looks to me a valve cover gasket too. just a suggestion when you replace the radiator, don't flush it, just refill it with toyota coolant. to get more coolant out of the radiator, blow it with air while the thermostat is removed. flushing it with water especially if it's not filtered, you'll just introduce more contaminant in there. water ratio will still be the same if you just refill it.
Originally Posted by fdbyrne
I'm not a professional by any means but that oil leak looks more like a bad valve cover gasket which isn't that big of a deal. Good luck.
