Old 12-28-2014, 10:01 AM #1
gbslater gbslater is offline
gbslater is on a distinguished road
2003 4Runner Won't Shift into OD
Most of the posts on won't shift into overdrive deal with cold fluid.
In my case the transmission shifts into OD just once, in fact if I turn the car off at a light then drive it will go into OD. But slowdown and the trans like normal down shifts back into L or 2 and won't go back into OD.
It will downshift on a steep hill then when you crest the hill it will shift back into OD. Then stop at a traffic light on a level surface and once you get back up to speed no OD.
I have unplugged the ECT by removing the fuse and it will manual shift thru 3 gears but not OD?
So it doesn't seem to be hyd since the transmission shifts normally after turning off the car. Doesn't seem like the temp sensor since the car is warm. There is no OD OFF code flashing on the dash.
Does anyone have another idea?
gbslater is online now Add to gbslater's Reputation Report Post
gbslater is offline   Reply With QuoteReply With Quote
Old 05-25-2024, 02:42 PM #2
J_Pav J_Pav is offline
J_Pav is on a distinguished road
I have this exact problem with my 2003 limited v8, your post is the only one Iíve found with the same problem. I know this post is years old but did you ever find a solution? I was thinking electrical as well because all I have to do is turn the car off then back on.
J_Pav is offline   Reply With QuoteReply With Quote
Old 05-26-2024, 12:20 AM #3
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
First, check the level and condition of the transmission fluid. Then, inspect the wiring connected to the transmission and its parts. And test the solenoids. A faulty solenoid could be causing the problem with your Overdrive.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-27-2024, 08:17 AM #4
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
my friends had an issue were it was getting stuck trying to shift into OD, change the fluid twice and hasn't had issues since.
daprotege5 is offline   Reply With QuoteReply With Quote
ect , overdrive , overdrive problem , shifting , transmission
2003 shift problem t4r4wd 4th Gen T4Rs 16 10-17-2018 07:17 PM
2003 4Runner Won't Shift into OD gbslater 3rd gen T4Rs 1 12-27-2014 08:14 PM
1-2 slow/sluggish Shift WOT A340E 2004 2WD V6 148K. Shift Solenoid? NCSCOTT 4th Gen T4Rs 1 04-22-2014 07:07 PM
2003 4wd v8 won't shift out of 3rd gear? alarka 4th Gen T4Rs 2 03-12-2012 07:42 PM
Code P0770-Shift Shift Solenoid E-Please help!! eric70412 3rd gen T4Rs 1 08-16-2010 01:31 AM
