12-04-2014, 08:55 PM
LED Bulbs for Rear Back up light?
Has anyone put in a good set of LED bulbs and seen noticeable results in light output out of their reverse lights? Drive a 2007 so have the newer housing, and I'm not interested in retrofitting any aftermarket housing or separate light source, as I don't need anything crazy bright. The price is right at $40 or so for a quality LED bulb pair, and if I could get a bit more light, I'd indulge.
Have done full interior LED Swap and HID for front lights...LOVE it. My hobbies have me up before and after the sun rises/sets so I prioritize good light output. 20% tint doesn't help either when trying to back out of a dark place at night.
12-04-2014, 09:20 PM
Real Name: Matt
Real Name: Matt
I have some 5W LEDs that I got from
@ Whitebeauty
but he sells 9W now. They're a pretty big improvement
Factory on left (hard to tell because the LED is so much brighter) and LED on right
LED in both sides
12-04-2014, 09:44 PM
Forget the leds for reverse lights, I use 15w hid kit there and it was brighter.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
12-04-2014, 10:07 PM
Real Name: Tony
Real Name: Tony
O.o Where's the write-up for that???
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
12-04-2014, 10:10 PM
Shiiit...I've got an 04 with the early style, non LED housings. I swapped in some LED bulbs from Amazon. I don't know if they fit your 06+ housing or not, but for the price (under $10 for the pair IIRC) it was a vast improvement over the stock incandescent bulbs, and as you requested not too bright. Plug and play, T10 bulb I believe.
Here's the link if you're interested though.
2004 SR5 V8 4WD White - Full LED Swap - Pioneer BT Stereo - Lite Racing UCAs - Toytec Bilstein 5100 Front 3"
Superflex Rear 2"- Spidertrax 1.5" - 255/75r17 Destination AT - SS Brake Lines - Prothane Bushings - SE Brake Upgrade - Full Synthetic
1994 SR5 V6 4WD Black - Bilstein HDs - OME 900 - 31" Destination AT
12-04-2014, 10:14 PM
Thank you
@ gaterose
for the photos.... Looks good enough for me, I couldn't see s**t backing into my parking spot moments ago.... Gonna track a pair down now!
12-04-2014, 10:45 PM
i mounted trailer lights under my bumper
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
12-05-2014, 01:34 AM
Here you guys go, it's a old pic but everything still work. Tho it cost about 70 off eBay for the kit, it's brighter for me since I have dark tinted Windows.
12-05-2014, 01:53 AM
Real Name: Andre Campos
Careful with the amazon LED's I ordered some with poor results. I am going to get more at a higher price point. In hopes of a brighter light with better quality
95' runner sr5
ES bushings
VAFM enlargement
"get busy living or get busy dieing"
12-05-2014, 06:36 PM
2017 Nightfall Mica GX460 Luxury
VLEDs: Highbeam H9 MicroEvolution 3500lm | Reverse | Spidertrax | AFE Pro Dry S
2006 Nautical Blue Metallic Limited V8 w/ XREAS - Retired
12-05-2014, 06:52 PM
THIS. Did the exact same thing with a single dually and just made a trailer wired it to the trailer plug. Works great!
-2013 T4R SR5-MYSALSA-KO2's
-(SOLD)2006 T4R SR5. Nautical Blue Metallic. 255/70/17 General AT2. LED Interior Swap. Toytec Ultimate 3inch lift/Icon 2.0s Rear, SHROCKWORKS Front Bumper, OEM FJ wheels, WM Roofrack, slowly working it up. My Build thread HERE
-(SOLD)2005 Subaru Impreza WRX STi. BMW Mica Blue paint job. Cobb stage 2 tuning. Other modifications.
12-05-2014, 07:35 PM
12-05-2014, 07:37 PM
same way i did it. i also have a 4 pin harness on mine. i went with dot lights so i didnt have to take them off for inspection. stupid va laws
12-05-2014, 11:30 PM
Originally Posted by 33plus1
Which ones did you buy? I like the output you got from yours
12-05-2014, 11:32 PM
Real Name: 660hp/488tq Evo X
Originally Posted by WI_4Runner
Thank you
@ gaterose
Got one that's even more powerful now... 11w... Alot of new things have come out that are mad wicked bright...
@ gaterose
thanks for the mention.
OP I can get you squared away just Lmk. Thanks.
Need lights???...Text me @ 3054239215
IG: @CREVOZ_X
