Old 11-28-2020, 04:32 AM #16
mysticz's Avatar
mysticz mysticz is offline
mysticz has a spectacular aura about mysticz has a spectacular aura about
mysticz's Avatar
This might help.
If you can grab the wheel (on jacks) and move it from 12 o'clock to six o'clock and also 3 to nine then you need new wheel bearings.
2005 T4R Silver SR5 V6 4wd with Mods.
mysticz is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 06:36 AM #17
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Originally Posted by KwonRunner View Post
Video of the noise
That doesn't sound like any wheel bearing I've ever heard. I usually describe a wheel bearing noise as a growling rather than a grinding. You're probably gonna need to put it on a lift to find that noise. As loud as it is it should be fairly easy to find from underneath. Possibly something cv axle related. Good luck.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 09:03 AM #18
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Have it checked out by a professional mechanic with a lift. If it is a front-wheel bearing buy the whole assembly not just the bearing. Replacing the bearing can take hours of mechanic time. Been there done that.Amazon.com: FKG 515040 (4WD Only) Front Wheel Bearing Wheel Hub Assembly fit for 10-16 Lexus GX460, 2003-2016 Toyota 4Runner, 03-09 Lexus GX470, 07-14 Toyota FJ Cruiser, 05-14 Toyota Tacoma, 6 Lugs With kit: Automotive
Captsolo is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 12:06 PM #19
montijo505's Avatar
montijo505's Avatar
Video of the noise
There's no way that is a wheel bearing, wheel bearing makes a grinding or howling noise. That loud clacking noise is likely the cv axle, sounds particularly bad under articulation entering that slight incline. Grab the shaft and move it side to side, if it has play it needs replacing.
Sent from my SM-G986U using Tapatalk
Old 11-28-2020, 01:43 PM #20
mysticz's Avatar
mysticz's Avatar
Sounds like maybe tire is hitting the wheel well or the body mount?
What kind of setup do you have? suspension, bl, bmc, tires and etc.
Old 11-28-2020, 02:28 PM #21
KwonRunner's Avatar
KwonRunner KwonRunner is offline
KwonRunner is on a distinguished road
KwonRunner's Avatar
Love this forum.
Good guess, but I don't think so. I've had my setup for a while and have been using it on and offroad with nothing like this happening. I remember the sound of tires rubbing my body mount back before I got it chopped and it's nothing like this clacking. I have ~3" in the front with coilovers, UCA, front bumper, bmc, 285/75/17s, 0 offset wheels. Thinking it's CV axles given what I'm reading about problems with non-OEM ones offroad, especially when articulated. It's definitely taken some abuse on the trails.
Taking it in to the local shop next Tuesday.
2008 V6 Sport Edition 4wd
KwonRunner is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 03:05 PM #22
RemyRunner RemyRunner is offline
RemyRunner is on a distinguished road
Resurrected.
Getting a loud grinding noise when making a slow rolling sharp right turn that sounds like it's coming from the drivers side front tire area. No noises when making a left turn.
Thought it might be the steering stops, so I greased those up, but still getting the noise. Thinking it might be the wheel bearings.
Any input or advice as to what it could be would be appreciated?
Jack up the front end and with hands at 12 and 6, see if there is any movement in the wheels.
If so, probably the bearing(s). I had this on my drivers front that was progressively getting louder over the last couple of months (338000 kms on the truck so definitely time to change) Ordered two new complete assemblies for about $400 CAD and just replaced both this past weekend.
Very straightforward job. Driver's side took about 2.5 hours, making sure I was not forgetting any steps. Passenger took about an hour.
Some will same to get new bearings and get them pressed in but that seemed too much of a hassle, considering that the assemblies are plug and play.
RemyRunner is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 04:25 PM #23
My bad....I didn't see the video before I responded...no, not a bearing issue. CV...I will see myself out.
Old 12-09-2020, 12:22 AM #24
KwonRunner's Avatar
KwonRunner's Avatar
Just wanted to update the community.
Good news. That terrible noise was not coming from the front nor the cv axles, but the rear of the vehicle. Turns out a carriage bolt on my fuel skid was backwards and making contact with the drive shaft when flexed.
PSA for those with RCI fuel skids: make sure your carriage bolts are installed the right way.
Thanks again for everyone's help in trying to figure this thing out.
Old 12-09-2020, 08:11 AM #25
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Grinding sound coming from the front end when turning is most likely a bent brake dust shield. When you turn under load, the rotor leans just enough to rub, but not when rolling straight. Crawl under there and bend it away from the rotor. And that will fix it.
But since its coming from the drive shaft at the rear of the truck, you can disregard the above.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Weird Sound.. Can You Diagnose? Brian757 3rd gen T4Rs 36 03-20-2013 07:54 PM
Help me diagnose this sound... masphx 3rd gen T4Rs 4 11-04-2011 04:07 PM
Help me diagnose this sound 99yota4 3rd gen T4Rs 6 12-18-2010 04:09 PM
grinding noise when turning cjm5027 Problems & Warranty Issues 1 06-26-2007 12:25 AM
Grinding sound when turning subzero Problems & Warranty Issues 4 02-08-2007 01:58 AM
