10-05-2017, 09:38 AM
#46
Originally Posted by DCameraMan
I originally planned to put my tent on the stock bars, and decided to build custom cross bars that I knew would be strong enough. This was all until I took the original cross bars off and learned that the stock rails are mounted to the vehicle with PLATIC. There was not a single chance I’d drive down the road, let alone off road, with a 130 lbs tent bouncing around on plastic. I have the sport, people said the roof mount was aluminum with a plastic cover.. nope all plastic
https://youtu.be/Ie4li7Rir7c
Nice idea and execution. I've heard the "Sport" parts are a bit different. I also make a roof rack that slides between the factory rails (60lb rack), and I'm able to jump my 180lbs body weight on it, with no issue. The factory feet ends look beefy enough, for the square aluminum style rails.
-2005 4Runner Limited V8 AWD - Toytec Boss Suspension, SPC UCAs, 285/70/17 Level 8 MK Wheels (17x8, -10), Tandem Rock Sliders
-1998 LX470 (Stock)
www.KeenanOffroadFab.com
10-05-2017, 09:41 AM
#47
Originally Posted by villaphoto
Got anymore photos of these? I just threw down for a set of adapters for my Thule Bars that I had laying around... but now you have me thinking...
I can send you all the photos I have, message me and I'll get you my email address and we can share. I'm not setup to advertise on here, but I believe my kit is much cheaper than the Thule set that clips to the factory side rails. Thanks for the inquiry!
-1998 LX470 (Stock)
10-05-2017, 11:30 AM
#48
Thanks. The parts are different, but apparently the Sport rack is stronger than the sr5/limited. Freaks me out even more lol I was actually never worried about sleeping up there. Static weight is much easier to handle. But drive down the road, hitting bumps and whatnot, I couldn't trust it, even with steel cross bars. I'd love to see your rack though! Does it bolt to the roof or to the factory rails?
2006 Sport v6 4x4
Videography | Photography | Guitar | Drums | Rollerblading | Road tripping | T4R
10-05-2017, 04:36 PM
#49
Hmmm, I'll have to jump on a sport rack when I see one! The tent I use is the basic 2 man Chinese tent (48x56) and weights around 100lbs. I don't have any worry about the tent riding on the my steel load bars, but since you bring it up.... I will set my gopro up there next time I have tent on the truck and see what the deflection is offroad. Going to big bend later this month, so that will be a good torture test. I will DM you some info about roof racks. Thanks.
-1998 LX470 (Stock)
10-05-2017, 06:48 PM
#50
Real Name: Newell
Real Name: Newell
I haven't had the chance to look at this with a Sport rack with the round bars. Does anyone know what material the Sport Rack rails are made out of?
I sell the whole setup, the hardware needed to mount the load bars, and the load bars (for square style side rails only, I'm unsure if this fits the rounds Sport Rails).
I'm pretty sure the rails are extruded aluminum and the footings are some type of nylon. I would imagine the internal track size would be the same for interchangeability but there could be a slight difference in the gap spacing. what is the length (width) of your setup?
10-06-2017, 02:02 PM
#51
That is my guess, probably a slight difference of the inside to inside measurement between the rails. If anyone with a round bar sport rack needs a product, I'm sure I can execute it, but would need to be pretty close on inside to inside measurement, and then I can make the mounting holes a smidge bigger for tolerance.
-1998 LX470 (Stock)
10-07-2017, 03:52 PM
#52
I'd be interested to see how it turns out! I have a sport rack for sale since I've made a custom rack. What part of the US you in?
2006 Sport v6 4x4
06-13-2018, 12:09 PM
#53
Factory Roof Rack
I'm debating just buying 1" x 3" 80/20 T-Slotted cross bars, which are pretty much what are used on Prinsu Design and FR roof racks, and just attaching them to the my 2007 Limited factory side rails. They should be stronger than the factory cross bars and the factory side rails seem to be beefy enough to hold a lot of weight.
The side rails have to be just as strong or stronger than the 1/4" aluminum side rails I see that come with $1000 roof racks.
Anyone try this or have any specs on how much the side rails are rated for (not the cross bars)?
06-30-2018, 06:19 PM
#54
I just started making these RTT Load Bars for 4th Gen (not sure if they fit the round Sport Rack). Very sturdy and an option if you don't want to set the RTT on the factory rail. Comes powder coated with every thing you need (minus the RTT and the nuts and bolts that come with RTT). I'm not sure if I need to be setup as a vendor on here, but message me if anyone interested.
Attachment 269350
Attachment 269351
I just put in an order for these! They seem like a great product. I was never asked to provide my email for confirmation however..
06-30-2018, 06:28 PM
#55
Also check out LFD offroad. They make awesome cross bars that bolt to the factory rails.
LFD Off Road - Home
07-01-2018, 06:10 PM
#56
Email Jeremy directly if you need too. I picked up a set of his rails a few months ago and they work great.
07-06-2018, 10:23 AM
#57
This might sound stupid but...
I love the idea of a RTT, but I'm paranoid. I grew up with a dad who told me sitting on top of my first car (a Ford Explorer) would make the roof leak. Probably just an old wives tale, so to speak, but now I'm worried about all the weight of a RTT up there.
Anyone got any pearls of wisdom to put my mind at ease?
07-06-2018, 12:21 PM
#58
Real Name: Sam
Real Name: Sam
Ive jumped mine many times and offroaded hard trails with it on top. Zero leaks.
Bunk Myth
07-11-2018, 10:56 PM
#59
Sorry I missed your original message, I don't check this forum very often. We have you all sorted out and in the mail. Thanks again! Best way to reach me is inquiry through the website which directs to my email.
-1998 LX470 (Stock)
07-11-2018, 11:02 PM
#60
LFD Off Road - Home
LFD definetly makes a nice cross bar setup. I believe they come predrilled with several holes for mounting other items. The cross bars I make are explicitly for roof top tents, and the mounts I use are modular to the roof racks I make.
-1998 LX470 (Stock)
