Just a thought, but did you install the small metal slider clips that fit in the slots in the caliper that the upper and lower tabs on the pads fit into? These clips are 'spring' loaded to help keep the pads from moving vertically with the disk rotation, but still allow the pads to move in and out as the caliper pistons apply and relax. If they are not in place, I could see the pads making noise as they shift with the rotor movement.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
