Thread Tools Rating: Thread Rating: 5 votes, 3.80 average. Display Modes
Old 03-17-2019, 02:47 PM #871
thewaydown thewaydown is offline
thewaydown is on a distinguished road
Originally Posted by jake87toy View Post
Mine is in the shop currently getting both head gaskets replaced. I wouldn't call it an epidemic either by any means, but I also would not ignore the fact that it is happening to people. Google search "P0306 Toyota 4.0" and read through a few. If are researching prior to a purchase, I would advise making sure you start the vehicle from a cold start in the morning and confirm that it runs smooth immediately. Toyota quotes this job at $2500-3200 and that is a very heavy expense for some.
New owner of an 03 v6. No codes. A little white smoke coming out of the exhaust at start up that goes away after a few seconds. Coolant is below low line in the reservoir, but I don't know when it was last topped off or changed. Previous owner did not put Toyota coolant in. Khameleon was put in after a flush at some shop. I'm really hoping there isn't an issue.
Has anyone tried the chemical tester kits? If so, which one is preferable, and have you had success? Also, would a compression/leakdown test cause/worsen the problem?
thewaydown is offline   Reply With QuoteReply With Quote
Old 03-17-2019, 03:18 PM #872
Does anyone have positive confirmation that the early 4th gens use Toyota Red LLC, instead of premixed pink? Mine is an 03, and I just read in another forum that red is supposed to be used in the 03.
Old 03-17-2019, 05:34 PM #873
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You do indeed need the red.
2004 Limited V8
Old 03-20-2019, 05:49 PM #874
iBison iBison is offline
Real Name: photoshop god
iBison is on a distinguished road
We used a radiator exhaust gas tester on mine and it came up negative. We used a borescope with an iPhone and saw coolant in #6 after sitting.
.: READ IT! :.
Pre-Purchase Info, Modifications, Write-Ups, Quick Links, and FAQ's
Tons of info on 4th gens for new and prospective buyers with links to the best topics.
iBison is offline   Reply With QuoteReply With Quote
Old 03-20-2019, 07:10 PM #875
Do you have any pics?
Heres the thread I just started with my pictures after inspecting Cylinders 4 and 6.
Borescope pics. Head gasket failure?
Old 04-05-2019, 09:44 PM #876
lbhsbz lbhsbz is offline
lbhsbz is on a distinguished road
Headgaskets can fail in several ways...which will need different methods of detection.
A blue juice test at the radiator will only detect if combustion gasses are leaking out of the cylinder into the cooling system, but won't detect if coolant is leaking into the cylinders. Just because one condition exists does not mean that both exist.
lbhsbz is offline   Reply With QuoteReply With Quote
Old 04-10-2019, 11:58 PM #877
Dhg4dragon8 Dhg4dragon8 is offline
Dhg4dragon8 is on a distinguished road
Got a master seal kit from Toyota to day. What are the bolts the are required to be replaced for a head gasket? I have the head bolts orderd.
Dhg4dragon8 is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 08:34 PM #878
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
I think the instructions call for new exhaust manifold nuts or studs or something but why o that really? Mine haven't fallen off yet.
gaber6 is offline   Reply With QuoteReply With Quote
Old 05-05-2019, 07:50 PM #879
Cody01 Cody01 is offline
Cody01 is on a distinguished road
Hello every. I recently traveled a good ways from home to buy a 2003 4runner with 130k that has kept up decently. It is a Limited and only problems I can really find are it needs struts(non xreas system), has very minor leak on a seal on left side front diff output shaft, ans brakes work but feel kind of soft. Not sure if thats just how they are but everything else I drive the brakes kick in way earlier in the pedal. Anyway after getting it home and doing some reading I came across all these threads about the head gasket issue with 2003-2005 and I felt like I could taste my a**hole after reading this stuff. Mine doesnt appear to be bad but now I feel like reselling even at loss and getting Tahoe or other pushrod engine. I've always been a Chevy guy bur heard how great Toyotas were so I thought I would give one try and now I have some buyers remorse.
Cody01 is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 11:44 AM #880
YetiX's Avatar
YetiX YetiX is offline
Real Name: Scott
YetiX has a spectacular aura about YetiX has a spectacular aura about YetiX has a spectacular aura about
YetiX's Avatar
Real Name: Scott
Why? It's not leaking so worry about it? That's like worrying about getting struck by lightning. Sure, it could happen but it's not likely. You're buying worries that you don't need.
-Semper Fi-
2006 4Runner Sport Edition 4WD V6/Suspension/Armor/Lights/Wheels and tires/Drawers/Camping things/Surfboards/Rhodesian Ridgebacks . . .
BUILD AND ADVENTURE THREAD
YetiX is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 03:23 PM #881
I see your point but I see to be a guy that has bad luck so I assumed I would get it. I didnt read wvery page but it like 04 and 05 were worse for some reason than 03? Maybe i will get lucky with my 03. Do you know if I buy a motor from a wrecked 06+ would it be direct swap? Sometimes that stuff is on Copart for crazy cheap and I could have a spare motor if the 06+ fits everything the same.
Old 05-06-2019, 04:38 PM #882
tom4416 tom4416 is offline
tom4416 is on a distinguished road
I too own an 03 V6, since new and wasn't happy when this thread popped up. However, after reading every single page , the 03 cars suffered the failure at a far, far lower rate than 04/05. Why? No clue and I posted this question to the forum and no one had an answer. Sales numbers were similar to failures should have been as well but they are not so rest a little easier knowing that, statistically anyway, yours isn't going to fail.
tom4416 is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 06:41 PM #883
Good to know. My wife has an 07 and I wouldnt mind doing a 5 speed transplant if I ever have to do a motor. I would just buy a wrecked rig for both. Has anyone done that swap?
I just looked and seen mine has a build date of May 03 so kind of late build for the year.
Old 05-06-2019, 08:24 PM #884
Nova_GTS Nova_GTS is offline
Nova_GTS is on a distinguished road
I just got my brothers old 2004 which was burning coolant. I've done testing and confirmed I have a HG failure... After doing a lot of reading I've realized its a very common issue, but I had a few questions:
-What replacement Gaskets are people using? Auto parts store? OEM?
-Anything else I should replace/repair while I have the motor apart? Water pump looked common (OEM or aftermarket).
-Any good write up's for the repair?
Nova_GTS is offline   Reply With QuoteReply With Quote
Old 05-08-2019, 09:44 PM #885
nghiS4's Avatar
nghiS4 nghiS4 is offline
Real Name: Neil
nghiS4 is on a distinguished road
nghiS4's Avatar
Real Name: Neil
Meh. I bought my well-maintained & documented '04 in 2014 with 130K. Now at 215K with zero engine issues.
'04 4RUNNER Titanium Metallic 4.0 LTD 4WD. Toytec Ultimate lift | LR UCA | ProComp 7105 wheels 17x8 | Cooper STT Pro tires 285/70/17 | RCI Full AL skids | RCI steel diff skid | Ricochet AL LCA skids | BAMF sliders | Demello Offroad 3 Hoop Bumper | Spec-D headlight housing, XD Philips 4300k halogen, TRS BiXenon ACME Super HIDS
nghiS4 is offline   Reply With QuoteReply With Quote
***Cracked Dashboard Action Request*** momo.75 4th Gen T4Rs 1582 08-10-2023 09:37 AM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
4th Gen HEAD GASKET (ACTION REQUEST!) Kshino 4th Gen T4Rs 2 09-12-2018 11:36 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
