Thread Tools Rating: Thread Rating: 5 votes, 3.80 average. Display Modes
Old 10-15-2019, 11:55 AM #961
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Originally Posted by Captsolo View Post
What makes you think you have a coolant leak into heads?
The loss of 1/4" antifreeze from the overflow every 5k miles.
No visible leaks in engine bay or on radiator.
Chunks of HG coming out of radiator after drain and fill.
The HG fails at the water jacket surrounding the top of the cylinders letting coolant enter the cylinders, usually its the #2 or #6 on the driver side, from what i gather reading here on the forum... Toyota corp still will not even acknowledge the HG fail on these 4th gens.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 12:24 PM #962
Captsolo Captsolo is offline
Captsolo will become famous soon enough
How does it run?
I got 150,000 miles on a V6 SR5 2005. Runs like new still.
No HG issues.
I'd use SteelSeal before barsleak.
I'm not certain you have a HG issue?
I get down some coolant occasionally. I'm in the Bahamas where its hot.
Chunks of HG coming out of radiator after drain and fill. - not a good sign.
My 4runner was built in Japan - not USA.
Captsolo is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 01:38 PM #963
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
How does it run?
No HG issues.
I'd use bars leak before SteelSeal.
When was yours built? Driver side door sill, for the info.
Seems like the change in these HG was mid 2005? No?
Mine runs real good too.
SteeSeal has a 99% happy consumer rate and money back guaranty.
Also no chunks in it to foul/clog up other non HG stuff.
Some theory as to HG fail.
1. The naming scheme "Lifetime" was a bad idea. Fools consumers into a false sense of complacency. Toyota used to avoid 'toxic waste' disposal tax...or some such BS.
2. Most drive 15k miles/year average these days, gasoline addicted society, 15k x 6years=90k, recommended change is 100k, first then every 50k after.
I think the longer it sits the more acidic it (antifreeze) becomes, bad for the early HG's.
Was like 10years of ownership before i thought i should look into this and was prompted by a leaking water pump.
3. If the engine warms up (allowing for thermal expansion) before you punch the gas peddle may help reduce blow-by, spit-balling ideas here.
Warmer climate may help extend the HG life?
There are really not that many fails in the whole scheme of 4th gen HG fail per sales numbers, so Toyota corp dodged a bullet.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 10-15-2019, 07:04 PM #964
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
How does it run?
No HG issues.
Just an FYI...ALL 4Runners are made in Japan, none are made in the USA!
All head gaskets on the V6 on or after 12/05 should be the new designed head gasket, so that build date or later is what one wants to see for their 4th Gen V6 T4R.
2004 Limited V8
Old 10-16-2019, 06:54 AM #965
The frequency of HG failures is probably under 1% of the 4 runners on the road today.
Toyota builds about 100,000 4runners annually. Failures seem to occur on older models with 140,000 + miles.
There are well over 1M 4runners on the highway WW today.
HG failures happen in Fords and all other makes and models too. No one is immune to having them IMO.
Old 10-18-2019, 03:27 PM #966
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
There are HG fails in pretty much all gen 4runners and tacomas.
I had a 1992 dump its HG at about 90k. Dealer fixed that one.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 10-29-2019, 03:52 PM #967
4Runner4Runner4's Avatar
4Runner4Runner4 4Runner4Runner4 is offline
4Runner4Runner4 is on a distinguished road
I just bought a 2007 4.0L with 193k miles. Leak down test results 162-165 PSI, and the Toyota dealership says the test is run from 189 PSI (which I think is weird, but I don’t suspect them of lying to me). This nets a 12-14% loss in pressure.
I believe I understand that this isn’t perfect by any stretch of the imagination, but I should still have some life left in the old girl. Is that about right? Is there anything I can do to help limp her along in her golden years, aside from maintaining regular oil changes and not letting her overheat?
4Runner4Runner4 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 08:14 PM #968
weaves weaves is offline
weaves is on a distinguished road
A leak down test is a completely different test from a compression test and uses a separate set of gauges. It is represented as a percentage but it is not calculated by subtracting the recommend compression outlined in the service manual (189 psi or more) from your results. "Or more" is key - a typical healthy engine will usually show higher than 200 psi at sea level.
While your numbers seem a bit low, the important thing is that they're all fairly consistent across the cylinders. My guess is that they did not open the throttle plate while performing the compression test which will significantly lower your results.
weaves is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 08:27 PM #969
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
I need some advice.
I have an '04 4.0 Sport, so this Head Gasket thing has always been in the back of my mind.
I have 230,000 miles and noticed something weird last week:
I have no could of smoke on startup. No waterfall sound. No CEL or codes.
What I do have is a black layer of crud that appeared of the inside of the overflow reservoir/tank of my radiator above the coolant, on the walls (probably 40k - 60k miles and 3.5-4 years on that radiator) I lost a little fluid in there, but it came back 2 days later. That was a week ago. I lost a little fluid again today. The black crud isn't in the fluid, only on the walls above the fluid. The fluid is 3.5-4 years old too, since the new radiator. I read that you should take the reservoir off, scrub it with dish soap, and replace it, and see if the black goo comes back. Only problem is that everyone that has a HG failure has the black goo in the fluid. This black crap looks terrible on the walls of the reservoir.
Should I get a hydrocarbon test? Oil is looking good on the dipstick, no condensation or anything on the cap. I just switched to synthetic 0w-20 on my last oil change, also.
Thoughts????
EDIT: I posted a new thread:
Is this the beginning of a Blown HG or False Alarm?
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 12:30 PM #970
A definitive TEST: How to check for a blown Head Gasket without any tools and zero costs...
I have a 2005 SR5 V6 with 150,000 miles. After reading all the HG threads full of HG failure paranoia, I did the following.
First. Checked the overfill canister and filled it up to the top "see through" line with fresh antifreeze. My canister was down 1/4 inch when I started this maintenance, and there were no coolant leaks.
Every day I open the hood and look at the coolant level to see if it has changed. I sometimes do this twice or three times a day.
Every day (after a 10 minute drive or a 2 hour drive) I check the overflow canister for a change in level, and not once has it moved up or down - and I've done this 30 times. AND.. I've never had to add coolant!
I also have had no overheats since I bought the car new in 2005. The gauge for temperature on the dash works fine, and I've concluded I do not have a blown HG (or any other coolant issues - thermostat, radiator, WP, hoses, etc., etc.).
Yes. Coolant leaking into your cylinders via the HG is a serious thing, but why worry about it if your coolant level is right where it's supposed to be (unchanged), the car doesn't miss at start up, doesn't smoke white water fumes out the tailpipe, and you get no "codes"?
BTW.. I changed the radiator cap with a new OEM cap about a week before I decided to run this "test". The original radiator cap was 14 years old. The old radiator cap was worn, and needed replacing.
Head Gasket Sealer | Head Gasket Sealant | BlueDevil
BTW Toyota 4runners on the road are upwards of 1 million or more, and probably less than 1% have a HG issue IMO.
UPDATE: Checked the coolant level in canister this Dec 6 2019 for any change. It has stayed exactly at the same height in the overflow canister. I tread the day I hear the gurgling behind the dash; a coolant level drop in the overfill canister, coolant smell out the exhaust, miss on startup. My 4runner has never had an overheat in 15 years and 145,000 miles.
Old 11-04-2019, 07:50 PM #971
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
My 4th gen 08 runner lost the hg at 270 000 miles. That car ran well for years and even with hg issue It still ran well. I replaced the motor with a low mileage motor for 3k. My son has got 3 more years of college and I'm sure it will continue to run just fine. After that he will get rid of it and probably get something else. 300k miles on the car is ok and has served the family well. My 3rd gen 96 has 314k miles and is used as a around the town car now. Toyotas are not immune to issues but considering how many miles it takes to get any serious issues I still say they are the best built vehicles
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 08:30 AM #972
Amazing.
Not unusual for a Ford Explorer to go through 3 transmissions in 200,000K.
Old 11-07-2019, 08:31 AM #973
Amazing. not unusual for a Ford Explorer to go through 3 transmissions in 200,000 miles
Old 11-07-2019, 06:08 PM #974
Dr-V's Avatar
Dr-V Dr-V is offline
Dr-V is on a distinguished road
Dr-V's Avatar
2004 V6
178000
cyl 4
Dr-V is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 12:05 PM #975
I didn’t subtract it. Please look at the math. I measured it as a percentage which, to my knowledge, is the correct method of measuring leak down.
I would love to know why you think this so that I can use this when discussing the results with the Toyota dealership.
2007 4.0L 2Runner SR5
250,000 miles, and adding 4000 more per month!
***Cracked Dashboard Action Request*** momo.75 4th Gen T4Rs 1582 08-10-2023 09:37 AM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
4th Gen HEAD GASKET (ACTION REQUEST!) Kshino 4th Gen T4Rs 2 09-12-2018 11:36 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
