02-02-2015, 09:16 AM
Help - Total Chaos UCA
I have this crazy "creaking sound" ever since I had these installed. Is that normal?
02-02-2015, 09:23 AM
No,
Check the torque values and make sure they were not tightened excessively. Assuming all is good there, lube the uniball with triflow and the bushings with the proper lube for that application.
2006 Limited V8, Toytec Ultimate, Camburg UCA's, Demello Bumper, 255/80r17 BFG KM2s
02-02-2015, 10:52 AM
Real Name: Sam
Real Name: Sam
Originally Posted by kaizer427
No,
this. I'd imagine either the UCA bolts are over torqued, or were torqued with the weight not on the suspension. Its an easy solution. Just loosen the UCA bolts with the vehicle on the ground under its own weight and then torque to spec. Also id throw some triflow on the uniball anyway for good measure.
02-02-2015, 12:47 PM
great, thanks guys
02-02-2015, 01:37 PM
Real Name: Sang
Real Name: Sang
I'm positive the creaking noise is from the uniball, use teflon lube or triflow and spray down the uniball top and bottom and the noise will go away. The noise will come back, just spray again.
2003 GX470 Ash Blue Mica "Bianca" Blue Steel 2.0
Demello front bumper, Icon 2.5 ext. travel coilovers w/ reservoirs, Icon VS2.0 rear shocks, Ironman rear conversion kit, Toytec Superflex rear coils, Black Rhino Roku wheels, 295 Toyo RT, Flowmaster Super 10, Inno Shadow 13, Tuff Stuff awning, LenzDesign snorkel, RRW sliders, Outrider lower link mount skids, Depo Sport head lights, Rago Fab ditch brackets, KC G34 LED pods
02-03-2015, 08:58 AM
Time for another dumb question, can I do this while it's sitting on the ground. I'm not much of a mechanic, but I can see the top of the ball and I'm assuming I could spray underneath it as well.
02-03-2015, 03:12 PM
Real Name: Sang
Real Name: Sang
yup, I usually turn the wheels to get better access, wipe down the uniballs up top and under with a rag and spray both sides.
02-04-2015, 08:44 AM
Perfect, thanks
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Total Chaos
Desertrunner25 |
3rd gen T4Rs |
36 |
10-17-2015 06:49 PM |
total chaos
bullydog |
4th Gen T4Rs |
0 |
09-16-2012 08:08 PM |
total chaos uca
kjeisner |
3rd gen T4Rs |
1 |
03-13-2012 12:13 AM |
Total Chaos
ric |
Off-Roading |
7 |
10-29-2009 12:28 AM |
