12-22-2014, 08:45 AM
Best Aftermarket Exhaust
Hey Crew
Long time no see.
My 2008 SE V8 has been having some rattles, and I fear that the New England winters have reeked havoc on the undercarriage and the exhaust system is on its way out.
My mechanic says Toyota's exhausts are "from the cat back" and cost a pretty penny. Id rather replace with something that sounds better, while not worrying about failing an inspection.
Any thoughts?
2003 Sport Edition V8 (sold)
2008 Sport Edition V8 (sold)
2016 Trail - Classic Silver Metallic - 17" Black TRD Wheels w/ BFG All-Terrains
12-22-2014, 08:58 AM
I still have the original on my 05 with over 270k miles here in NH.
The OEM replacement muffler is stainless. Most aftermarket are galvanized steel, so should be a lot cheaper.
As for brand...not sure there is just one too choose from. Flowmaster or Walker seem to be big around here.
12-22-2014, 09:42 AM
Thanks Mike.
Is it true that if I have to replace a rattling muffler that I would have to replace the cat too?
12-22-2014, 10:43 AM
Sounds like you're not sure what's rattling... Chances are it's not the actual exhaust... Probably a heat shield or hangar rotted away.... I'm partial to borla for the actual muffler... Stainless one from Jegs costs $161, weld it in and you're good to go.
Current: 17' GX460 Luxury with DSP, Nightfall Mica / Black
Sold: 05' 4R Sport v6, 07 4R Limited v6
12-22-2014, 10:47 AM
I replaced my exhaust on an 04 V8 with a cat back stainless system from Gibson. It gives the truck a nice rumble but is not loud. It is also very reasonably priced and many others here are happy with the Gibson stainless as well. They make a non stainless version for a little less money but when it comes to exhaust in New England- I would recommend the stainless.
12-22-2014, 11:24 AM
+1 on the Gibson CBE..
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
12-22-2014, 11:31 AM
Real Name: Brian
Real Name: Brian
Toyota actually makes a nice stainless. its there TRD version. Sounds great. Not a huge fan of the chrome at the end but the sound is nice. It will connect at your Y pipes. Basically will be half your exhaust replaced with stainless. Otherwise you will need to replace your Y pipes which cost some $$$$$ since they have the catalytic converters in them. I have not found anyone that makes those in stainless. My guess is you will need to go to a shop to get that done...that is if you want to pass inspections.
But I am with NuclearN8 most likely a heat shield that is rattling. Mine did the same thing. Just need to get underneath the car and take a look. I just got some bigger washers and tightend that thing back on. Then of course about a couple of months later went wheeling and the back half of my exhaust rusted through on a trail ride...thus the new TRD stainless exhaust
My Build Thread
12-22-2014, 12:46 PM
You said the mechanic told you that you needed a cat-back system...that means everything ]back of the cat....so the cat doesn't need replacing.
12-22-2014, 06:40 PM
Real Name: Ethan
Real Name: Ethan
+3 for gibson, excellent quality, very nice sound.
A lot of stuff I didn't need...
My Build
Originally Posted by kfitz77555
oh my god the erection I have from this thread is unreal.
12-23-2014, 12:48 AM
Check the heat shields attached to the body above the exhaust pipes as well as the heat shields ON the cats.
1999 BMW M3 coupe(E36) & 2005 V8 sport 4X4 black: ARB bull bar with 4 hella 500s,backup camera in spoiler,VSC off, springs:Tacoma w/ toytec(1/2"Fr) & FJ w/ daystar(1.5"R) spacers,Bora .75" front & Spidertrax 1.25" rear spacers,swaybar bushings upgrade,Stoptech rotors,SS brake lines,RCI Metalworks skids (front, trans.,transfer), Volant CAI,DT shorties w/ Dirty Deeds exhaust,fully soundproofed,Rostra seat heaters,HID (lows),HIR (highs),running board lights (added),aux reverse lights,2006+ tail lights,rear fog mod (tail, brake, directional OR rear fogs),Scion T1819,LED int. lights, key reminder diabled, Land cruiser steering wheel,rear window dog barrier, vent visors, Ultraguage, Enkei Deep Six 20" wheels for summer, factory sport wheels with A/Ts, FJ cruiser wheels with winter tires
12-23-2014, 05:31 AM
Real Name: Dan
Real Name: Dan
I went with the non-stainless Gibson exhaust. I purposely did not install the final 2 foot extension which runs out the back. In my opinion, a much cleaner look. The tip of the exhaust is still rear the differential, but is not visible.
The sound is a deep gurgle at idle, but not loud. There is an audible drone at cruise speeds, but it's not annoying. If anything it's a very complimentary sound to the look of the vehicle. A head or two will swing to see if it's really your 4runner.
Dan Mock / 2004 Sport Edition / 4.7L V8
2010 Hyundai Santa Fe GLS / 2009 Lexus IS 250 AWD (sold) / 2006 Scion tC (sold) / 1991 Honda Accord EX (stolen)
12-23-2014, 05:35 AM
Real Name: Dan
Real Name: Dan
another shot
12-23-2014, 12:16 PM
Real Name: Patrick
Real Name: Patrick
Originally Posted by Minn3sota
another shot
Do you get any exhaust fumes inside the cabin? This would be my biggest concern...
I just ordered the stainless version, but since I'll be using a cargo carrier on the rear hitch, I'll have the exhaust shop up the road weld on a new piece to exit just behind the RR tire.
2004 2WD 4PreRunner Build Page | OME Nitros | OME 885/895E | K&N AirCharger | Gibson Stainless Exhaust | ES Sway Bar Bushings | Goodyear Wrangler DuraTrac 255/75 R17 115S SL | CBI Ditch Light Brackets | Hella 500 Fog's
2003 Infiniti G35 w/Stillen goodies (we've put over 180k miles and still running strong, my wife's DD)
2012 Harley Road King w/goodies (put on almost 10k since getting new)
12-24-2014, 07:56 PM
Put a "down cut" tip on the end of the tail pipe to insure you do not get the fumes inside the passenger compartment....
06 4Runner Limited V8, 05 Tundra Stepside
16 Audi A8L, 13 Audi S5 Convertible
Family comes first....nice cars a close second!
12-25-2014, 06:08 PM
Gibson all the way.
I originally went with a Magnaflow 22 inch muffler, but it was barely noticeable over the stock exhaust. I then swapped in an 11 inch muffler which sounded mean around town, but produced so much drone on the freeway. Once I switched to the Gibson, I seriously wondered by I didn't go with that option from the beginning.
Get a Gibson. It seriously the best sounding exhaust I've heard on a V8 4runner.
