then, reconnect battery, hit unlock on remote twice, and then open hatch.
Then, pop cover off grab handle rope and undo 10mm nut, then using a trim tool pop clips along bottom of large interior panel, once bottom is all loose, slide upwards and remove. Set aside. Remove vapor barrier.
Carefully remove black plastic cover from latch face. There are clips top and bottom. Undo 10mm nuts on face of latch and single nut on inside holding on mechanism, then unclip connector, loosen grommet and remove unit. If you break the clips on the latch face cover you can re-attach it with silicone but I highly recommend being careful with removal.
Installation is reverse of removal. For vapor barrier I just cut a piece of plastic from a discarded package and attached with silicone, then applied and trimmed with a utility knife.
SPECULATION:
I believe whoever designed this unit built it in such a way that the control unit measures the motor resistance and if it's too high (like a rusty mechanism), disables it to protect the motor. This is why disconnecting the battery works--it resets the monitoring.
Cezar is offline   Reply With QuoteReply With Quote
Old 03-02-2023, 10:28 PM #27
depjr depjr is offline
depjr is on a distinguished road
This same thing happened to my dads 2005 4runner, all that you have to do is pull the ECU 10 fuse out for 10 second and put it back in. this we allow it to open again.
Or unplug the battery ground for 10 seconds then reconnect.
depjr is offline   Reply With QuoteReply With Quote
1998 4Runner. Rear hatch dead. No wiper, no power window, license plate lights, etc.. tgreathead 3rd gen T4Rs 24 01-23-2023 02:19 PM
HELP: How do I manually open my 2003 4Runner Trunk? rmajoran 4th Gen T4Rs 21 08-13-2020 01:31 PM
'03 4Runner Back Door Problems Toy-Man Problems & Warranty Issues 3 02-17-2011 08:58 PM
new hatch lock on '04 4runner not working bullitt774 4th Gen T4Rs 0 09-21-2010 03:15 PM
