Thread Tools Rating: Thread Rating: 5 votes, 3.80 average. Display Modes
Old 05-29-2014, 01:37 AM #16
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
An update of HG problems so far.
*** V6 Head Gasket Action Request ***-screenshot_1-png
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
Old 05-29-2014, 10:12 AM #17
telum01 telum01 is offline
telum01 is on a distinguished road
2006
4WD
140k+
no issues
*furiously knocking on wood*
telum01 is offline   Reply With QuoteReply With Quote
Old 05-29-2014, 07:10 PM #18
SharonKR SharonKR is offline
SharonKR is on a distinguished road
Originally Posted by jake87toy View Post
Mine is in the shop currently getting both head gaskets replaced. I wouldn't call it an epidemic either by any means, but I also would not ignore the fact that it is happening to people. Google search "P0306 Toyota 4.0" and read through a few. If are researching prior to a purchase, I would advise making sure you start the vehicle from a cold start in the morning and confirm that it runs smooth immediately. Toyota quotes this job at $2500-3200 and that is a very heavy expense for some.
were you able to get the gasket fixed? i had the same problem toyota quoted 2000.00 to 8000.00 my husband optied to change now it idel high. not sur whats wrong any ideas
SharonKR is offline   Reply With QuoteReply With Quote
Old 05-29-2014, 07:12 PM #19
did you replace the head gaskets?
Old 05-29-2014, 09:59 PM #20
morphious's Avatar
Real Name: John
morphious's Avatar
Real Name: John
No, I have not had any problems in 86,xxx miles so far since I bought it in Dec 03'.
Old 05-31-2014, 11:36 PM #21
KMG1981 KMG1981 is offline
KMG1981 is on a distinguished road
2005
02/05
4x4
167,500
I threw a P0302 code, performed a tune-up, and changed the coil. The problem persisted and alas, it was a blown head-gasket. The typical symptoms began to manifest itself with the gurgling water sound from the coolant when the cylinder sealed. No over-heating, white exhaust, or smell of gasoline in the coolant. The coolant level did eventually begin to fall. The coolant had been changed at 110 k. According to the tech, the radiator was damaged by the pressure. And this car has had scheduled maintenance performed consistently.
The machine shop did a pressure test and found no warpage or cracks. So all they did was re-surface and sent it back. Fortunately, extensive repairs weren't warranted. The dealership was clueless as to the exact cause of this.
So the issues surrounding this are two-fold. First, it's an aluminum engine in which thermal expansion occurs with temperature fluctuations. Other brands of automobile engines built around the same time are known to blow head gaskets and it's the aluminum.
Second, mine occurred on Bank 2, cylinder 2. It didn't occur on the usual Bank 2, Cylinder 6. A person speculated that the even cylinders have head gasket failure on the driver-side due to exhaust routing. It makes sense.
The service manager indicates that he didn't know why the head gasket was superseded and indicated that it was probably a change in the manufacturer.
I had this occur 2 months after the dreaded frozen caliper/seizure on my front and rear brakes. I had the calipers, rotors, and brakes re-done. I also had the CV Boots replaced too.
To add insult to injury, my power steering rack was also leaking. I had them cut the area where it was leaking and clamp a hose to it. It's a temporary fix and the rack is rusting. It's got to be replaced eventually.
I don't even want to tell you how much I spent. And yes, I went to the dealer. The service manager there is a very honest and upfront person. I also don't have a local shop I trust and have the most faith in. I have very little free time to do the research and perform the repairs myself. It's very cool though how some people here attempt the repair and are successful.
I'm disappointed in Toyota because when you buy their brand, you buy it first and foremost for reliability. I've had the vehicle for 9 years and had nothing major happen thus far. But at 167 k, I don't expect a head gasket failure this early. In the back of my mind, I expected something like this at the 230 k mark. My dad's 16 yr-old Ford Crown Victoria which is hardly ever serviced for regular routine maintenance still runs and hasn't had any significant repairs compared to my 4Runner. I'm well aware this is mechanical and can happen to any vehicle, but this isn't a coincidence or small aberration.
I love the 4th Gen, it's the last of it's kind in terms of true truck SUV. I looked at the 5th Gen 4Runner and just was not interested. This car has been paid off for awhile too. Financially it makes sense to stop putting money into it or find a used V8 4Runner. But this is "mine" and there's nothing new out there that I believe I'll be happy with.
2005 4Runner V6 SR5 4WD
KMG1981 is offline   Reply With QuoteReply With Quote
Old 06-13-2014, 02:32 AM #22
Chalk Outline Chalk Outline is offline
Chalk Outline is an unknown quantity at this point
2005
4x4
130,000
#6 (P0306)
Always serviced at factory intervals and never overheated.
2005 SR5 V6 4x4
Scion T1807, P.I.E., MB Quarts, PIAA Xtreme White bulbs, ScangaugeII, Garmin 60CSx, Weathertech Classic
Donahoe c/o's, Radflo 2.5" rear shocks, custom rear coils + 1"/15%, Hanna sliders, BFG ATs 265/75/16
Chalk Outline is offline   Reply With QuoteReply With Quote
Old 06-13-2014, 05:38 PM #23
Martinjmpr's Avatar
Martinjmpr Martinjmpr is offline
Martinjmpr will become famous soon enough
Martinjmpr's Avatar
2007
4x4
118,000 miles and counting
No HG issues or overheating. I pull a trailer regularly, too.
Martin AKA Zapp Branigan - No longer a 4runner owner!
Martinjmpr is offline   Reply With QuoteReply With Quote
Old 06-16-2014, 11:14 AM #24
BToyota BToyota is offline
BToyota is on a distinguished road
2nd post, but no troll...
HG has a small leak after replacing coil in cylinder 6 and all plugs.
2004
V6, 4X2
170,000
#6 (P0306)
Thanks to all of the posts about this, I recommended to the tech to check the HG before fixing any other "possible" issues.
BToyota is offline   Reply With QuoteReply With Quote
Old 06-16-2014, 12:01 PM #25
VACJ7 VACJ7 is offline
VACJ7 is on a distinguished road
2004, Sport 4x4, #6 misfire
  • 2004 4Runner Sport, V6
  • Do not know production date
  • 150000 miles
  • Started 2 weeks ago with #6 misfire and would smooth out after 40 seconds
  • Replaced coil, same symptoms
  • Currently sitting at dealer with head removed and headed to machine shop for inspection
  • At 1200.00 right now for head removal and diagnostics
VACJ7 is offline   Reply With QuoteReply With Quote
Old 07-07-2014, 03:11 PM #26
thefatcat thefatcat is offline
thefatcat is an unknown quantity at this point
2005
Not sure of production year?
4x4
132,000 miles +/-
Cylinder 6
The small shop that diagnosed the problem (dealership had two shots to get it right) said it was a very minor leak so I could limp along for a while but I should plan on dealing with it sooner than later. Same symptoms, cylinder 6 misfire, sputters when started for 30 seconds, etc. I have refilled the resevoir once since the diagnoses (currently have 144,000 miles on it).
One import shop told me to try bars leak on it first. I am planning on keeping it until it dies so I am leaning towards just biting the bullet and fixing it.
Dealer wants $2500 to fix just one side, import auto repair wants $2400 to do both sides...seems reasonable.
thefatcat is offline   Reply With QuoteReply With Quote
Old 07-11-2014, 10:37 AM #27
nysimonsez nysimonsez is offline
nysimonsez is an unknown quantity at this point
2004
I think late '03
V6, 4X4
145,000
#6 (P0306)
Diagnosed leak in July '13 at 145k. Didn't want to put $3k+ into the fix because I'm only keeping it for 2 more years. Used Bar's leak to see if it worked. Now truck has 163k and no issues yet. I'm sure the bar's leak won't hold up very long but hopefully will for another year.
nysimonsez is offline   Reply With QuoteReply With Quote
Old 07-11-2014, 11:02 AM #28
morphious's Avatar
Real Name: John
morphious's Avatar
Real Name: John
Update spreadsheet:
Old 07-11-2014, 11:38 AM #29
thebitz1 thebitz1 is offline
thebitz1 is on a distinguished road
Not sure how much help this will be, but I want my issue thrown into the tally.
2006 Sport - Sold in 2011 (worst car decision of my life)
Prod date unknown
V6 4x4
2, 4, 6 cyl leaked. I think 1 3 5 did as well, but Dealer replaced both under warranty
45k miles?? (unsure now)
2003 Limited 4WD V6, Black, 41K miles
1999 Limited 4WD V6, Silver, 122K miles - SOLD (tired of the suspension issue)
2006 Sport 4WD V6, Silver - SOLD
thebitz1 is offline   Reply With QuoteReply With Quote
Old 07-11-2014, 11:44 AM #30
alaskaman's Avatar
alaskaman alaskaman is offline
alaskaman is on a distinguished road
alaskaman's Avatar
2007 SE 4x4 no head gasket issue.
2007' V6 SE 4WD PIAA 520's.
Yakima Load Warrior
Michelin LTX M/S 265 65 17
Westin Bull Bar Weathertech Mats
Bilsteins 5100's
alaskaman is offline   Reply With QuoteReply With Quote
***Cracked Dashboard Action Request*** momo.75 4th Gen T4Rs 1582 08-10-2023 09:37 AM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
4th Gen HEAD GASKET (ACTION REQUEST!) Kshino 4th Gen T4Rs 2 09-12-2018 11:36 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
