Old 12-26-2014, 06:57 PM #1
moloss moloss is offline
moloss is on a distinguished road
synthetic oil change interval v8
I have a 2004 4runner with a v8 and 145,xxx miles my wife has an 2006 sequoia with 59,xxx miles.....i've decided to switch them both over to full synthetic motor oil....that said I have several friends who use full synthetic and only change their oil every 10k miles.....their oil analysis says the oil is good at 10k.....do any of y'all see any problems going 10k between oil changes.....any and all opinions are wanted and thank you....Chris
moloss is offline   Reply With QuoteReply With Quote
Old 12-26-2014, 07:20 PM #2
kry226 kry226 is offline
kry226 is an unknown quantity at this point
I think you'll be fine with 10K OCI under normal driving conditions. If you happen to tow a lot or heavy, I'd probably reduce that interval a bit. You could also look at replacing the oil filter at 5k. Either way, I think you'll be good to go.
2004 SR5 V8 4Runner 4WD
kry226 is offline   Reply With QuoteReply With Quote
Old 12-26-2014, 07:32 PM #3
hikenbike's Avatar
hikenbike hikenbike is offline
hikenbike is on a distinguished road
hikenbike's Avatar
I change at around 8k but I'd have no concerns about going a bit higher. Been using Mobil 1 0w-30.
2019 Subaru Outback Limited 3.6 - Silver (replaced 2016 Trail Premium w/KDSS)
2007 V8 Sport 4Runner - Magnetic Gray
"A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty" - Winston Churchill
hikenbike is offline   Reply With QuoteReply With Quote
Old 12-26-2014, 09:14 PM #4
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
Im using Amsoil and change every 10k. Ill be upgrading to the 25k change and oil from Amsoil once this one is done.
LTDSC is offline   Reply With QuoteReply With Quote
Old 12-26-2014, 09:32 PM #5
rinkman07's Avatar
rinkman07 rinkman07 is offline
rinkman07 is on a distinguished road
rinkman07's Avatar
Drop synthetic in both then change it at 5k and do a blackstone labs analysis at the same time. Should tell you a lot about oil change intervals for YOUR vehicle and what's recommended for YOUR driving habits. That is what I would do anyway.
Mark
2005 (SR5-V8) | WKO Sliders |
rinkman07 is offline   Reply With QuoteReply With Quote
Old 12-26-2014, 11:00 PM #6
28.'s Avatar
28. 28. is offline
28. is on a distinguished road
28. 28. is offline
28.'s Avatar
I do mine in spring and autumn.. Mobil 1 with Wix filters...
04 4runner Sport Edition V8 4WD // X-REAS removed // Bilstein 5100s // Fj Cruiser coils // Interior LEDs // gshadow325 12V charger mod // Undercarriage LEDs // Back-up lighting // onboard 12v air compressor // 255/75/17 Duratracs // Homemade load bars // Smittybilt roof rack(when needed)
2016 T4R Trail Edition
2017 Civic Si
28. is offline   Reply With QuoteReply With Quote
Old 12-26-2014, 11:58 PM #7
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
My Honda only needed a filter every other change with regular oil (so about every 10-12k miles). A good filter should be fine for the whole time. You could consider a larger filter if you think you need more filtration.
m85476585 is offline   Reply With QuoteReply With Quote
Old 12-27-2014, 08:21 AM #8
Thank y'all so much......by my calculations synthetic should actually be cheaper in the long run while using a much better product.....sounds like a win win to me ☺
Old 12-27-2014, 11:21 AM #9
me_rikey's Avatar
me_rikey me_rikey is offline
Real Name: Jake
me_rikey is on a distinguished road
me_rikey's Avatar
Real Name: Jake
I change my 4R when the light comes on which I believe is a ~7,500mi interval. I also do a 5 wheel rotation then, and lube the drive shaft. I'm sure I could go longer, but it's inexpensive insurance.
2016 Jeep WK2 Hemi H/A
me_rikey is offline   Reply With QuoteReply With Quote
Old 12-27-2014, 02:49 PM #10
Neumonic Neumonic is offline
Neumonic is on a distinguished road
Originally Posted by rinkman07 View Post
Drop synthetic in both then change it at 5k and do a blackstone labs analysis at the same time. Should tell you a lot about oil change intervals for YOUR vehicle and what's recommended for YOUR driving habits. That is what I would do anyway. Mark
Some sound advice right here!
I like your system, if or when I get new tires I will get 5 instead of 4 and adopt the same practice! I also change my oil when the maintenance light comes on ans run 5W30 full synthetic (whatever is on sale with a quality filter)
Neumonic is offline   Reply With QuoteReply With Quote
Old 12-27-2014, 05:32 PM #11
MikeInNH MikeInNH is offline
MikeInNH is on a distinguished road
I want to see the 300k engine that used the 10k oil change interval.
MikeInNH is offline   Reply With QuoteReply With Quote
Oil change interval after switch to synthetic? 46runner 4th Gen T4Rs 12 11-07-2014 06:14 PM
0W20 synthetic oil interval Okki 5th gen T4Rs 9 09-30-2013 09:13 AM
synthetic oil change interval bokmeipai Maintenance/Detailing 16 08-16-2011 12:47 PM
5th Gen Oil Change Interval 10K miles with Synthetic 0W-20 GMZ 5th gen T4Rs 15 10-15-2009 10:29 PM
Synthetic Gear Oil Change Interval? TeryT Maintenance/Detailing 9 12-30-2008 01:00 PM
