Old 01-12-2015, 09:40 PM #1
Tooltime19 Tooltime19 is offline
Tooltime19 is on a distinguished road
Long Travel
Who makes the best Long Wheel Travel system for the fourth gen 4x4's? Im looking for as much wheel travel as possible and still have the 4x4 working as normal. My current setup works fine, but I want more.
Bilstein 5100's on all four, Eibach/Toytec front coils, OME rear coils, RCI skid plates, 1.25/1.5 wheel spacers front/rear 275/70/17 BFG A/T KO2's, drop in K&N, Cobra CB, Powerslot Slotted Rotors, Hawk HPS pads and Mobile-1 Lubricants throughout.
Tooltime19 is offline   Reply With QuoteReply With Quote
Old 01-12-2015, 10:09 PM #2
lipek's Avatar
lipek lipek is offline
lipek is on a distinguished road
lipek's Avatar
Total Chaos +3.5"
Instagram : Dirtbagtravels
TLCA#22115
hodor's build
lipek is offline   Reply With QuoteReply With Quote
Old 01-12-2015, 10:11 PM #3
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
On the boards, Total Chaos seems most popular but I think you're going to find differing opinions of what is the "best."
All Pro & Camburg also make LT kits for the 120 platform. There aren't a lot of members here running LT, it may be a good idea to include FJCruiserForum and TacomaWorld in your search for reviews since the platform is the same.
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 01-12-2015, 10:12 PM #4
Thanks for the quick reply. Do you know how much useable travel?
Old 01-12-2015, 10:29 PM #5
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
the Total Chaos 2" has 11.5" of travel with a 4" track width addition, 3" has 13." of travel w/4wd and a 7" track width addition.
Basically a pick your poison situation. Both lift 3-4"
LTDSC is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 03:03 AM #6
Troymclure's Avatar
Troymclure Troymclure is offline
Real Name: Jake
Troymclure is on a distinguished road
Troymclure's Avatar
Real Name: Jake
If you want some serious travel, wait for DTF's new kit for the tacoma and therefore our 4runners. 4x4, fully fabbed spindle, 18"ish of wheel travel, and +6" each side for 12" additional track width. That will be the most travel using bolt on parts, but isn't out yet and is most likely the most expensive.
If not, go with Camburg or Total Chaos +3.5" kit
Troymclure is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 12:23 PM #7
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
i just wish someone would ****ing make a lift spindle for 4x 4runners. Its all i need.
Old 01-13-2015, 12:28 PM #8
wkeryder4's Avatar
wkeryder4 wkeryder4 is offline
Real Name: Will
wkeryder4 is on a distinguished road
wkeryder4's Avatar
Real Name: Will
Wouldn't you start running into issues with the CV angles? I figured those would the limiting factor.
2007 Sport Edition 4WD - Build Thread
wkeryder4 is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 12:30 PM #9
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
GM, ford and Dodge all have aftermarket lift spindles for stock set ups. i ran them on my last truck. They have a spacer that pushes out the CV to meet spindle hub. The hub and whatnot stays the same, its an extended top that makes the lift.
EDIT: maybe the way toyota has their LCA BJ location causes the issue.
Old 01-13-2015, 02:51 PM #10
Nyc-Runner's Avatar
Nyc-Runner Nyc-Runner is offline
Nyc-Runner is on a distinguished road
Nyc-Runner's Avatar
I've also been looking into long travel. I think in the future i'll be going with either the Total chaos or Camburg 2" LT set up. I think that will be more than enough for what i need and i also don't want to go too wide cause of the trails we run back east can get a little tight with all the trees etc. The thing you have to think about now is either running Glass works fenders or modifying/cutting the stock ones because your going to have a lot more up travel and depending on your tire size you will be hitting them if you keep the stock fenders. The issue i have now is i will have to have someone modify my bumper to match the Glass works fenders as they with be a couple inches wider on each side the same way that @The josh did with his.
What do you guess think about the rear though? I'd like to try to match up the stance a little bit to the front. I was thinking of running a set of sidertrax in the rear as a cheaper option at least to help widen it up..
[/SIZE]08 Urban Runner Dipped-Satoshi Grill,Icons,M LT,BAMF,RCI,Addicted Off Road Front bumper,4x4 Labs rear bumper,Warn M8000 w Spydura synth,FN Five Stars with 34" Goodyear kevlar Mtr's,4:56 Re gear with Rear FJ Elocker,Flow Master,Afe,and much much more..........
My Build >http://www.toyota-4runner.org/4th-ge...ld-thread.html
Nyc-Runner is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 03:04 PM #11
AARONR's Avatar
AARONR AARONR is offline
AARONR is on a distinguished road
AARONR's Avatar
The geometry and axle shaft are the issue for 4wd lift spindles.
I would buy Total Chaos again. I have their Gen 3 Race kit on my pick up. Top notch quality parts and service. They have done all the R&D on that chassis, you just buy the parts (from me ) and it will perform like a different truck!
06 4Runner V8 4WD
92 SR5 Pickup w/ bypasses and roll cage
AARONR is offline   Reply With QuoteReply With Quote
Old 01-13-2015, 03:50 PM #12
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
i dont think you will match the width of LT for the rear. Nor would i want to have that big of a spacer.
Old 01-13-2015, 03:59 PM #13
AARONR's Avatar
AARONR's Avatar
Currie makes a custom F9 housing for the FJ cruiser which is the same as 4runner rear axle. Custom width for Long travel
06 4Runner V8 4WD
Old 01-13-2015, 04:20 PM #14
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
if i only had $3500 to blow
Old 01-13-2015, 05:02 PM #15
Nyc-Runner's Avatar
Nyc-Runner's Avatar
Yeah of course it won't match it up perfectly but at least it will push it out 2.5" with spidertrax 1.25 on each side and the difference wouldn't be as drastic but yes would be nice to not have to run any spacers at all. I just thiunk the difference would would bother me a little..
I just looked it up and came up with $2300 haha still a nice chunk of change! I'm pretty sure @The josh is also running this it looks like a pretty sweet set up!
Going long travel on my '06...need some help saulty81 Off-Roading 9 06-25-2019 05:00 PM
Long Travel Suspension 3rd gen 4RUN0326 3rd gen T4Rs 38 01-23-2018 11:30 PM
Tie Rods With Long Travel? cbielat General Discussions 1 11-02-2014 09:12 PM
WTB Long Travel Kit for 3rd Gen 4Runner Spunk Want to Buy/Trade 1 10-01-2014 02:37 AM
Long Travel JamesDean91 3rd gen T4Rs 19 03-14-2013 08:53 PM
