Old 02-21-2015, 11:45 PM #1
RunnerAK's Avatar
RunnerAK RunnerAK is offline
RunnerAK is on a distinguished road
RunnerAK's Avatar
Wiring help: light bar to come on with brights?
I have a LED light bar that came with a harness/relay that is wired up like the diagram below (pardon my amazing drawing skills):
I bought this switch from Air On Board to replace the one that came with the light bar, and I'd like to wire it up so that the light bar switches on and off with the brights when the switch is activated.
Now this would be very straightforward except that Toyota uses negative switching for the headlights so I can't simply tap into the high beam's positive lead. Air On Board included the diagram below with the switch, and I am confused about the part in the box about the second relay.
Where on that diagram should I connect the high beams to the second relay (and which wire should I tap, negative or ground)?
Does anyone have other ideas on how to get the bar to come on with the high beams that don't require a second relay? Any help is appreciated, I'm a noob when it comes to wiring so the simpler, the better.
2006 Limited V8 4x4 - His
2007 SR5 V6 4x4 - Hers
RunnerAK is offline   Reply With QuoteReply With Quote
Old 02-22-2015, 02:50 PM #2
Johnny4runner's Avatar
Johnny4runner Johnny4runner is offline
Johnny4runner is on a distinguished road
Ground the relay trigger to the switched ground of the hight beams. That worked for me when I did my Hella driving lights. Note when the high beams are off there will be some potential on the ground for the high beams since the positive is not switched. My accessory switch would light up like it was on because of the until I installed a diode to stop the potential before the switch. But that may not be an issue with your switch.
2003 4Runner Sport Edition V6 Galactic Grey
Radflo 2.5, 650#/AllPro 3.5 (f/r), LR UCA, Medic Links, 1" BL, GY Duratrac 285/70/17, Pro Comp 7089 17x8, BM chop
Bumpers: Shrockworks / CBI (f/r)
Other: Hella 700ff w/55w HID conv., BAMF sliders, Engo 10K, 2 x MFC, 48" HiLift, backup light, Galaxy 979 CB & Yaesu FT-7900R
Johnny4runner is offline   Reply With QuoteReply With Quote
Old 02-22-2015, 07:03 PM #3
2chains 2chains is offline
2chains will become famous soon enough
Did you get this resolved? I've got 5th gen but this might help? I just received my switches and came with this diagram.. it shows diode should be installed. Haven't done my install as waiting on my Gobi rack. Lots of folks here have the switches installed hopefully someone will chime in.
Wiring help: light bar to come on with brights?-aob-switches-jpg
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
2chains is offline   Reply With QuoteReply With Quote
Old 02-22-2015, 11:28 PM #4
RunnerAK's Avatar
RunnerAK's Avatar
Awesome, thanks for the replies and diagram guys. It looks like all I need to do is hit up Radio Shack for a diode to get it set up the way I want. I'll report back once I give it a try.
Old 02-23-2015, 12:00 AM #5
Let us know how it turns out and you know we all love to see pics to!
Old 10-31-2015, 12:25 AM #6
irish_loveAWD irish_loveAWD is offline
irish_loveAWD is on a distinguished road
Did you ever figure this out? I've been trying to wire my LED light bar to turn on and off with the brights as well. I just can't seem to make it work. I've followed both sets of directions listed. Spent a lot of time on Google searching for ideas. Just not sure what I'm doing wrong. Also, I was trying to bypass having an extra switch (interior switch), so the only way it would work is by turning the brights on and off (no other switches). I'm now planning to order a switch an see if I can figure it out.
irish_loveAWD is offline   Reply With QuoteReply With Quote
Old 11-01-2015, 02:32 AM #7
RunnerAK's Avatar
RunnerAK's Avatar
Sorry, I forgot to update this thread, but I did get it wired up and working as planned using a diode from Radio Shack and Diagram 2 from 2chains's post. I'll try to take some pictures of what I did and post them up.
When wired up this way and with the light bar switch in the ON position (and key in the ignition in the ON position):
  • Light bar is ON when the headlight switch is OFF
  • Light bar is OFF when headlight switch is turned to low beams
  • Light bar is ON when headlight switch is toggled to high beams
I don't think that I'd wire the light bar without a switch, as there are situations where I'd want to use the high beams without the light bar (such as flashing them at oncoming drivers without totally blinding them).
Old 11-21-2018, 09:41 PM #8
edwinj edwinj is offline
Real Name: Edwin
edwinj is on a distinguished road
Real Name: Edwin
pics?
I keep running across this thread, as I'm trying to figure out how to wire my LED light bar to come on with the brights as well. I've got the in cabin switch working perfectly, and i see the AOB diagram 2, but my extent of electrical skill is pretty minimal, so I'm not sure where I'm supposed to tap into the bright light trigger.
Do i run something off of the relay cables in the engine compartment or am i tapping into a skinny wire in the dash panel somewhere?
Any pics you have of your setup would be great. Or, even just an explanation on the bright light piece of the setup.
Thanks in advance!
edwinj is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 09:48 PM #9
ElDuck ElDuck is offline
ElDuck is on a distinguished road
Anybody know which color the grounding wire of the high beams is, by chance?
ElDuck is offline   Reply With QuoteReply With Quote
Old 05-18-2020, 10:05 PM #10
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Should be red w/green stripe, it'll be the same color wire on both driver and passenger high beams
Brights but no Dim 96 4 runner zstevens 3rd gen T4Rs 7 08-09-2011 07:44 PM
Brights not working. hulk311 Problems & Warranty Issues 6 02-13-2008 03:26 PM
brighter brights bonds44 4th Gen T4Rs 15 02-05-2008 01:31 AM
Brights not coming on pickerdd Problems & Warranty Issues 5 06-01-2007 06:40 AM
Brights Don't Work 607T-town Classic T4Rs 3 09-26-2005 05:16 PM
