11-26-2019, 02:54 AM
#976
185k 2003 2wd..
so my story is that I originally noticed some coolant "leakage" from the upper radiator hose down my radiator. My overflow coolant level didn't drop so I didn't think much of it... fast forward to two weeks ago and I saw that the "leak" was a lot worse, so I try adjust the clamps of the hose with plans to replace the upper rad hose.
A couple days ago I replaced the upper rad hose and a lot of coolant was lost, after changing it - I filled the overflow tank as the levels decreased a bit.
Today during a cold start I heard the dreaded water trickle behind my steering wheel.... no rough idle or overheating today when I drove my hour long commute. When I get to work I notice my overflow tank is empty. No signs of leaking from the upper rad hose or anywhere else from a quick check. I ordered some Toyota 50/50 with anticipation I would have to use it, so I filled the overflow once again and wait until work is over.
I start my car to go home after work and hear the same water noise behind my steering wheel. Once I get home I see that the overflow coolant level has also decreased a little from where I filled it earlier in the day.
After much research, the first thing tomorrow morning Im going to try and burp my coolant system to get any air out
My questions is do you all think this water fall noise could be the result of a bad HG?? I had no problems with my car and no decrease in coolant until I replaced the upper rad hose.
11-26-2019, 07:31 AM
#977
Real Name: Hunter
Real Name: Hunter
Originally Posted by Gen4SR5
185k 2003 2wd..
I had something very similar happen and it was because I didn’t burp the system properly. My overflow tank kept losing coolant. it slowly stopped after it worked the air bubbles out itself. I would still try the best you can to burp the system Because air creates a lot of pressure in the cooling system.
2006 Limited V6 4WD, Natural White (Sold)
2006 Limited V8 4WD, Salsa Red Pearl
11-26-2019, 07:50 AM
#978
Real Name: Skip
Real Name: Skip
185k 2003 2wd..
The waterfall sound that's related to a bad head gasket is usually heard coming from behind the glove box not the steering wheel, so I think you most likely have trapped air in the cooling system.
2004 Limited V8
11-27-2019, 06:06 AM
#979
Real Name: Miah
Real Name: Miah
Look up this video that was just posted on YouTube.
Food for thought...
4th Gen 2WD to 4WD CONVERSION
2003 SR5 T4R Pac Blue Metallic w/rear locker, on 35" Mastercraft MXT’s, TC uca"s, TC lca"s, 2.5 King C/O's w/remote resi TC lca gusset kit, Taco Tabs, 2.5 Icon remote resi w/adj on rear Shock Hoops, adj panhqrd A 3.5" lift springs, 10" HD Series AirLift bag, hidden winch W/ 10k Smittybuilt, DMZ eng mounts
11-27-2019, 07:57 AM
#980
Real Name: Skip
Real Name: Skip
Food for thought...
While I like his diagnosis process, I would have loved to see a follow up confirming the intake coolant leak by fixing the issue, because a bad head gasket could produce coolant in that cylinder so there would be the same results he came too with the coolant system pressure test.
2004 Limited V8
11-27-2019, 11:24 AM
#981
Food for thought...
Complete rubbish. How does coolant leak past the intake manifold when there are no coolant jackets in the intake manifold?
"It's 100% definitely not a head gasket". Well then, how does coolant get into cylinder? Either a blown head gasket, cracked head or block.
11-27-2019, 11:27 AM
#982
Real Name: Kevin
Real Name: Kevin
Could also be coming from the throttle body. Though I'd imagine it'd end up in multiple cylinders if that happened.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
11-27-2019, 11:35 AM
#983
Exactly, it would be on all cylinders and not just #6.
11-27-2019, 10:23 PM
#984
Update:
I burped my system pretty well, there was so much air that it caused a lot of coolant to come out of my radiator cap when I first started my car. Ran the heater, revved up to 2.5-3k a few times and then let the car run to operating temp. I let it sit overnight and no more water sound or leaking coolant
11-28-2019, 10:25 AM
#985
He posted a follow up video, after being challenged.
11-29-2019, 08:05 PM
#986
Real Name: Skip
Real Name: Skip
Yes he did!
Basically admitting he was wrong, that's what happens when you try to diagnose an engine you're not familiar with and also dead set on proving the first diagnosis was wrong because they sold the lady a set of new spark plugs that may not have been needed so they just have to be wrong about it being a head gasket.
Here's a link to the video if anyone cares to watch it, I stopped watching around the halfway point of a 35 minute video because of him as in the first video being so very redundant that it drove me up the wall waiting on him to get to the point, either video could of been 10 minutes long or less and said the same thing.....but to no avail he just keeps repeating himself, and trying to explain why he was so right but also so wrong in his diagnosis!
YouTube
2004 Limited V8
11-30-2019, 01:10 AM
#987
Real Name: Miah
Real Name: Miah
@ AuSeeker
I was just about to post his follow up video,!!
Haha
12-01-2019, 03:15 PM
#988
Year: 2006
Production Date: Oct 2005
4x4
Mileage of failure: 185164
Cylinder # that leaked: 4
CEL came on, PO304. Swapped coils, no change in codes. Rough on start and sweet smell from exhaust. Had the dealer confirm leaking head gasket. Pulled both heads and had them re-built and machined. 0.002-0.003" warp on the driver side head.
Truck has been up and running for a couple weeks. No CEL or leaking coolant so appears to be fixed.
12-06-2019, 12:05 AM
#989
Originally Posted by weekendwrencher
Year: 2006
4x4
The dealer huh? Just out of curiosity how much did that run you? I'm debating whether it's worth taking to the dealer since I haven't been able to find a reliable toyota mechanic near me.
2006 Sport Edition 4Runner
Toytec suspension
Total Chaos UCA
Spidertrax spacers
12-08-2019, 12:41 AM
#990
weekendwrencher,
Sorry to hear about your failed headgasket on your 06.
Mind if I ask how often the coolant changed prior to the failure?
I’ve changed my coolant in my 06 4 times now since I purchased it at 126k (built date of nov 2005) and have 196k with no issues at all.
Just got a second blackstone labs report back and everything is perfect with my engine.
Glad you got it fixed. How much did it run you?
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
