Thread Tools Rating: Thread Rating: 5 votes, 3.80 average. Display Modes
Old 05-21-2020, 05:32 PM #1006
babar babar is offline
babar is on a distinguished road
I'm looking at a pristine one-owner 2003 V6 4x4 with 60k in SoCal that has been meticiously maintained every 5k at the dealership and kept in garage and babied.
Dude wants SoCal prices 12-13k. What do you guys think? I haven't seen that many 2003 V6 with the HG issue in this tread so far?
babar is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 06:15 PM #1007
Gen4SR5 Gen4SR5 is offline
Gen4SR5 is on a distinguished road
At that price I would look for 06+ with a little higher mileage.
- Projector beam headlights
- LED tail lights
- fixed HG issue (depending on mfg yr)
Gen4SR5 is offline   Reply With QuoteReply With Quote
Old 05-24-2020, 08:14 PM #1008
tom4416 tom4416 is offline
tom4416 is on a distinguished road
Damn, I'm coming to California to sell mine! I think that's low mileage V8 pricing and about five model years newer.
As to your real question about HG on the 2003 models - you are correct, far less failure rate reported on here. I have no idea why that would be, no one has ever voiced a reason why since they didn't make a change in the setup until 2005 but it is what it is. I don't' worry about mine with 130K, keep all maintenance current or proactive and it still runs like new.
tom4416 is offline   Reply With QuoteReply With Quote
Old 05-25-2020, 11:29 PM #1009
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
220k on my 03 4runner, valve cover gasket, rear main seal and other minor stuff so far.
Transmission got a rebuild in 2017, had a seal issue but went the whole 9 yards.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
Old 06-14-2020, 11:06 AM #1010
chengitis's Avatar
chengitis chengitis is offline
chengitis is on a distinguished road
chengitis's Avatar
I might have the dreaded HG failure on my 05 with 154k. Overflow tank is full when driving and does not go back into radiator when cooled. Car drives perfectly fine, no rough idle or CEL. Ordered the block tester to confirm.
chengitis is offline   Reply With QuoteReply With Quote
Old 06-14-2020, 08:19 PM #1011
Iluvboost Iluvboost is offline
Iluvboost is on a distinguished road
So I had a doh moment. I watching my son at the same time as doing my head gaskets. I forgot to put the gasket sealer on the front corners of the head gasket. Has everyone put the gasket sealer on the gaskets? Seems to me it should seal. If I would have been at the shop, I would have caught it. I’m not that far along, I’ll probably disassemble them and redo that part.
Iluvboost is offline   Reply With QuoteReply With Quote
Old 06-14-2020, 09:45 PM #1012
Real Name: Skip
Real Name: Skip
While I would say yes you need to do the gasket sealer to make sure it correct, hopefully I'm wrong but I also think that the head bolts are torque to yield bolts and are not reusable and need to be replaced once they have been tighten down correctly, just another thing to think about...sorry.
2004 Limited V8
Old 06-14-2020, 11:08 PM #1013
You’re right. I’m looking at a fsm and I’m going to check mitchell tomorrow at work but it seems like it only take gasket sealer on the drivers side gasket.
Just checked, it takes it at both sides.
Old 06-15-2020, 12:10 AM #1014
chengitis's Avatar
chengitis's Avatar
I just did the block tester and it didn’t turn yellow. Still don’t understand why my coolant doesn’t go back into the radiator when cooling down. Car has a new thermostat, CSF Aluminium radiator and CSF cap. Should I switch back to my TRD cap? Only thing I haven’t touch is the water pump.
Old 06-15-2020, 08:59 PM #1015
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Get a new radiator cap for a few bucks plus the plastic tank cap and tube that goes to the bottom of tank. Could be either of those.
gaber6 is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 06:18 PM #1016
Daguy80 Daguy80 is offline
Daguy80 is on a distinguished road
- LED tail lights
I am looking to buying 2006 Toyota 4runner. I am wondering if it had the new head gasket or not. The manufacture date of the car is November 2005.
Daguy80 is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 07:11 PM #1017
Real Name: Skip
Real Name: Skip
Unfortunately..no, the date for the redesigned head gasket starts with 12/05 and onwards.
That being said not all of the old design head gaskets fail, not sure what the percentage is but I would think it's not too high of a percentage or Toyota would have been forced to do a recall, but it's still the luck of the draw so to speak if it will have a head gasket failure.
You may also want to research the maintenance history of the vehicle to see if the head gaskets were ever replaced, if they were you shouldn't have any worries.
2004 Limited V8
Old 07-12-2020, 11:34 PM #1018
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
I had our 08 4th gen fails at 270k miles. Blue devil head gasket sealant worked for months but soon after the problem was back. Had the gasket fixed and vehicle drives fine with zero issues. Sooner and later everything will fails and head gasket issues unfortunately does happen on the 4th gen and even the 3rd gen eventually with age and miles.
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 08-01-2020, 03:20 PM #1019
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
I am back in this thread...again.
Was loosing a 1/4" per 4-5k miles (year driving for me) from the overflow.
Looking back at my service notes, i first started thinking this HG deal had me.
After i did the water pump, 63,855miles on 1/21/2015.
I was still loosing coolant.
This last 6 months i have lost over 2" out of the overflow res.
Dumped a couple bottles of Steelseal in at 83,650 on 11/19/2019.
After a flush, did the directions on the bottle. Straight water and Steelseal then heat cycle.
Then a flush and regular antifreeze added last.
Bought this krazy UV flashlight... UV Beast v3.
Waved it around the engine bay... DAMN, NEON GLOWING antifreeze is all over, looks like the water pump... again.
Either i did a piss-poor job the first go or was a bad pump from the get go, seems unlikely.
I am going to dig into this over the next couple days.
I will add some UV pics, pretty amazing...
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 05:27 PM #1020
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
So this is another water pump for me.
More of a recent looking leak.
If i had looked closer i would not have needed the UV...der.
Had my front skid off not all that long ago and didnt see this.
While not exactly head gasket related it maybe a good way to rule out leaks like the water pump, hoses, t-stat or other...
Phosphors in the antifreeze glow neon pink under UV light.
No additives just the coolant.
Waved the UV light around a 2014 GX460, not a speck of glow.
Just antifreeze in first 2 pics.
*** V6 Head Gasket Action Request ***-img_9010-jpg  *** V6 Head Gasket Action Request ***-img_9008-jpg  *** V6 Head Gasket Action Request ***-img_9006-jpg  *** V6 Head Gasket Action Request ***-img_9018-jpg  *** V6 Head Gasket Action Request ***-img_9022-jpg
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
***Cracked Dashboard Action Request*** momo.75 4th Gen T4Rs 1582 08-10-2023 09:37 AM
2004 head gasket #6 (gasket treatments work?) ingrjc1 4th Gen T4Rs 7 12-01-2019 12:39 PM
4th Gen HEAD GASKET (ACTION REQUEST!) Kshino 4th Gen T4Rs 2 09-12-2018 11:36 PM
head gasket repair leads to piston through head theresa4586 3rd gen T4Rs 37 03-20-2013 01:20 AM
blown head gasket, then warped head, now new engine straightjacket 4th Gen T4Rs 42 05-12-2012 09:45 PM
