Originally Posted by therhythmic
Did you mount using the factory crossbars or literally mount to the factory side rails?
I have a roofnest Condor and trying to figure if I need to buy ruggedized crossbars or if I can use the factory crossbars.
Thanks,
J
The tent is mounted directly to the factory roof rails. The factory roof rails are quite sturdy, but the factory crossbars are not. The tent's mounting rails, which are designed to support the entire tent plus occupants, essentially become heavy duty crossbars
The mounting rails on my tent (CVT Mt. Shasta) can be installed front to back, which would require crossbars, or side to side, which allows for mounting directly to the factory roof rails like I did. I'm not sure if your tent's rails can be mounted side to side.
