Originally Posted by wnelax04sr5
this happened to me, i have a can obdII reader and it trips the codes. i can't remember if i needed to do a zero point calibration or i took it to a mechanic and had him reset it with the proper reader
Originally Posted by kacper
Thanks ! I'll wait for more suggestions
Ok alert!!
With my amazing mind I figured out how to clear Vsc lights with scanner
Ok so this is it instead of awaiting scan to be done..... once you notice the Vsc and abs lights start to blink a series of times turn engine off instead of allowing scan to complete test.
Trying to wait when it’s done and erasing codes won’t work you have to unplug and turn ignition off when Vsc and abs lights start blinking a series of blinks it doesn’t matter how many just as soon as you see them start blinking
Be sure to unplug the scanner from computer when you see Vsc and abs lights start blinking.... turn off ignition then with everything disconnected start up engine and test run your vehicle you shouldn’t have lights turn back on.
It’s so hard doing what some of those YouTube videos advise of and so I eventually did and noticed with my mechanical and technical mind of when it happens with computer and without computer this is the easiest and less complicated way to get it to work.
When you drive it to test it you’ll feel the difference in the drive that it’s fixed right away.
Hope that helps!
Success!!’
