02-23-2015, 12:05 AM
## issues after body lift ##
Got 1 inch toytec bl installed today.
NOW:
Horn no workie
Airbag light on
Vsc lights on
Small click when turning steering wheel.
2007 Driftwood Pearl SR5 V6 4x4 /MB Wheels TKO 17x8.5 -6mm/ Hankook dynapro mt2 285/70/17 / bilstein 5100s -1.5 daystar rear spacer lift on moog fj coils / 1" Toytec body lift / ddm hids / interior leds / reverse light led / vsc - atrac disable mod / limo-30% tint/ rear diff breather mod / rola vortex roof rack / hanma 30" LED lightbar / kenwood ddx373bt w backup camera / ppi p900.4 / sundown sax1200d sa8d4v1.5 / diamond audio d6 comps / SPPC black halos
02-23-2015, 01:22 AM
Real Name: Jake
Real Name: Jake
Did you put the steering shaft spacer in? If so sounds like you turned the clock spring too far and broke it. I did the same thing when installing mine.
02-23-2015, 01:35 AM
agreed, sounds like clock spring is broken.
2014 Trail
A mild build She gone... sad face.
2001 Limited 4x4
02-23-2015, 01:41 AM
Yes, steering spacer in.
How do i remedy?
02-23-2015, 02:51 AM
Real Name: Jake
Real Name: Jake
How do i remedy?
Replace the clockspring. You pretty much follow this exactly. I think I replaced mine in about 20 min.
How to install a Clock Spring a.k.a. Spiral Cable.
02-23-2015, 03:18 AM
Will that take care of all my issues? Thanks for the help and link.
02-23-2015, 11:42 AM
Real Name: Jake
Real Name: Jake
It should with the exception of the vsc light, but my guess is that will go off with a zero point callibration.
http://www.toyota-4runner.org/proble...libration.html
02-23-2015, 03:12 PM
Got vsc lights off. Now just got the airbag light, no horn, or cruise control.
04-06-2015, 08:38 PM
They're telling me at the dealership that the click spring is like $265
Is that right?
04-07-2015, 02:51 PM
Is that right?
Check ebay. I broke my clock spring installing a body lift and experienced the same issues as you minus the VSC light, so i bought the clock spring below for $35.
If you do purchase this one, just make sure all of the metal prongs get connected properly. One of mine didn't connect when I initially installed it, so my controls didn't work. Turned out that a prong was bent out of place, so I corrected that and problem solved.
Finally, since this one may not be oem, there may be a slight crunch sound when you crank your steering wheel. It doesn't affect performance or anything, just a little noise.
New 84306 60080 for Toyota Lexus Spiral Cable Sub Assy Clock Spring Airbag | eBay
04-07-2015, 03:41 PM
Real Name: Jake
Real Name: Jake
Is that right?
That sounds about right for a dealer price. I picked up a used OEM one on ebay for $30 or so, as I didnt trust the non-OEM ones. Didnt really matter in the end though, as it recently broke again. This time I might just go with a new one from the dealer to hopefully prevent any issues.
04-07-2015, 04:44 PM
THANKS FOR THE INFO AND LINK
WHY DID YOURS BREAK AGAIN
04-07-2015, 06:31 PM
Real Name: Jake
Real Name: Jake
Not sure actually haha. Maybe it was damaged when it was taken out of the car that I bought it from, or I damaged it while putting it in. It lasted close to a year before breaking though, and I didnt take the wheel off at all, so who knows.
