Old 01-04-2015, 06:38 PM #1
hikenbike's Avatar
hikenbike hikenbike is offline
hikenbike is on a distinguished road
hikenbike's Avatar
Standard or thin wall socket for lug wrench?
A friend of mine had a flat today on his Jeep and we had a tough time finding pipe for more leverage to work with his lug wrench to loosen the lugs. We did find something but his crap wrench just bent and was basically useless.
To arm myself for future chores, i went online and found this....
http://www.amazon.com/Gorilla-Automo...productDetails
I have a stock 4Runner so do I get standard socket or thin wall socket? Don't know what thin wall socket is.
Anyone have experience with this Gorilla wrench?
Thanks
2019 Subaru Outback Limited 3.6 - Silver (replaced 2016 Trail Premium w/KDSS)
2007 V8 Sport 4Runner - Magnetic Gray
"A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty" - Winston Churchill
hikenbike is offline   Reply With QuoteReply With Quote
Old 01-04-2015, 06:46 PM #2
zopperman's Avatar
zopperman zopperman is offline
Moderator
Real Name: Zak
zopperman is on a distinguished road
Moderator
zopperman's Avatar
Real Name: Zak
Amazon.com: Gorilla Automotive 1721 Telescoping Power Wrench - Standard Socket: Automotive
Thanks
Standard should be fine, but I have something like this Ampro T29771 1/2-Inch Drive Standard Extendable Ratchet - Socket Wrenches - Amazon.com
that I got from harbor freight. It ratchets and is rated to like 400 ft lbs or something stupid. I keep that and a 1/2" socket set in the truck at all times.
zopperman is offline   Reply With QuoteReply With Quote
Old 01-04-2015, 07:12 PM #3
chitown40's Avatar
chitown40 chitown40 is offline
Real Name: Rob B.
chitown40 is on a distinguished road
chitown40's Avatar
Real Name: Rob B.
Standard socket will work fine. I have the same Gorilla wrench in standard size and it has worked flawlessly in all my Hondas and Toyotas.
2009 GX470 Sport Edition w/ KDSS
chitown40 is offline   Reply With QuoteReply With Quote
Old 01-04-2015, 07:25 PM #4
cpark_12's Avatar
cpark_12 cpark_12 is offline
Real Name: Chris
cpark_12 is on a distinguished road
cpark_12's Avatar
Real Name: Chris
This! I had one before I got my impact gun and it worked great. It will extend enough to give you pretty good leverage
2003 Sport Edition V8 4X4
TRD Taco coils Bilstein 5100 fronts,
MetalTech LT stage 2 kit w/ HD coils/Icon 2.0 shocks
2006+ Headlights 6000K HID
Level 8 MK6 LT285/70-17 Cooper ATP. Flowmaster 50 series
cpark_12 is offline   Reply With QuoteReply With Quote
Old 01-04-2015, 08:03 PM #5
hikenbike's Avatar
hikenbike's Avatar
Thanks for the suggestions and help. I just ordered this for my truck since I already have the 1/2 inch 13/16 socket......
http://www.amazon.com/Neiko-Heavy-Du...iko+heavy+duty
And I picked up the Gorilla power wrench with the thin sockets for my sons Mazda 6 which has a tighter recessed fit for the lugs.
Old 01-05-2015, 11:15 AM #6
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
A good 1/2" ratchet can withstand 800ft-lb or more. Ratchet-Handles Torture Test - Hot Rod Magazine (those are all cheap ones)
I skipped a tooth on my 3/8" ratchet trying to loosen a stuck suspension bolt. Luckily it looks like there was no damage. I'd rather have a good 1/2" ratchet and use my jack handle as a breaker bar than have a less useful fixed breaker bar (and still need the jack handle most of the time).
I think my impact sockets fit the lug nuts on my truck, and they are super thick walled. I don't have an impact wrench (yet), but I got them because they were cheaper than regular sockets. The thick wall does get in the way sometimes, but regular non-impact sockets are thinner, and they should be fine for almost anything.
m85476585 is offline   Reply With QuoteReply With Quote
Old 01-05-2015, 07:02 PM #7
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
i would get the thin wall. its more universal to use, since u can use it to help others and charge them for service.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 12-05-2021, 09:36 PM #8
[email protected] scor440@aol.com is offline
scor440@aol.com is on a distinguished road
I use a new tool called a torque wrench for lug nuts so I don’t have that problem try that it really does work!
scor440@aol.com is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 12:57 PM #9
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
a regular socket is fine for as long as the lug nuts are torqued properly. if it was tightened too much from a car shop, then you have a problem.
4r-4ever is offline   Reply With QuoteReply With Quote
Pic request: Method Standard / Double Standard Highlex 4th Gen T4Rs 6 08-12-2014 08:40 PM
Gear Wrench 8-19 mm Ratcheting Combination Wrench Set - Metric $30 nissanh 3rd gen T4Rs 4 09-20-2013 09:30 AM
add another 12v socket, tap into socket in trunk? matthewkristof Engines / Suspension / Wheels / Tires / Audio / Accessories 5 04-11-2012 04:22 PM
hello from thin thindundun New Members 0 10-11-2010 11:34 PM
what so you thin of this sdstud212001 Classic T4Rs 5 02-06-2006 10:37 PM
