Thread Tools Rating: Thread Rating: 5 votes, 3.80 average. Display Modes
Old 07-11-2014, 04:56 PM #31
norcal2 norcal2 is offline
norcal2 is on a distinguished road
2007 SE 4 x 2 170k no problems change antifreeze yearly with a drain and refill no total flush
norcal2 is offline   Reply With QuoteReply With Quote
Old 07-13-2014, 08:23 PM #32
Jeff S. Jeff S. is offline
Jeff S. is on a distinguished road
2004
(Will look it up and edit with info)
4X4
204,000
Number 4
Edit:
For what it's worth, 200k miles is about when the problem started. Haven't replaced them yet. Was quoted $3,000 to fix it, so am considering selling it. I'm now at 218,000 miles and it's still running. My mechanic told me to try a chemical head sealer before I buy a new car or drop thousands of dollars on my 4Runner. Didn't think it would work. I'm not holding my breath, and, knock on wood, but Bar's HG-1 seems to have elevated the symptoms of a blown head gasket in my truck, so I'm hopeful it may have actually worked.
Jeff S. is offline   Reply With QuoteReply With Quote
Old 08-11-2014, 07:32 PM #33
Fins_3 Fins_3 is offline
Fins_3 is on a distinguished road
Just saw the thread, here are my issues:
2004 V6
HG leak at @125,000
Same problems as other posters, rough start and misfire on cylinder 6. Coolant also fouled oxygen sensor. Total bill was around $1900 to replace the gasket, check the heads and replace the o2 sensor.
Other issues:
Leaking crank shaft seal due to improperly machined harmonic dampner. Took forever to trace and find the source of the leak. While replacing the seal I also found that the radiator was leaking. This was around 130000.
No other issues since.
Fins_3 is offline   Reply With QuoteReply With Quote
Old 08-15-2014, 02:54 PM #34
Proctor750 Proctor750 is offline
Proctor750 is on a distinguished road
Year: 2004
Production Date: 02/04
4x2
230,xxx
Cylinder # 6
I wonder if I could just torque that headbolt down a little more...
Proctor750 is offline   Reply With QuoteReply With Quote
Old 08-15-2014, 03:06 PM #35
hearno's Avatar
hearno hearno is offline
hearno is on a distinguished road
hearno's Avatar
2004 V6
HG leak at @125,000
That isn't a bad deal... who did the work?
2014 Trail
A mild build She gone... sad face.
2001 Limited 4x4
hearno is offline   Reply With QuoteReply With Quote
Old 08-15-2014, 05:41 PM #36
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
Updated:
*** V6 Head Gasket Action Request ***-screenshot_1-png
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
Old 08-15-2014, 07:16 PM #37
I called 800-331-4331 and sure enough no recall or anything, they just took my name down.
Here is my case# 1408152385,
Anyone who has had this issue even if it was years ago please call and mention my case number so we can get the wheels moving on a possible recall.
The rep did say if enough people called in that people who did the repairs previously could possibly be reimbursed. Please call.
Old 08-15-2014, 11:42 PM #38
cellzone77 cellzone77 is offline
cellzone77 is on a distinguished road
sr5 no additional options
I have 2003 sr5 v6 4x2 no options what so ever
120k miles all oem parts mobile full synthetic oil every 5k , never had a single issue
my neighbor has same model 2003 sr5 v6
regular oil (mobile10w30 extended performance) every 3 k
no water pump changed coolant flushed at 100k with toyota oem
220k miles and still running strong
my brother has 2004 v6 sr5 regular oil change 10w30 extended p
every 3k
180k miles still running strong, never had water pump replaced, simply
oil change and coolant flush at 100k.air filter changed at each oil change
sparkplug changed at 100k
i guess it all depends on the way you drive?
cellzone77 is offline   Reply With QuoteReply With Quote
Old 08-16-2014, 12:39 AM #39
morphious's Avatar
Real Name: John
morphious's Avatar
Real Name: John
So far not 1 03' is on the list. I wonder if something changed between 03' and 04'? Mine is an 04' but built and purchased in 03', all the others in the list (from info given) are 04's and 05's built in 04' and later. Interesting and I will keep updating the spreadsheet when I get people to post new info.
I am really curious about the build date which many are not posting.
Old 08-16-2014, 01:50 AM #40
MikeInNH MikeInNH is offline
MikeInNH is on a distinguished road
Too small of a sample to make any statistical conclusions.
MikeInNH is offline   Reply With QuoteReply With Quote
Old 08-16-2014, 02:08 AM #41
morphious's Avatar
Real Name: John
morphious's Avatar
Real Name: John
Hey Mr. Statistician;
I am only putting together some basic info from what people are posting. I am no where near trying to make a "statistical conclusion".
Just Sayin!
Old 08-16-2014, 06:48 AM #42
Just Sayin!
Hey Mr JumpToConclusion,
Never said you were. I was just pointing out that you CAN'T make any analysis about variances from one year to the next from this small sample. I think your stats is good and useful, just NOT when trying to make conclusions.
Just Sayin
Old 09-01-2014, 02:15 PM #43
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
Production date: Don't know
03 Limited 4WD
271,200km
New radiator
Small leak that will be fixed at the end of the year
Runnig strong
I've also noticed in other forums this issue and not one mentions an 03
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 09-01-2014, 02:20 PM #44
alaskaman's Avatar
alaskaman alaskaman is offline
alaskaman is on a distinguished road
alaskaman's Avatar
Good Thread. Toyota has the data. If I was in your position I would request it. When they say no, have an attorney write them. That will get the ball rolling.
2007' V6 SE 4WD PIAA 520's.
Yakima Load Warrior
Michelin LTX M/S 265 65 17
Westin Bull Bar Weathertech Mats
Bilsteins 5100's
alaskaman is offline   Reply With QuoteReply With Quote
Old 09-01-2014, 02:54 PM #45
Cornelius's Avatar
Cornelius Cornelius is offline
Real Name: Justin
Cornelius is on a distinguished road
Cornelius's Avatar
Real Name: Justin
2004
11/03 production (IIRC)
4x4
150,000 miles
Cylinder 2
-Never overheated, coolant changed on schedule with Toyota SLL
**Fun fact: A head gasket leak is the reason I sold my '99 Tacoma 3.4 before this. Bought the 4Runner thinking I'd have at least a good 3 or 4 years before anything serious went wrong. Had it 9 months and this happened... Yay me.
2004 4Runner SR5 4x4 V6
Toytec 3" lift (Eibach/Superflex coils with Bilstein 5100s), BFG T/A KO 275/70R17, Spidertrax, 5x11x22 Magnaflow with resonator delete, and a rattling sunroof
Cornelius is offline   Reply With QuoteReply With Quote
***Cracked Dashboard Action Request*** momo.75 4th Gen T4Rs 1582 08-10-2023 09:37 AM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
4th Gen HEAD GASKET (ACTION REQUEST!) Kshino 4th Gen T4Rs 2 09-12-2018 11:36 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
