Old 02-17-2015, 03:21 PM #1
eds72 eds72 is offline
eds72 is on a distinguished road
Brake shim - what does this mean?
I am due for new brake pads and pulled the RF to take a look. This is how the slotted shim looks:
You can see there is a plastic-like film covering part of the shim that has started to peel. Do the shims have plastic coating that is intended to be left on when installing, or did someone fail to peel it off? If it's supposed to remain on there, is the shim now useless or can i peel it entirely and use grease or some sort of anti-squeal?
eds72 is offline   Reply With QuoteReply With Quote
Old 02-17-2015, 03:34 PM #2
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
the pic isn't showing up.
my guess, is that it was supposed to be removed. a lot of times the shims have a sticky side, and that plastic it meant to be removed to expose it. its not a big deal either way. pull the shim, and remove the plastic, reinstall the shim.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 02-17-2015, 03:38 PM #3
Pic is there now, I always forget that Google drive requires me to jump through some hoops to embed a shared image.
Old 02-17-2015, 05:37 PM #4
Whatever it is it's not easy to remove. I tried soaking in brake fluid with no results. Next tried mineral spirits... maybe loosened it a little where its already peeling but not much.
Finally hit it with a little torch and made it bubble a bit, now soaking in mineral spirits again. Tough adhesive.
Old 02-17-2015, 05:55 PM #5
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Mine didn't have shims, do I need them?
blackoutt is offline   Reply With QuoteReply With Quote
Old 02-17-2015, 06:08 PM #6
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
I don't think that they are necessary if you get replacement pads that have the metal backing where the caliper pistons make contact.
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 02-17-2015, 08:52 PM #7
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
You should have had a second shim that goes over the slotted shims. They come coated with a black rubber/plastic film and are placed between the pad and outer shim with a light coating of brake grease on both sides. They are supposed to be cleaned and re-used with new Toyota brake pads if in good condition. Unfortunately they are now technically ruined.
As you can see in the following picture in section 04945 you can see how the shims are intended to be placed on the pads.
If you are using Toyota brake pads (the good ones, not the cheaper ones, they come with their own shims), then you need to buy a new set of shims. If you are using non-Toyota brake pads you don't re-use the shims as most aftermarket pads come with their own shims.
BlackWorksInc is offline   Reply With QuoteReply With Quote
FS:NEW OEM Tundra Rotors/Brake Pads/Shim Kit $200 Utah TheArkMaster For Sale: Non-T4R Items 11 10-18-2016 12:57 AM
Brake shim question cj80cruiser 3rd gen T4Rs 4 11-05-2014 04:49 PM
V-6 valve shim tool graeaglecrawler Classic T4Rs 4 04-16-2012 11:30 AM
PF Pads and Factory Shim ? pinchshopper 3rd gen T4Rs 2 07-24-2011 06:19 PM
Shim for a 4th Gen receiver shackle? G.I.G. 4th Gen T4Rs 5 03-25-2009 10:42 PM
