Old 01-04-2015, 08:09 PM #1
mav2287 mav2287 is offline
mav2287 is on a distinguished road
avalon remote start on 4Runner
Does anyone know if the 08 Toyota Avalon remote start can be made to work on the 4runner? or if at least there is an equivalent for the 4runner to do the same? http://www.toyotapart.com/PT398-07081.pdf
2008 - 4runner V8 limited
mav2287 is offline   Reply With QuoteReply With Quote
Old 01-05-2015, 02:07 AM #2
netwon netwon is offline
netwon is on a distinguished road
Go aftermarket like Compustar. Way more features and it doesn't turn off when you open the door!
netwon is offline   Reply With QuoteReply With Quote
Old 01-05-2015, 07:35 AM #3
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
I agree with this opinion. Compustar is great.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 01-05-2015, 07:29 PM #4
Everything on this car is factory perfect and it is in MINT condition. That is why I want to keep it all as close to factory as possible which is why I won't use a system unless I can keep the factory fob. Not to almost every aftermarket fob I have used broke a lot easier than the stock ones. If anyone has anything that would help here I would really appreciate it.
My plan B was to use the avital 4003 with a bypass module and the factory key fob. The only issue I have with this is the stupid ECU on the 4runner disables the fob once the motor starts. This means when you remote start the car it locks and then won't let you unlock it. If I could find a way around that I would be golden!
Old 01-06-2015, 11:47 AM #5
Compustar. It locks and unlocks regardless of engine running or not. I am not sure what avital is but seriously there is a reason Compustar was Mercedes OEM remote start in North America.
I've had my fob since 2008 no problems.
Old 01-06-2015, 05:23 PM #6
I have looked at compustar, but it seems I can't use my OEM remote. The biggest deal for me is I want to keep the oem remote.
Old 01-06-2015, 05:48 PM #7
gshadow325 gshadow325 is offline
gshadow325 will become famous soon enough
who says you cant?
You can. You can have it setup to arm and disarm the compustar when you hit the oem fob to lock or unlock. you can have it setup to remote start via 3 lock pulses. un lock you will have to insert key or use something to unlock it like a EZ-go or drone mobile unit.
But yes it can be done. You are not talking to the right people.
here i am with a 2014 mini cooper using a oem keyfob. it can be done
https://www.facebook.com/video.php?v...type=3&theater
mercedes using the oem remote to remote start
one more mercedes just in case you missed the first one
you get the point now? LOL
@gm350reratliff one of the many reason i love compustar and dislike those snakes :P
gshadow325 is offline   Reply With QuoteReply With Quote
Old 01-06-2015, 07:55 PM #8
That is why I was thinking that the factory kit would be best. I would be able to remote start and unlock the car with the factory fob. The issue I have with the aftermarket kits is if I keep the factory remote once I start the car I can't use it to unlock the car and get in. The car lives outside so if I need the remote start it is because the car is covered in ice/snow and the key would be a bad idea at that point.
Old 01-06-2015, 11:49 PM #9
chitown40's Avatar
chitown40 chitown40 is offline
Real Name: Rob B.
chitown40 is on a distinguished road
chitown40's Avatar
Real Name: Rob B.
Why are you so hung up on the factory remote? The factory remote is garbage and has a horrible range. An aftermarket DEI remote start will give you more options, has a better range and works as well or better. Plus it's more easily programmed than factory.
You can always stash the factory remote away until you sell the truck. Then it will still be perfect. The OEM fob will always work even with an aftermarket unit installed.
2009 GX470 Sport Edition w/ KDSS
chitown40 is offline   Reply With QuoteReply With Quote
Old 01-08-2015, 10:36 AM #10
when i got the email with the OP's reply i said WTF SMH OMG...why? thanks @chitown40 for reading my mind
Old 01-08-2015, 01:08 PM #11
chitown40's Avatar
Real Name: Rob B.
chitown40's Avatar
Real Name: Rob B.
Anytime @gshadow325 .
I get why he wants to keep it all stock. Some people have the OCD worse than others.
Toyota does many things well, but unfortunately making good-ranged, feature-rich remote starter modules is not one of them.
Old 01-08-2015, 04:15 PM #12
well remote start on a 4th gen was not in toyotas design plan. so aftermarket is necessary. in the newer 5th gen it was part of the design. YET the OEM remote starter SUCKS! aftermarket kicks it butt all day long.
I litterally just did a 2011 lexus es350 2 minutes ago using the OEM fob, real neat, real cool how it works. Now that vehicle the OEM remote works for both locking and unlocking after its started.
video... @ 6pm lol
Old 01-12-2015, 09:59 PM #13
Was that with an aftermarket or factory remote start? Is there anyway to do it on 4th gen?
FOR SALE: 1995 4Runner SR5 V6 4X4 / 4WD w/ remote start icdawg Classic T4Rs 2 12-29-2011 02:52 PM
Installing a Remote Start on a '99 Toyota 4Runner maverick906 3rd gen T4Rs 22 11-16-2009 09:23 PM
Remote Start or Security + Remote Start dheeter 4th Gen T4Rs 3 12-29-2008 05:49 PM
Remote Keyless Start from Toyota for 07 4runner osxcode General Discussions 5 05-18-2008 09:47 AM
2006 4Runner SR5 remote start w/factory remote?? brantatchison Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-04-2006 12:18 PM
